This device has a unique join sequence that currently seems to only work with S2 security. When we get S2 going we should be able to support this keypad without a problem.
Don't ask how or when S2 will roll, even if I knew exactly I wouldn't say anything anyway.
@bcopeland, Can you elaborate on what those features are? I've seen conflicting reviews on them, and would like one that could make a sound- perhaps during arming or when a door/window sensor is opened.
Stupid question that maybe you can't won't answer... But since S2 doesn't require a 700 series chip why can't we get S2 on the existing C-5 hubs (aka why does this require C-7 hub when it isn't Zwave 700 specific)?
Ha, well this is theoretically something that could be done, but it is not a zero effort undertaking. We've been focused on getting C-7 ready to go.
I should add: We built an entirely new Z-Wave stack for C-7, one that supports S2. S2 is not an easy protocol to implement. Our C-5 Z-Wave stack does not support S2, and the effort to make it do so was scoped out to be a large effort (which is why you don't see many hubs supporting it). Could our new Z-Wave stack be made to run on a C-5? Maybe, but I can't see how we'd justify the effort, and frankly at this point, we've dined too long at the Z-Wave table as it is...
Z-Wave requires an inordinate amount of engineering resource. We've been putting a lot of effort into it for quite some time. It gets old. It's not an easy protocol to implement.
Ha, so my answer to @JasonJoel should probably be: how much would you pay for it and how many others would do the same?
That makes sense. I was genuinely just curious, and wasn't trying to be critical at all. Maybe I shouldn't have been a smart arse by saying "won't" - I was trying to be funny.
I definitely wasn't aware that it would take so much effort to do it on the C-4/5 once it was done on the C-7. So thanks for the explanation.
I'm getting a C-7 or two either way, so I'm covered.
