well, then I hit "refresh" and it shows OFF. im not making that up I havent tap the dimmer or anything. RL made it go off, it went off and stayed off. but hub report it been at 9%
here is what I do:
top right, it shows 9% (ok, to do that picture, I hit "set level" at 9%, but trust me, that how it was. once out of 2 times I trigger the all off RL, it does wrongfully report a dimmer been turned back on. we can do a TEAMS screen share if you want, I can show you)
then I hit refresh on the device and it shows off. but the zooz light remained physically untouched. blue led of zen72 is till ON showing light is off
I pushed the test further to confirm the switch was actually really off and wrongly reported dim by the hub
so i turned on all light in my house again (using dashboard). waited 20 minutes, then called the all off (using dashboard again)
now the TV room in the basement is showing to be on at 10%
Much more likely is that the device is doing this itself. Not a clue why it would, but in all the years, no one has ever found a hub invented random event.
since it's always random dimmers that have a wrong status after a all-off RL, I used preferance manager and turned on debog logging on all zen72.
usualy I could reproduce the issue once out of 2 attempt or 2 out of 3. but this time took about 10 attempts. but got 3 lights that are actually off but report the wrong status.
