I’ve got a Hue hub integrated with Hubitat. I’ve added a couple of Innr Smart Plugs to my Hue hub, with the hope they will work as repeaters for the Hue.
Does anyone know if the Innr smart plug does in fact work as a Zigbee repeater for a Hue network? Is there anyway for me to tell if my Innr plugs are working as repeaters?
I know Hue bulbs are repeaters, but I don’t need anymore of the bulbs, and I don’t really have a place to put them. That’s why I went with Innr plugs.
Hue bulbs repeat. You shouldn't needn't to specifically add any repeating devices unless you only have remote-type devices (or a long range and can't use a bulb in between) for some reason. Do you have a specific problem you're trying to address?
My Hue bulbs sometimes drop the connection. So I want to place a repeater between the bulbs and my Hue hub. It’s not practical for me to move my Hue hub, and not practical to add another bulb to serve as a repeater.
AFAIK, there are no available repeaters aside from bulbs for the Hue hub as there are no wall warts or switches that support the ZLL Zigbee profile that the Hub hub uses. If someone finds one, I'd be amazed as I was searching for years for one that would support ZLL.
In the end, I ended up throwing a small lamp into my attic with a single white Hue bulb in it to help extend the range.
Here is a way to move your hue bridge to anywhere in the house. I have one on all my HE hubs and you can't tell any difference in speed. But it allows you to centralize the hub or bridge. They connect to the modem through WPS.
@corerootedxb I am not really up on the transmission between the bridge and the modem. Not my area. But I don't think the ZLL will play a part in it. Hopefully someone who understands how that part works can chime in. It basically is just a wifi connection to the modem via the air instead of directly plugging in an ethernet cord. I think Mike said once that there isn't a whole lot of difference between ZHA, ZLL and Zigbee 3.0 (which contains both). I think I have it right.
Yeah, I saw that too and that you answered it. That's why I didn't touch it. No worries mate! Hell, how often do we all run off the rails in one thread or another? LMAO!
I used an inexpensive Tradfri repeater (paired to the Hue bridge using touchlink) and the light at the end of my driveway has been pretty much solid ever since.
It's a means of pairing Hue compatible devices (but which are not natively supported by Hue) to the bridge. It's part of the 3rd party Hue Essentials app.
Considering that no one (that I have heard of at least) has been able to join an an XBee to a Hue bridge and see if these devices are actually repeating for the mesh, and the fact that the official certification of the repeaters don't show commands for being able to repeat messages in a ZLL mesh, I honestly don't think they are truly repeating for the Hue bridge.
