[RELEASE] Zigbee Sonoff - generic relays [driver]
Zigbee Sonoff - generic relays driver
ZBMINIR2
Sonoff MINI ZB ,eWeLink ,3A Smart Home ,Generic
Generic zigbee relays
Lamp_01, SA-003-Zigbee, 01MINIZB, BASICZBR3, LXN59-1S7LX1.0
Sonoff light switch ZBM5-1C-120
Supports presence, alarm ,switch, strobe ,siren, Refresh
I wrote this because I have lots of the above switches and some don't work with OlaLabs generic driver and some don't work with internal generic drivers.
This driver allows me to use the same driver for all of my relays.
And has a standard report for all my switches with better logs.
Corrected cluster 5 problems. Added support for sonoff switch and tiny relay.
I still need fingerprints for other devices that you get to work.
If your having problems with drop outs try this driver. Also in HPM
Hi.
I have installed your sonoff relays package as im trying to get some Sonof ZB Mini Extreme switch devices working properly.
The generic ZB driver works but basic rules are not working with these devices
I install the package via package manager but under devices, Im not able to find your driver in the drop down list under "user".
Do you know what i need to do?
Mike
Was having some unreliable behavior with generic zigbee switch drive and tried yours out. It seems to have fixed those issues. Thank you for this.
Thank you!
This is working well for Sonoff ZBMINL2 Thanks!
Hi there
I started using this driver for some Sonoff ZBMini Extreme L2 modules. I found using the generic driver sometimes was out of state sync with the hub as mentioned in the notes in the driver.
I think this driver works better - thank you!
I have noticed errors in the logs for all the modules that I have moved over.
My process for moving over is to change the driver to Device - Press the buttons to remove states etc and then select this driver - I have pressed the option to "Resend Last State on Refresh"
This error was confirmed in another post I found but was attributed to the driver and not the platform.
Could you fix it?
Nope, no fix
I am getting the same errors as you. The relay is so inconsistant. I thought grabbing this driver would work, but I still have the same issues/warnings. Did you get it to work?
No, I still have a few left in my house but I have been slowly moving off them
damn, that sucks. I dont really have any other options for this location since I do not have a neutral wire. Unless I wire up a non neutral switch
I started using these.... Dimmer Switch Modules - Candeo
Still experimenting
Driver has been updated. cluster5 was not being seen on my devices so i didn't
notice that, Its been upgraded so future errors wont warn but be under debugging. |
I still need fingerprints for you devices that you find will work.
