I'm on the case!
In all the logs I'm pressing keys from left to right, starting with single press on then off, then one double press, one triple press and one hold, before moving on to the next key.
I'll do combo presses another time, because this is already a lot of logs!
Starting with the 3-key QBKG25LM, it paired very enthusiastically as this:
- endpointId: 02
- buttonCombos: 0
- application:
- driver: v0.8.1.0814
- model: lumi.switch.l3acn3
- physicalButtons: 0
- manufacturer:
dev:1192020-08-29 23:45:15.616 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC008FC001000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 08, attrId: 00FC, encoding: 10, command: 0A, value: 00 | msgMap:[raw:BCFA01FCC008FC001000, dni:BCFA, endpoint:01, cluster:FCC0, size:08, attrId:00FC, encoding:10, command:0A, value:00, clusterInt:64704, attrInt:252, valueParsed:false]
dev:1192020-08-29 23:45:13.615 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:45:06.927 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100066100103280F052105009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100066100103280F052105009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100066100103280F052105009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100066100103280F052105009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:45:06.923 debugdirty model = lumi.switch.l3acn3, clean model=lumi.switch.l3acn3
dev:1192020-08-29 23:45:06.918 debugModel Name Received - description:read attr - raw: BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni: BCFA, endpoint: 01, cluster: 0000, size: 2C, attrId: 0005, encoding: 42, command: 0A, value: 126C756D692E7377697463682E6C3361636E33 | parseMap:[raw:BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni:BCFA, endpoint:01, cluster:0000, size:2C, attrId:0005, encoding:42, command:0A, value:lumi.switch.l3acn3, clusterInt:0, attrInt:5]
dev:1192020-08-29 23:45:06.581 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:45:06.257 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:45:05.978 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:45:04.433 infoButton 3 was double tapped
dev:1192020-08-29 23:45:04.429 infoButton 9 was pushed
dev:1192020-08-29 23:45:04.425 infoMultistate - endpoint: 43, taps: 2, physicalButton: 3, physicalButtons: 3, button: 9
dev:1192020-08-29 23:45:04.421 infoMultistate - description:read attr - raw: BCFA2B00120A5500210200, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:BCFA2B00120A5500210200, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:1192020-08-29 23:45:04.043 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:45:03.701 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:45:02.208 infoButton 3 was pushed
dev:1192020-08-29 23:45:02.203 infoMultistate - endpoint: 43, taps: 1, physicalButton: 3, physicalButtons: 3, button: 3
dev:1192020-08-29 23:45:02.199 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:45:01.694 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:59.991 infoButton 3 was pushed
dev:1192020-08-29 23:44:59.987 infoMultistate - endpoint: 43, taps: 1, physicalButton: 3, physicalButtons: 3, button: 3
dev:1192020-08-29 23:44:59.983 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:44:59.506 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:55.351 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC008FC001000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 08, attrId: 00FC, encoding: 10, command: 0A, value: 00 | msgMap:[raw:BCFA01FCC008FC001000, dni:BCFA, endpoint:01, cluster:FCC0, size:08, attrId:00FC, encoding:10, command:0A, value:00, clusterInt:64704, attrInt:252, valueParsed:false]
dev:1192020-08-29 23:44:53.371 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:48.338 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100166100003280F052105009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100166100003280F052105009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100166100003280F052105009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100166100003280F052105009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:44:48.333 debugdirty model = lumi.switch.l3acn3, clean model=lumi.switch.l3acn3
dev:1192020-08-29 23:44:48.326 debugModel Name Received - description:read attr - raw: BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni: BCFA, endpoint: 01, cluster: 0000, size: 2C, attrId: 0005, encoding: 42, command: 0A, value: 126C756D692E7377697463682E6C3361636E33 | parseMap:[raw:BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni:BCFA, endpoint:01, cluster:0000, size:2C, attrId:0005, encoding:42, command:0A, value:lumi.switch.l3acn3, clusterInt:0, attrInt:5]
dev:1192020-08-29 23:44:47.920 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:47.595 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:47.320 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:45.269 infoButton 2 was double tapped
dev:1192020-08-29 23:44:45.265 infoButton 8 was pushed
dev:1192020-08-29 23:44:45.260 infoMultistate - endpoint: 42, taps: 2, physicalButton: 2, physicalButtons: 3, button: 8
dev:1192020-08-29 23:44:45.256 infoMultistate - description:read attr - raw: BCFA2A00120A5500210200, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:BCFA2A00120A5500210200, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:1192020-08-29 23:44:44.774 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:44.482 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:42.646 infoButton 2 was pushed
dev:1192020-08-29 23:44:42.641 infoMultistate - endpoint: 42, taps: 1, physicalButton: 2, physicalButtons: 3, button: 2
dev:1192020-08-29 23:44:42.636 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:44:42.122 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:40.225 infoButton 2 was pushed
dev:1192020-08-29 23:44:40.221 infoMultistate - endpoint: 42, taps: 1, physicalButton: 2, physicalButtons: 3, button: 2
dev:1192020-08-29 23:44:40.216 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:44:39.738 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:33.656 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC008FC001000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 08, attrId: 00FC, encoding: 10, command: 0A, value: 00 | msgMap:[raw:BCFA01FCC008FC001000, dni:BCFA, endpoint:01, cluster:FCC0, size:08, attrId:00FC, encoding:10, command:0A, value:00, clusterInt:64704, attrInt:252, valueParsed:false]
dev:1192020-08-29 23:44:31.669 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:24.372 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100165100066100003280F052105009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100165100066100003280F052105009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100165100066100003280F052105009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100165100066100003280F052105009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:44:24.368 debugdirty model = lumi.switch.l3acn3, clean model=lumi.switch.l3acn3
dev:1192020-08-29 23:44:24.363 debugModel Name Received - description:read attr - raw: BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni: BCFA, endpoint: 01, cluster: 0000, size: 2C, attrId: 0005, encoding: 42, command: 0A, value: 126C756D692E7377697463682E6C3361636E33 | parseMap:[raw:BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni:BCFA, endpoint:01, cluster:0000, size:2C, attrId:0005, encoding:42, command:0A, value:lumi.switch.l3acn3, clusterInt:0, attrInt:5]
dev:1192020-08-29 23:44:23.954 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:23.659 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:23.340 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:20.754 infoButton 1 was double tapped
dev:1192020-08-29 23:44:20.749 infoButton 7 was pushed
dev:1192020-08-29 23:44:20.745 infoMultistate - endpoint: 41, taps: 2, physicalButton: 1, physicalButtons: 3, button: 7
dev:1192020-08-29 23:44:20.740 infoMultistate - description:read attr - raw: BCFA2900120A5500210200, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:BCFA2900120A5500210200, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:1192020-08-29 23:44:20.346 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:20.042 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:18.173 infoButton 1 was pushed
dev:1192020-08-29 23:44:18.168 infoMultistate - endpoint: 41, taps: 1, physicalButton: 1, physicalButtons: 3, button: 1
dev:1192020-08-29 23:44:18.163 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:44:17.615 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:15.660 infoButton 1 was pushed
dev:1192020-08-29 23:44:15.655 infoMultistate - endpoint: 41, taps: 1, physicalButton: 1, physicalButtons: 3, button: 1
dev:1192020-08-29 23:44:15.650 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:44:15.120 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:44:05.098 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC02, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC02 | parseMap:[raw:BCFA0300061600001000F5002300FABC02, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:02BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:05.079 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC02, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC02 | parseMap:[raw:BCFA0200061600001000F5002300FABC02, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:02BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:05.070 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC02, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC02 | parseMap:[raw:BCFA0100061600001000F5002300FABC02, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:02BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:44:03.995 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100066100003280F052105009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100066100003280F052105009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100066100003280F052105009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100066100003280F052105009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:44:01.736 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA0100001C0600420A30392D32372D32303139, dni: BCFA, endpoint: 01, cluster: 0000, size: 1C, attrId: 0006, encoding: 42, command: 0A, value: 0A30392D32372D32303139 | msgMap:[raw:BCFA0100001C0600420A30392D32372D32303139, dni:BCFA, endpoint:01, cluster:0000, size:1C, attrId:0006, encoding:42, command:0A, value:09-27-2019, clusterInt:0, attrInt:6]
dev:1192020-08-29 23:43:58.713 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100066100003281E052105009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100066100003281E052105009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100066100003281E052105009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100066100003281E052105009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:43:57.901 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC02, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC02 | parseMap:[raw:BCFA0300061600001000F5002300FABC02, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:02BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:42:16.354 infoButton 3 was pushed
dev:1192020-08-29 23:42:16.350 infoMultistate - endpoint: 43, taps: 1, physicalButton: 3, physicalButtons: 3, button: 3
dev:1192020-08-29 23:42:16.346 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:42:15.872 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:42:08.587 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100066100103280F052104009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100066100103280F052104009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100066100103280F052104009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100066100103280F052104009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:42:08.582 debugdirty model = lumi.switch.l3acn3, clean model=lumi.switch.l3acn3
dev:1192020-08-29 23:42:08.577 debugModel Name Received - description:read attr - raw: BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni: BCFA, endpoint: 01, cluster: 0000, size: 2C, attrId: 0005, encoding: 42, command: 0A, value: 126C756D692E7377697463682E6C3361636E33 | parseMap:[raw:BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni:BCFA, endpoint:01, cluster:0000, size:2C, attrId:0005, encoding:42, command:0A, value:lumi.switch.l3acn3, clusterInt:0, attrInt:5]
dev:1192020-08-29 23:42:08.266 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:42:07.963 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:42:07.674 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:42:05.889 infoButton 3 was double tapped
dev:1192020-08-29 23:42:05.885 infoButton 9 was pushed
dev:1192020-08-29 23:42:05.880 infoMultistate - endpoint: 43, taps: 2, physicalButton: 3, physicalButtons: 3, button: 9
dev:1192020-08-29 23:42:05.875 infoMultistate - description:read attr - raw: BCFA2B00120A5500210200, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:BCFA2B00120A5500210200, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:1192020-08-29 23:42:05.431 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:42:05.142 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:42:03.196 infoButton 3 was pushed
dev:1192020-08-29 23:42:03.192 infoMultistate - endpoint: 43, taps: 1, physicalButton: 3, physicalButtons: 3, button: 3
dev:1192020-08-29 23:42:03.187 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:42:02.720 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:42:01.155 infoButton 3 was pushed
dev:1192020-08-29 23:42:01.150 infoMultistate - endpoint: 43, taps: 1, physicalButton: 3, physicalButtons: 3, button: 3
dev:1192020-08-29 23:42:01.145 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:42:00.647 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:57.627 infoButton 2 was pushed
dev:1192020-08-29 23:41:57.622 infoMultistate - endpoint: 42, taps: 1, physicalButton: 2, physicalButtons: 3, button: 2
dev:1192020-08-29 23:41:57.617 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:41:57.121 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:48.061 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100166100003280F052104009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100166100003280F052104009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100166100003280F052104009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100166100003280F052104009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:41:48.057 debugdirty model = lumi.switch.l3acn3, clean model=lumi.switch.l3acn3
dev:1192020-08-29 23:41:48.051 debugModel Name Received - description:read attr - raw: BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni: BCFA, endpoint: 01, cluster: 0000, size: 2C, attrId: 0005, encoding: 42, command: 0A, value: 126C756D692E7377697463682E6C3361636E33 | parseMap:[raw:BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni:BCFA, endpoint:01, cluster:0000, size:2C, attrId:0005, encoding:42, command:0A, value:lumi.switch.l3acn3, clusterInt:0, attrInt:5]
dev:1192020-08-29 23:41:47.737 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:47.415 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:47.120 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:44.938 infoButton 2 was double tapped
dev:1192020-08-29 23:41:44.934 infoButton 8 was pushed
dev:1192020-08-29 23:41:44.929 infoMultistate - endpoint: 42, taps: 2, physicalButton: 2, physicalButtons: 3, button: 8
dev:1192020-08-29 23:41:44.924 infoMultistate - description:read attr - raw: BCFA2A00120A5500210200, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:BCFA2A00120A5500210200, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:1192020-08-29 23:41:44.498 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:44.171 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:42.611 infoButton 2 was pushed
dev:1192020-08-29 23:41:42.607 infoMultistate - endpoint: 42, taps: 1, physicalButton: 2, physicalButtons: 3, button: 2
dev:1192020-08-29 23:41:42.603 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:41:42.155 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:40.052 infoButton 2 was pushed
dev:1192020-08-29 23:41:40.048 infoMultistate - endpoint: 42, taps: 1, physicalButton: 2, physicalButtons: 3, button: 2
dev:1192020-08-29 23:41:40.044 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:41:39.554 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:34.730 infoButton 1 was pushed
dev:1192020-08-29 23:41:34.726 infoMultistate - endpoint: 41, taps: 1, physicalButton: 1, physicalButtons: 3, button: 1
dev:1192020-08-29 23:41:34.722 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:41:34.243 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:17.035 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100165100066100003280F052104009A2010082119010A2191FC0B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100165100066100003280F052104009A2010082119010A2191FC0B2000 | msgMap:[raw:BCFA01FCC044F700411E64100165100066100003280F052104009A2010082119010A2191FC0B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100165100066100003280F052104009A2010082119010A2191FC0B2000, clusterInt:64704, attrInt:247]
dev:1192020-08-29 23:41:17.030 debugdirty model = lumi.switch.l3acn3, clean model=lumi.switch.l3acn3
dev:1192020-08-29 23:41:17.025 debugModel Name Received - description:read attr - raw: BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni: BCFA, endpoint: 01, cluster: 0000, size: 2C, attrId: 0005, encoding: 42, command: 0A, value: 126C756D692E7377697463682E6C3361636E33 | parseMap:[raw:BCFA0100002C050042126C756D692E7377697463682E6C3361636E33, dni:BCFA, endpoint:01, cluster:0000, size:2C, attrId:0005, encoding:42, command:0A, value:lumi.switch.l3acn3, clusterInt:0, attrInt:5]
dev:1192020-08-29 23:41:16.715 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:16.400 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:16.113 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:11.478 infoButton 1 was double tapped
dev:1192020-08-29 23:41:11.474 infoButton 7 was pushed
dev:1192020-08-29 23:41:11.470 infoMultistate - endpoint: 41, taps: 2, physicalButton: 1, physicalButtons: 3, button: 7
dev:1192020-08-29 23:41:11.466 infoMultistate - description:read attr - raw: BCFA2900120A5500210200, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:BCFA2900120A5500210200, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:1192020-08-29 23:41:11.056 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:10.775 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-08-29 23:41:08.125 infoButton 1 was pushed
dev:1192020-08-29 23:41:08.121 infoMultistate - endpoint: 41, taps: 1, physicalButton: 1, physicalButtons: 3, button: 1
dev:1192020-08-29 23:41:08.117 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:41:07.625 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-08-29 23:41:05.003 infoButton 1 was pushed
dev:1192020-08-29 23:41:04.999 infoMultistate - endpoint: 41, taps: 1, physicalButton: 1, physicalButtons: 3, button: 1
dev:1192020-08-29 23:41:04.994 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-08-29 23:41:04.440 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
It would appear to handle single, double, triple and hold for each key and on the whole everything is identified as it should be. Keys 1, 2 and 3 were correct in the logs and only multi-presses caused unhandled event warnings. They also control their respective L1, L2 and L3 relays in the order you would expect.
