I have spent a few hours trying to get the Ring keypad to connect to the HE. It is never seen. I have tried a factory reset, moving the unit next to the controller. I think I have read every article on this to no avail. Any help will be greatly appreciated.
OK, I feel stupid. Turns out that I did not have the micro USB plug all the way into the keypad. Once I got it in, the device was found.
Now I have a different issue. The HE does not recognize the keypad when I try to arm/disarm HSM. If I arm the system manually, the keypad does recognize that. I do have the keypad configured to arm/disarm HSM . Any ideas on what I need to do?
You shouldn't need the USB cable plugged in for it to pair.
The ring Gen 2 devices can be very picky. Did you pair it with S2 security or change any of the security parameters. They need to have exactly what they ask for when they prompt you for security through either the app or through Smartstart. Without that they just will have problems.
I had a few issues getting my to pair fully as well. I finally had to hold the little reset button on the back to get it to rully reset and then add it with Smartstart.
Check Live logging to see if anything is logged when pressing the buttons and such. If not it probably didn't fully pair and needs to have everything reset.
I could do a hard reset but it would not pair until I plugged in the unit properly. I was able to scan the QR code to pair the keypad. Once I did that, all was good.
How did you get the keypad to work and arm/disarm the system. I cannot get mine to do anything.
Can you go into the Zwave details under settings for the hub and look at what security is used when it was paired to the hub. I experienced this behavior when my keypad didn't pair right the first time with incorrect security.
When you enter your code and press the arm home button does the keypad respond in any way? It should light up the armed home button and say "home and armed." That function is, I believe, controlled entirely within the keypad.
I would remove and setup again. You may want to check Rings info on how to trigger the pair properly so you can get it to exclude. I know I ended up just doing a factory reset on the back to clear it. I was fortunate and was able to remove the ghost it left behind on my hub fairly easily.
That is great to hear. I will point out ne more thing just to save yourself some headaches. I have had good success with my ring keypad once it was setup. The one thing i have happen was an occasional issue where the keypad would stop talking to Hubitat after certain events where the hub and Zwave radio has been reset due to a power loss or me working on other stuff in the house. If that happens just pick up the keypad and single press the reset button on the back. It will help kick it to reconnect. I believe it will reconnect on it's own if you just leave it alone but i don't know how long that might take.
