Not sure there's a way. In RM you can have two triggers, but can't directly set one dimmer to the other. In WATO, you can set one dimmer to the other, but can only have one trigger.
good!
you also mentioned the setup you were using and i knew this would simplify things quite a bit for you and for other users trying the same.
i guess i could add additional triggers but then someone else is going to ask for multiple command support and soon i will be rebuilding RM.
one learns to never say never but for now going to stick with When any Attribute Then this command Otherwise that command
framework … so one of each.
sorry.
You kinda can set one dimmer to another in RM, though. That is how I do it now. (sorry for the off topic from WATO post).
Right, that works as long as the trigger/condition dimmer is changing. If you want to set dimmer 1 to dimmer 2's level when dimmer 2 is not changing, RM can't do this. My workaround was to force dimmer 2 to change by adjusting down 1%, then back up 1%, but it was hacky and there was a (short) delay between the decrement and increment, which translated to a delay in the target dimmer adjusting. @bangali's update makes this unnecessary, which simplifies things and eliminates the delay.
Edit: Necessity is the mother of invention I Guess:
Dimmer Sync A simple app to keep any number of slave dimmers in sync with a single master dimmer (ON/OFF and level). This isn't the first app I've made, but it is the first app I've shared externally (so be kind). I borrowed a lot of code and layout ideas from @Cobra and @bptworld. So thanks to both of them for that!!! Features: Parent/Child App structure Ability to pause any child apps Slave dimmer(s) turn ON/OFF when master dimmer is turned ON/OFF Slave dimmer(s) level is/are sync'ed to m…
The previously posted rule ensures the two dimmers are the same after the master one turns on.
Then this second rule always keeps them in sync as the master is changed after they are on.
OK, enough thread hijacking.
@bravenel pointed me to this thread which i had completely missed. awesome to see @bravenel released the apis for RM … i had been one of the users requesting HE make these available so other apps could use RM to run the actions.
Rule Machine API It is possible for other apps to use Rules defined in Rule Machine. This is very similar, and uses the same mechanism, as actions in Rule Machine that affect other rules. It is also possible to use Rules from an HTTP request to an endpoint. Important Update There is more up to date documentation here: Rule Machine | Hubitat Documentation Using Rule Machine from other apps First, import the RM helper class into your app: import hubitat.helper.RMUtils The List of Rules Ru…
so guess what folks? …
@bangali does WATO support REGEX for text attributes?
Example: trigger on weather attribute containing the text SNOW or RAIN?
i will add it this weekend along with support for executing RM actions.
@bangali - can WATO compare humidity on the same device?
Scenario:
- bathroom humidity at 37%; lights at 75%
- humidity goes up by 10% and motion; lights change to 100%
WATO only supports 1 trigger match check with 1 match or 1 unmatched command.
what you are looking for is rooms manager.
Rooms is too large of an app for me to use for just 1 room. . Bummer was hoping WATO could be my answer.
sounds like you should use it for more than 1 room
Alas I cannot. My WAF is stable. I am now hesitant to do updates. Lol!
I hear you
My WAF is stable
but … what if you could take that rooms automation experience to beyond stable … have it be her indispensable companion?
I joke … a little.
Yeah...I have used Rooms with ST and loved it. On HE I have not had the same loving WAF experience as I have with RM currently.
Why does the three axis data return Null? Cant figure it out. In the maker API my st multi sensor v5 is reporting three axis data. In WATO the return is null. I tried to figure it out but groovy is very bizarre to me
This app is awesome with my ApiXU Weather Driver. One thing I'm trying to do is turn on a roof snow melt system (a.k.a. Gutterglove) when it's snowing. I see there are a dozen conditions with snow in the text. I can go through and create a separate WATO child for each condition separately, but is there a way to either enter a list of values (essentially an IN statement) or have a text contains operator? Great work!
thanks for the great idea. i will see if i can add that in to WATO.
So I just stumbled upon this app and it appears that it's just what I'm looking for but I'm not sure if I'm implementing it properly because I can't get it to trigger my switch. My ultimate goal is to have it send me a notification if the weather changes to rain and the windows are open. However since it's February in New York right now, it's not too likely to rain so I simply setup a test script to insure I could get it to flip the virtual switch (Rain Alert) based on the current condition (overcast), But no matter what I do it doesn't seem to want to flip that switch to on. How often does this app poll the APIXU weather device? I've let it sit for an hour and still nothing. Help!!!
