Recently noticed that various WYZE lights were not turning on or of properly. Then outside lights started failing to turn on about every other day. App responsible for outside light shows no errors.
Looked at WyzeHub log and found that box was being overwhelmed with failed requests to refresh the token with Wyze. Tried everything to make it work including, rebooting hub, stopping and starting app, changing password on Wyze.com, which then caused errors to turn into 403 forbidden errors in the log.
I ultimately deleted and reinstalled WyzeHub and gave it the login credentials and still all I see are 403 errors in log, and app shows and error if I attempt to view devices. So, most of my lighting automation is dead.
I've found no mentions of this issue on here or on the Wyze support area, and searched but found no means to report it to them, as it seems to be a problem on their end. (when changing my password, it refused new one, though it met all restrictions except possible use of my name in it, which it didn't have. Eventually found one it would accept, so something may be wrong on their end}.
Any thoughts or help would be appreciated!!!
Error samples:
Current state of errors:
app:2292026-03-16 10:52:07.492 PM
error
[WyzeHub] Login Failed with Exception: groovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden
app:2292026-03-16 10:52:07.165 PM
info
[WyzeHub] Authenticating User...
app:2292026-03-16 10:51:38.274 PM
error
java.lang.Exception: No Auth Tokens. Reauthenticate. on line 946 (method pageSelectDevices)
app:2292026-03-16 10:51:31.715 PM
error
java.lang.Exception: No Auth Tokens. Reauthenticate. on line 946 (method pageSelectDeviceGroups)
app:2292026-03-16 10:34:40.001 PM
error
app:2292026-03-16 10:34:39.756 PM
info
app:2292026-03-16 10:34:07.886 PM
error
app:2292026-03-16 10:30:50.784 PM
error
app:2292026-03-16 10:30:41.192 PM
error
app:2292026-03-16 10:30:40.935 PM
info
app:2292026-03-16 10:25:45.091 PM
error
app:2292026-03-16 10:25:45.010 PM
info
app:2292026-03-16 10:24:58.041 PM
error
app:2292026-03-16 10:24:57.965 PM
info
Original error state:
app:332026-03-16 10:23:02.010 PM
error
java.lang.Exception: No Auth Tokens. Reauthenticate. on line 946 (method deviceEventsCallback)
app:332026-03-16 10:23:01.996 PM
debug
[WyzeHub] apiPost()
app:332026-03-16 10:23:01.937 PM
debug
[WyzeHub] refreshAccessToken()
app:332026-03-16 10:23:01.935 PM
debug
[WyzeHub] {"code":"2001","msg":"access token is error","traceId":"80354c0205e2a82589ed492de8d763b7","data":{}}
app:332026-03-16 10:23:01.934 PM
error
[WyzeHub] Access Token Invalid. Attempting to refresh token.
app:332026-03-16 10:23:01.932 PM
debug
[WyzeHub] validateApiResponse()
app:332026-03-16 10:23:01.930 PM
debug
[WyzeHub] deviceEventsCallback() for device 7C78B27D615D
app:332026-03-16 10:23:01.859 PM
debug
[WyzeHub] asyncapiPost()
app:332026-03-16 10:23:01.772 PM
debug
[WyzeHub] [mac:7C78B27D615D, model:WLPA19C, actionList:[[pid:P1507, pvalue:FF9900]]]
app:332026-03-16 10:23:01.770 PM
debug
[WyzeHub] apiRunActionList()
app:332026-03-16 10:23:01.765 PM
debug
[WyzeHub] [F1] Setting color to HEX FF9900
app:332026-03-16 10:23:01.758 PM
info
[WyzeHub] [F1] setColor() Pressed
app:332026-03-16 10:22:59.541 PM
error
app:332026-03-16 10:22:59.527 PM
debug
[WyzeHub] apiPost()
app:332026-03-16 10:22:59.467 PM
debug
app:332026-03-16 10:22:59.466 PM
debug
[WyzeHub] {"code":"2001","msg":"access token is error","traceId":"fba0261848e1ba0fdc4cdbd74c6dbd0c","data":{}}
app:332026-03-16 10:22:59.464 PM
error
app:332026-03-16 10:22:59.462 PM
debug
