I don’r have experience with any of the levitons.. Can you turn on debug logging and send me the logs to that point?
Richard - When I am writing more complex rules and such, I try to leverage devices (or even just a single device) as a group, as I have found this to be much easier to handle updates, device swaps, etc. All the code refers to those groups instead of the devices themselves, that way if something goes wrong, I can just fix the group membership rather than having to touch the actual code. The downside to this was the switch from Groups 2.0 to 2.1 since there was no upgrade path and was a pain to update every bit of code -- manageable but time consuming. Still, this approach has saved me lots of time otherwise when a device has gone arwy.
@tjsawyer Thanks for that tip.
@sujit - Were you able to update your Aeotec Multi-sensor?
I'd like to do the same for mine, and have struggled figuring out what firmware version I have an how to update it if I can.
There didn't seem to be anything in the logs actually, even with debugging on. Just a note about acquiring a lock. Do I need to do anything special other than toggle the debug switch?
All I see is:
dev:692020-05-04 12:21:04.806 pm warnUpdate process is currently running
dev:692020-05-04 12:21:04.790 pm debuglocked by: 04
--- Live Log Started, waiting for events ---
Can you send me that log?
Oops, yep sorry just edited my above post. Cheers
anything before that?
Because that tells me that the switch might have sent something unexpected
Oh I actually got past this on a different switch:
dev:662020-05-04 12:26:18.512 pm debuglocked by:
dev:662020-05-04 12:26:18.453 pm warnUpdate failed to find a valid target
dev:662020-05-04 12:26:18.177 pm infocalculating crc...
dev:662020-05-04 12:26:17.886 pm infofirmware total bytes: 65536
dev:662020-05-04 12:26:17.882 pm infoSorted all the bytes. cleaning up some memory...
dev:662020-05-04 12:26:00.242 pm infoVersionReport- applicationVersion:1.17
dev:662020-05-04 12:26:00.226 pm infoVersionReport- zWaveProtocolVersion:4.33
dev:662020-05-04 12:26:00.011 pm infoFirmwareUpdateMd version:4
Current States
- manufacturerId : 2F00
- firmwareUpdateProgress : Failed to find matching firmware
- firmwareTarget : null
- firmwareUploadPercent : null
- currentFirmwareVersion : 1.17
- firmwareFragmentSize : 40
- firmwareId : FB3D
- lockedBy : None
I'm using this firmware: https://raw.githubusercontent.com/djdizzyd/hubitat/master/Drivers/Z-Wave-Firmware-Updater/Leviton-DZ6HD_01_20.hex
This is saying the firmware ID in the hex file didn’t match what is on the device
This is also suspect.. Total bytes should be larger
Give me a minute to look this over
Awesome thanks.
I realized that I didn't have the debug logs on for this switch. Adding it below in case it gives any mroe information;
dev:662020-05-04 12:39:36.594 pm warnUpdate failed to find a valid target
dev:662020-05-04 12:39:36.580 pm debugFirmware Descriptor: [wFirmWareCommonSize:42683, wFirmWareBank1Size:40950, wFirmWareBank2Size:30263, wFirmWareBank3Size:8744, manufacturerId:12032, firmwareId:64317, checksum:27506]
dev:662020-05-04 12:39:36.352 pm infocalculating crc...
dev:662020-05-04 12:39:36.317 pm infofirmware total bytes: 65536
dev:662020-05-04 12:39:36.314 pm infoSorted all the bytes. cleaning up some memory...
dev:662020-05-04 12:39:36.311 pm debugParser: EOF
dev:662020-05-04 12:39:24.880 pm debugParser: 16 bit shift: 0x0
dev:662020-05-04 12:39:24.840 pm debugpacking all the bytes...
dev:662020-05-04 12:39:23.236 pm debugfirmwareMdReport: checksum 15691 firmwareId: 257 manufacturerId: 29 maxFragmentSize: null firmwareTargets: 0
dev:662020-05-04 12:39:23.224 pm debugFirmwareMDReport: FirmwareMdReport(manufacturerId:29, firmwareId:257, checksum:15691, firmwareUpgradable:false, numberOfTargets:0, maxFragmentSize:null, firmwareIds:[])
dev:662020-05-04 12:39:22.891 pm infoVersionReport- applicationVersion:1.17
dev:662020-05-04 12:39:22.887 pm infoVersionReport- zWaveProtocolVersion:4.33
dev:662020-05-04 12:39:22.662 pm infoFirmwareUpdateMd version:4
weird.. That should have matched... Give me a bit
Following back over here from:
Of which the latest firmware can be found here:
Then to my dismay and reading in other forums that there is no OTZ or HEX for Aeon devices but apparently some have extracted them from the .exe that is provided for their automatic updater that apparently others have been able to extract the HEX file from the binary.
I tried the 1st of my LZW30-SN On/Off switches and had to follow the above steps and be ready to push that air gap switch in quickly but it updated fine after that. Before it just kept nagging to wake up the sleepy device. Now just a dozen more or so to do. Thanks to @bcopeland for the excellent tool and thanks to @gavincampbell for figuring out the sequence to wake up those LZW30-SNs!
So I just saw that Inovelli released 1.17 this weekend for the LZW30-SN but I'm not sure how to get the URL, I may download it and put it on an internal web server unless someone knows how to get the URL? Thanks.
Unfortunately 1.16 didn't correct the sleepy device issue, going to 1.17 I still had to follow the above steps. I downloaded the firmware to my internal web server temporarily and created the mime type so it could be downloaded then used that URL. I plan to just run that update on one switch for a few days since I haven't seen anyone else update to it yet to make sure it doesn't introduce a new issue.
Wish there was a "legal" way to share all of the updates in a repository verses each person having to make multiple requests.
Right.. I would love to have a massive repository of firmware files.. The aeotec and leviton are what I would consider "grey areas" because they are on their website, just not in the correct form (exe extraction). But others that verify purchase prior like zooz, I wouldn't put that up as this would not be a grey area..
Thanks, Erik replied with this address too...
http://files.inovelli.com/firmware/LZW30-SN_1.17.otz
