Replacement for Simple Dates
SInce BPTWorld apps are no longer supported, anyone know if there is a supported app which has the same features as Simple Dates?
I'm looking to have the ability to add dates with description and then have them show up on the Dashboard with count down numbers... the same capabilites as this addon:
Simple Dates
What's your concern with the current app you are using? Is something not working correctly for you?
Well first, I just did a soft reset on my C7 since I moved. Thus, I need to re-install the Simple Dates app. When I went to the website to copy the driver/code, I noticed the message that the app was no longer supported. Thus, I want to see if there is another app which is supported. If not, then I'll have to make a decision on whether to use the old app without support or do without.
Understood. I glanced over the code; and it's a fairly basic app. I don't see it "breaking" with updates to hubitat anytime soon. Granted, you won't get new features or developer support... but the community here is quite responsive and eager to help if you post again with any issues.
I wouldn't be concerned about it being unsupported if it is working fine for you. To answer your question; I'm not aware of any replacements.
Are you aware of the HPM app? It is a community app that many of the hubitat community developers use to add/update their applications. You can use it to search by keywords; and perhaps find an app that has similar features.
https://hubitatpackagemanager.hubitatcommunity.com/installing.html
Yes, I've had HPM installed for several years. Searching HPM was my first effort but did not see anything so posted here in case I've overlooked one.
