[Resurrected] Advanced Honeywell T6 Pro Z-Wave Thermostat Driver
40°F is the minimum heat value that the thermostat supports.
So I finally got my new Honeywell T6 (the newest model 700 series TH6320ZW2007) that was back-ordered for 8 weeks. I'm not wired into the HVAC system yet, but have the tstat running on a wall wort near its final install location while I get it all set up.
Thanks for this driver. Zwave pairing and overall Setup with the Advanced driver and then the tsat scheduler has been a joy so far.
One question I have, the install manual shows an ISU 1421 (Z-Wave Temperature Resolution) setting, but both regular zwave menu and advanced installer menu seem to skip right over this ISU (jumps from 1420 to 1425) on the tsat itself. I didn't specifically see a setting for this in the advanced driver. There is a field to set the reporting change interval for temp and humidity, but that might be limited to 1 degree if that is what the tstat has 1421 set to?
Manual says its set to 1 degree by Default, I'd like to set to 0.5 degrees if possible. Anyone know how to do that, or something else I need to do to expose it?
If you pair it while it's on mains power it will become a repeater. If you're just using batteries it won't repeat.
Not all isu's are available on all models.
Yes, I paired on AC; no batteries even installed. (yet). The zwave temp. resolution reporting r seems independent of that.
Right that was just a side note. Anyway as I said, not all models have those isu's available to them. The ISU table in the manuals encompasses every model but isn't available on every model. I looked at both my 500 series and my 700 series and neither has that ISU available...
The 0.5 deg. setting is in a weird place.
Menu—>Z-Wave Setup—>Temp Report—> Advanced
Wow I have never seen that... Is it also reflected in the driver attributes?
Edit: Tried setting and hit configure in Hubitat. Hubitat doesn't seem to reflect the 0.5 setting outlined by @user3790 nor does it show on the screen.
Yes! Thank you very much! Instant fix when I set it at the T6 itself, although is in a just slightly different place:
(first item in temp report, no "Advanced"); maybe due to the 2007 model being newer (unless you also have the 2007)?
I must have scrolled right past it 1000 times.
I wasn't buying that the install manual would have an actual ISU number spelled out and not support it (although looks like they did miss he f/w implementation to view/set said ISU (1421) in the advanced installer menu, so...).
rlithgow1,
I initially tried setting it from the hubitat zwave config side, but that no effect. Setting it at TSTAT itself worked for me though.
I finally installed the T6 after getting past the trial on wall wort. I have to say, the install hardware (the UWP and mounting wiring block) was a joy to install; well thought out and an easy process. Ive installed quite a few TSTATs for myself and others, this was one of easiest.
Life on the advanced driver has also been good. I wasn't sure how things were going to go with the Honeywell "Zero Deadband (non settable) " operating mode of the T6 with the "advanced algorithm", but seems to be doing ok, I guess its just a balancing act against the cycles per hour setting and some learning history for runtime to target temps.
The only thing I haven't quite reckoned is that my system is 2 Stage Heat/1 Stage Cool (Conventional), but both the Tstat and the driver seem to only allow one setting of stages for both (so either 1/1 or 2/2). To be fair I did note that in the manual ahead of time. I guess worst case I can just change configs twice year, setting to 1/1 during cooing season and 2/2 during heat.
ISU 220 sets stages for cooling, 221 sets stages for heating... So they indeed can be set for 2/1 . It's how mine is set
At the T6 Gui itself, yes, there are two ISUs. I meant in the HE advanced driver GUI , there is a "Stages" field that seems to drive the stages for both heat and cool; but I cant explicitly see how that field is mapped to ISUs.
The advanced driver still shows settings related to stage 2 cooling.
It may just be a presentation thing; the T6 GUI will automatically hide fields based on prior context select selections, where the advanced driver screen maybe shows all fields all the time.
I don't have aux or emergency heat as another example , but I can't see how to explicitly disable them from advanced driver ("no selection" doesn't seem to cut it.). And in the "Current States" summary section of the advanced driver, supportedThermostatModes shows: "auto", "off", "emergency heat", "cool").
For that I'll let @thebearmay chime in. Perhaps he can write something in to eliminate the emergency heat aspect but honestly is that even a big deal? I mean you can just ignore it. The driver is reading the abilities from the thermostat itself and looking at the isu chart it doesn't look like that can be set to disabled. @bcopeland may have an idea as to why but as I said does it really matter? You can set stages under preferences but I don't think that's available as a displayed attribute from the thermostat itself.
Parameter 6 (Stages) is the cooling stages setting
Parameter 7 (Heat Stages Aux/E stages) - is the heating stages setting
Especially now that they have fixed the dashboards for the stock generic driver, I still maintain that this driver is more dangerous than helpful.
Set your ISUs on the device, and leave them alone. If you need to adjust something, do it on the device, and not take the (however small) chance that a misclick or error somewhere in the chain sets an ISU in a way that you weren't expecting.
Can anyone tell me what the functionality of Initialize Vars command does?
Can anyone give me some basic help to get a rule in rule machine to initiate the "Away" command when the Hubitat mode changes to "away"?
Simply set mode via custom attribute from the thermostat
Under Custom Commands for the device you should be able to find Home and Away, just a matter of writing a rule (or two) to trigger on Mode change and run the appropriate custom command.
Initialize Vars is a method to correct the supported thermostat and fan modes to the current standard definitions.
@rlithgow1 and @thebearmay. Thanks for the help! I just could not, for the life of me, remember where to find that option.
Thanks, i went and looked at what the ISUs were set to. I had set Parameter 7 to 0 for "none" (thinking that was meaning no aux or EM heat) in the driver. At the thermostat, this resulted in ISU221 being set to 1 (1 stage heat), and I see Cooling is 2 from stages. So that matches.
Looking more closely at the ISU description in the installer section, ISU221 is context set by ISU 200 first. If ISU 200 is conventional, then 221 drives heats stages. if ISU 200 is Heat pump, then ISU221 drives the AUX/EM stages.
It might be less confusing if the advanced driver used the same names for the fields as the ISU fields are named, but I realize there's probably long historical reasoning and maybe some attempts to simplify the isu language.
Having a dynamic context menu in advanced driver might be a lot of work(like ,the heat pump settings grey out if you select conventional for system type as one example) ;but that would be another way to clarify whats being set.
Yeah, I was generally feeling this way (set ISUs at thermostat and forget), and I initially set all the ISUs the way I wanted; but I wanted to make sure the zwave config in advanced driver was also in sync with the T6, in the event the settings ever get refreshed by HE, or I needed to restart/reconfig etc. And I think on the first device add and initial setup, some of them clearly got flipped(as I didn't have all the field mappings between advanced driver name and actual ISU. probably still don't.
I didn't give the stock driver a run as I was originally thinking I needed this for at least a few of the options that I thought were missing, but maybe that wasn't the case.
I started using this driver because when it was originally released, it solved a couple of issues with both dashboards and supported modes. (To be precise, it solved the modes issue naturally, and you could edit the driver to work around the dashboard issue.)
However, they have since fixed the dashboard issue, and the stock generic (NOT the stock T6-specific) driver provides all the functionality correctly.
I don’t recall which thread it was in, but someone else alerted me to the dashboard fix, so I tried the generic driver again and it works fine.
I can’t think of anything this driver offers for basic functionality that the stock generic driver does not.
