Although not documented there is actually an LED indicator inside the ZEN74. You would not be able to see it with a cover plate on the switch though, and the default is for it to be always off. When I tested it those parameters did work but I will have to confirm if they still work on the current firmware.
For the beta driver (which I need to just finish and make official), I have an easy way I can shut those parameters off for specific models.
Also, even if it says there are "Pending Changes" the driver itself would still function 100% otherwise, the pending changes does not prevent any other features from working.
That is not exactly right for the Zen74. If you turn on the LED it will shine out around the toggle switch. It isn't very bright though. I actually have it turned on for a few of my a zooz toggle switches. It can be a nice addition when it is pitch black.
FYI. I just reverted back my Zen74 to v10.0 of the firmware and all is good again. v10.1 just had problems. Hopefully get the kinks worked out of the V10.1 so we can get proper fade over time
Good to know, I have only had mine in a test rig without a cover-plate so I was assuming it would not be very visible.
If you have not already report the issues to Zooz. I have a ZEN74 and the updated firmware but I have not had a chance to install or test it out yet. I don't actually have that switch installed in the wall yet.
I have several emails with them about it after you responded to me. I believe they are fully aware at this point. They had to send me the old v10.0 firmware for me to roll back since i was on 1.2 previous as that is what my switch came with. Hopefully fixing that identification information isn't to hard. Either way at this point i wouldn't suggest upgrading to 10.01 or at least not until some more time has passed.
It took them less then 24 hours to respond to me the last time after i confirmed the rollback fixed what I was experiencing. I provided in that response v10.02. This does appear to have fixed the problem and have the udpate to allow proper setlevel over time. So that is good. I would point out most of the delay has been on my part as well to get this resolved. Zooz has been very responsive.
Updated on HPM, for ZEN Switches/Dimmers only, ZEN30 no update.
If you were running the beta version, there are only minor updates to this final release.
Version [1.5.0] - 2021-11-24
Added
ChangeLevel capability support so level can be adjusted from button holds (Dimmers Only)
Warning if driver is loaded on unsupported device (including wrong type)
Added support for new parameters where applicable, Disable Programming from Paddle is the big one.
Changed
Total overhaul of parameters code to make it easier to maintain
Changed switchMultiLevel class down to V2 as no V3 features are needed (Dimmers Only)
Thank you for this driver! I'm having as issue with it. I have many Zooz 77 dimmers. I like to have them set up so that a single tap turns to full brightness, and a double tap turns to a pre-set brightness. I've done this by adjusting parameters 12, 18, 25 with the Advanced Driver (v1.5):
The issue I'm having is that when I double tap, the light first goes to full brightness, then dims to the set level, instead of turning on directly to the set dimmed level. This is really annoying at night, since I use the double tap to go into rooms where I don't want to turn the light to full brightness.
When I change over to the built in Zen77 driver, it behaves as it should (single tap to full brightness, double tap to pre-set dimming level). Contrasted with the Advanced driver behaviour on double tap that first turns it to full brightness, then dims to the pre-set dimming level.
The same driver, same settings, with a Zen72 dimmer works as it should (goes straight to preset dimming level with double tap, instead of first to full brightness, then to dimming level).
Firmware on the dimmers is 10.0
Is there something I should change, or is this a driver issue?
I am not at home this week to test, but you enable debug logging and get a screenshot of both cases on the ZEN77 and post it.
The parameters are set directly to the device, and I assume you are setting them with my driver and they are not being changed when going to the stock driver. So that should not be a variable. The actual native single and double tap up features those parameters set are totally firmware level, the driver has no part in telling the switch what to do once the parameters are set, so that should not matter between drivers. When you tap the switch physically it does its thing and tells the hub what it did, the driver itself does not send any commands back in this case.
The ONLY thing I can think of is that you setup a button controller or rule, to act on button 3 pushed and have the scene control enabled (param 7). This would possibly only trigger with my driver because I think the stock driver sends a "doubletapped" event and not the button 3 pushed.
Also, it looks like you have modified the driver, as your param 12 and 25 marked "DEFAULTS" are not the actual defaults in my code.
I forgot, I had modified the defaults, to save time since I wanted the same behaviour in all my switches. I've restored to your original code for the purpose of debugging.
As I was compiling this response, I could not get the desired behaviour out of either driver this time. I could swear before I wrote my original email, I had confirmed this behaviour. So I'm guessing it's a firmware issue then with the Zen77. Looks like with a double tap, it registers a single tap then double tap. When I switch the single tap and double tap behaviour, the bug persists (single tap brings it to full brightness, double tap brings it it custom level, then to full).
Desired behaviour:
Single tap: Full brightness
Double tap: Custom brightness (set by param18)
Case 1:
ZEN77 dimmer with driver: Zen Dimmer Advanced v1.5:
Behaviour:
-- Single tap: turns on to full brightness
-- Double tap: turns on to full brightness, then immediately dims to custom brightness level.
@jtp10181@agnes.zooz Not sure if this is a driver issue, firmware issue, or intended behavior. This is on a Zen21 with firmware 4.04, though it may be the same on other models too. The auto-off timer doesn't work under the following conditions:
Turn on scene control
Disable paddle control
It could be just one of the above settings that makes the auto off not work. I have not tested. I had the auto-off set to 20 minutes and it was working before I made those changes. This switch is for a closet light and the reason I wanted to turn off physical control of the relay and enable scene control is that I use a contact sensor to turn the closet light on and off. I wanted to re-purpose the switch to turn a lamp on/off. So button 1 & 2 control the lamp, but I can still control the closet light manually if needed using buttons 3 & 4.
I know I can easily create an additional rule to turn the light off after a set amount of time when it comes on, which is what I plan on doing, but I thought I'd let you know just in case.
That is a device setting so it is totally hardware/firmware controlled. I would guess that disabling paddle control inadvertently also prevents the auto-on/off from working. The only way it could be a driver issue is if the parameter is somehow not being set. Check in the DATA section at the bottom for the "configVals" data map. First number in each pair is the parameter number, second number is the value the device reported back to the hub it is set to. You can use that to confirm the parameters are set as desired. The auto-off timer on that model is a combination of parameters 3 and 4, #3 would be set to 1 to enable it and #4 would be the duration (20 in this case).
This is indeed what shows in the data section. Which makes total sense because the auto off was working before I made the changes.
EDIT: I always forget, which one is canceled when the rule retriggers, a wait or a delay? I'm thinking I want to use a delay so that if you open the closet door, close it, and then open it 19 minutes later it doesn't turn off after 1 minute. But maybe I need a wait 20 minutes. I really wish there was helper text somewhere when selecting various wait or delay actions.
I didn't even know one would cancel if the rule triggers again? I have done it before by doing a wait for actions with a timeout. Have it wait for the device to turn off, so either it turns off before the timeout and the rule turns if off again, or it times out and turns off.
I also just found in the Basic Rules app there is a "on and stays on for.." setting which basically does all that for you.
FWIW - I've played around and gotten the Indicator Command Class working to turn the LED on and off (I'm using ZEN77's, only tested there). I found that only the Device Identifier indicator ID (0x50) is supported, and only Parameter ID's 3, 4, and 5 (all related to toggling of the indicator). But it's possible to "abuse" those parameters to turn the LED on and off with this:
The extra check against state variable was needed in my application because I can get multiple "off" commands in sequence, and that caused a short flash of the LED.
Small nitpick - and I'm not sure if this is something that could be addressed by the driver at all. Can you make it so that doing a refresh updates the last activity at field for the child device of the Zen30? Would be helpful for those of us that use Device Watchdog to keep on eye on our devices to make sure everything is responding properly. It seems to update like I'd expect for other devices, so I'm sure it has something to do with being a child device.
I probably could, but you really only need to monitor the parent device, since they are tied together its going to be all or none situation if they go offline. I need to refactor that entire driver to bring it up to speed with the other one anyway,
Minor update to 1.5.1, a couple of parameter fixes and also a fix that prevents some errors with HE v2.3.1 was the main reason I wanted to push it out.
UPDATE: [1.5.1] - 2022-03-22
Changed
Description text loging enabled by default
Fixed
Added inClusters to fingerprint so it will be selected by default
threeWaySwitchType options corrected between switches and dimmers
Parameter #7 removed from ZEN71/72 which do not have that option
Global (Field static) Maps defined explicitly as a ConcurrentHashMap
Thanks for the great work on this. However, I'm still lost when it comes to creating scenes to be controlled by my Zen82 switches.
I have tried both the onboard Zen72 drivers and your drivers. I've tried setting the SCENE parameter (#13) to ENABLED or DISABLED, and I've tried setting the double-tap behavior (parameter #12) to DISABLED and FULL BRIGHTNESS.
No matter what combination of settings and drivers I try, when I go in to create a new scene, none of the switches show up as options under "Select button to push upon scene activation".
What do I need to do to trigger scenes by double tapping my Zen72 switches?
The terminology Zooz uses it a little misleading. The buttons don't trigger scenes directly, they just send out button events. Use the stock "Button Controller" app to catch the button events and then trigger a scene (or whatever you want really).
If you are still stuck on setting it up (or any other settings on the switch), I would start a new thread and feel free to @ tag me. Myself and others I am sure will jump in get you going.
I'm working to associate a Zen71 to directly control a Zen51 relay. I have everything up and running independently in Hubitat, but I'm hitting a roadblock on the association. My Zen51 deviceID is shown as 513, and I believe that it is decimal, so it converts to 201 in Hex. No matter what I enter in the Device Associations - Group 2 field, it appears to cut it down to only the last 2 digits. For example, if I enter 201, after I save, it changes is to just 01. If I enter 513, it changes to 13. I'm able to enter numbers all they way up to 99, but then after that, it ignores all leading digits.
This is my first foray into associations, so my assumption is that I'm simply missing something obvious, but I'm having a hard time finding anything with Google searches. Any help would be greatly appreciated! Also, thanks for all the hard work on this driver!!
