Camera question (specifically V3)... should I be able to view it on Dashboard? I created a tile based on the Camera device, set it to Image template with 30 second refresh, but it's just a blank box.
The camera driver is only there for control of the device (on/off, etc), does not pull images/video. There are options to get get video but requires updating camera firmware allowing for an RSTP stream.
Is there any way to trigger the floodlight light on and off? It seems the powerstate true and false is read only and does not actually change the state of the device. It would be nice to have a virtual button that turned the floodlight lights on and off. Going into the wise app and hitting that little tiny icon is really cumbersome. The best work-around I've come up with is to have a rule at the top of the homepage for turning the light on and a rule for turning the light off. Any other ways of doing this???
Wyze is like the plague. All my devices suddenly show OFFLINE in the Wyze app and I can't get them back online. Epic fail on Wyze's end.
I plan to stay far away from their products from now on.
I have about 20 various cams, light bulbs, outlets, door locks, motion sensors - all just suddenly went OFFLINE except I can see the live camera feed, format SD cards, sync time but not upgrade firmware on the cams. Obviously this a a Wyze failure, as nothing has changed on my end network. Shame on Wyze!
I've completely reinstalled the app on 4 different devices with no luck. I've uninstalled the app and just logged in on one device with no success. I've tried to delete and reinstall devices with no luck. For all my devices to suddenly show offline is clearly beyond my settings.
I've got almost 200 zwave devices which work just fine. The Wyze cloud servers (Amazon) have the issue, meanwhile Wyze is busy releasing new products instead of investing in the reliability of the current products.
What good is a Wyze door lock if I can't operate or see it's status online from anywhere? My Schlage zwave door locks never, ever do this.
My cams show off line but I can see live feed through them, format the SD card and sync time but can't upgrade firmware because it will say device is offline. It's like all my devices are bricked.
Wyze has been no help what so ever and want me to run some program to test my network. I'll pass. I've got top end equipment that works fine with everything else and did work fine with Wyze until their cloud took a dump on me...
I now have zero confidence in wyze products. Such an epic fail on their part.
Wow, I've had issues but nothing like that...mine will occasionally show offline but like you, I can see the live feed. That's why I suggested force closing the wyze app. I starting noticing that it would say offline on my phone but not on a separate tablet. Assumed it was some kind of cache issue and a force stop usually removed the offline indicator unless there was a true network interruption.
jakelehner or jlv have you figured out any way to control the floodlight light with a virtual button? Are there any hooks to make this happen? Using a virtual button as a state sensor is useful but I need a more efficient way to turn the light on and off from my dashboard and via voice with Google Assistant.
I just installed the Wyze App and Wyze Cam drivers. All devices are connected. I'm trying to turn on a light when motion is detected and can't find the correct device in Rules to do this. I've tried switches but nothing happens. Wyze cams don't show up in motion detectors or contact switches. Has anyone of you set this up?
Hi Jake:
New to the group and Hubitat due to the WINK shut down. I have many wyze devices and would love to integrate them into HE.
I'm not at the point where I know how to add these files. I have cameras, switches, indoor and outdoor plugs, vacuum and LED and bulbs.
Richard
Since no one chimed in with a solution, I figured I’d post what I came up with. I didn’t want to have to use a cloud based solution but I had no choice. I just made a virtual color temperature light button and connected 2 applets in IFTTT to turn the floodlight on/off. Since my Flood light is set to automatic inside of the Wyze app and will turn off after 3 minutes of PIR detection I also had to make a basic rule in Hubitat > (When Flood Light turns on and stays on for 3 minutes … Turn off Floodlight) or else the dashboard button will not stay in sync in certain conditions. Hope this helps someone until the floodlight is properly integrated.
There is a lot of discussion above about using these for motion detection.
For what its worth, after that post, I did discover an endpoint to pull events from the API.
I've been testing the setup for a bit and it seems to work ok. I am still polling for data so it is never real-time motion alerts, not close enough for things like security/lighting.
I'm trying to replace my finicky IFTTT applets that enable and disable motion detection for my Wyze cameras. In the Wyze app this corresponds to the toggle under Event recording/Record an event when camera/Detects motion.
There appears to be 3 issues that are preventing the migration:
While the Set Motion Recording button yields the proper outcome from the Hubitat device page, issuing the setMotionRecording(true|false) from webCoRE appears to be a no-op: no impact on the device in Hubitat or the Wyze app and no logs for the device in Hubitat. These are the webCoRE logs:
I cannot seem to get this to work with IFTTT. On a "push" action things trigger as expected. But I cannot get motion trigger to work. This is Wyze doorbell - not a camera specifically.
Interestingly - it works with cam v3 - but not doorbell.
In webCore, when adding the action if does not show parameters by default. But you can add a boolean parameter. Click the parameters button then select boolean.
