It never died completely, but it started seriously slowing down by 11pm. It stops at sunrise of course, so everything would be fine during the day. Took me a few days to figure it out, heh.
Do simple conditionals with delays get evaluated at rule trigger, or after the delay?
The second simple conditional (just before the ELSE) didnt fire. I now suspect that it's because at the time of the trigger, it was off/false....can you please confirm?
In your rule, on execution #1 it turns on the light and that status likely will not get updated in the system before the very next line runs to evaluate if it is on. I don't see that working reliably at all.
I guess you could do this, though:
ON simple condition
DELAY for a few seconds
OFF simple condition
Has anyone managed to get RM4.0 to work with add/remove lock codes via custom actions? I totally removed my WC instance that only had one rule -- to control lock access based on mode and specific presence.
Yes, this works. There are 3 parameters. The first one is the number for the code, and is a number type parameter. The second parameter is the code, a string. The third is a name for the code, also a string.
you should make your triggers “changed”. that will cause it to eval the rule when they are false also, which is what needs to happen for your else condition.
OK, so here is one I cannot get to do what I want. I must be doing something wrong, but I cannot for the life of me get this to add "cancel delayed actions" to my ELSE.
I was OK up until the ELSE. When I try to insert an ELSE, there is no other action or way to add to the ELSE. If I save it, I just get ELSE with no way to do anything further. It ends up looking like the picture above with just a blank ELSE.
What am I doing wrong here. I spent literally an hour messing with this and I cannot get that one stupid cancel. Why does this have to be so convoluted?
