That’s the direct/native link for the Google Drive file and its a permanent link. So you can use the link for lifetime! The direct/permanent link will skip the Google Drive web viewer.
@aaiyar Thanks for the offer but I really want to learn some how to do some of this on my own, you have help me so much with node red and other things. I think that I finally got it and it is now downloading the firmware? Thanks for you help also @bcopeland. It updated the firmware with no problem Thanks to you both for helping.
You know.. I don't believe in writing tracking functions into my code.. But it would have been interesting to know how many devices got updated using it.
I had 6 so far and have another 12 that I want to do but doing a little at a time. I'm just grateful to be doing inside Hubitat instead of the USB Z Stick. Thanks for making it easy on us.
I've been seeing other signs that there might be high activity or interference, such as scenes taking 10-20 seconds to fully activate. I'm not sure how to diagnose it though. I did make some recent changes to my mesh: I added two Inovelli Red dimmers and 3 Iris plugs with the Z-Wave repeaters enabled. Maybe the plugs? I didn't really need the repeaters but as long as I had the plugs i thought I'd enable the Z-Wave repeaters as well. Maybe they are interfering or adding additional hops?
Does anyone have any suggestions on how to diagnose something like this other than removing devices one by one until things start working? Thanks for any suggestions.
You don't mention it so ...have you done a Zwave repair since adding the repeaters ?
If not I'd do one, then reboot your hub via the GUI and in a couple of days time do anther zwave repair.
And don't panic if things seem a little jittery straight after the "repair and reboot", because the system should be sorting itself out.
I would also enable logging for these and any other devices you may have that are capable of reporting power usage. I had a single switch drag my hub into the mud with excessive power reports.
Thanks @bcopeland, @njanda and @bjcowles. I did to a repair right after adding the repeaters and have rebooted the hub since, but not immediately after. I'll try enabling logging and doing on second repair. I'll take this to a new thread if I need more help so I don't clutter this one more than I already have.
Great stuff @bcopeland, I just updated 5 Zen22s and 2 Zen27s. All went smoothly. Thanks to @aaiyar for outlining the Zooz process and @agnes.zooz for sending the firmware files over so fast! Love how fast my dimmers are now.
I want to add my thanks to @bcopeland and @aaiyar to those sent by @liquidskin.
I too was able to successfully update my ZooZ Zen23, Zen24 and Zen27 switches without issue.
Fantastic job!!
That's actually one of the few things I don't have.. I bought a bunch of the Red dimmers.. but for the 2 switches I needed.. I just got the black series..
