Yeah I don't know what I was thinking.. It makes sense and I can test for armed/disarmed in HSM so all good.
@rpaterson81 need your help....... integrating the ring keypad into HSM been reading quite a bit but stumped on how to get it to arm home and arm away with regards to setting the codes. You made reference to the lock code manager..... how does that work?
Lock Code manager will allow you to add and remove user codes to be used with the keypad to Arm and Disarm HSM.
Info on installing and using Lock Code Manager can be found here:
https://docs.hubitat.com/index.php?title=Lock_Code_Manager
Also be sure to add your keypads in HSM in the Configure Arming/Disarming/Cancel options. More info on HSM can be found here:
https://docs.hubitat.com/index.php?title=Hubitat®_Safety_Monitor
