here is what i got from bottom up as i am sure you know lol.
dev:6122020-07-27 06:58:27.123 pm debugIn parse, map is null
dev:6122020-07-27 06:58:27.120 pm debugParameter: 15 value is: 0
dev:6122020-07-27 06:58:27.117 pm debug---CONFIGURATION REPORT V1--- Thermostat sent parameterNumber:15, size:1, value:0
dev:6122020-07-27 06:58:27.113 pm debugParsing 'zw device: 38, command: 7006, payload: 0F 01 00 , isMulticast: false'
dev:6122020-07-27 06:58:27.108 pm debugParse...START
dev:6122020-07-27 06:58:24.875 pm debugIn parse, map is null
dev:6122020-07-27 06:58:24.873 pm debugParameter: 15 value is: 0
dev:6122020-07-27 06:58:24.870 pm debug---CONFIGURATION REPORT V1--- Thermostat sent parameterNumber:15, size:1, value:0
dev:6122020-07-27 06:58:24.867 pm debugParsing 'zw device: 38, command: 7006, payload: 0F 01 00 , isMulticast: false'
dev:6122020-07-27 06:58:24.865 pm debugParse...START
dev:6122020-07-27 06:58:24.710 pm debugIn parse, map is [value:44, unit:%, name:humidity]
dev:6122020-07-27 06:58:24.708 pm debugSensorMultilevelReport...END
dev:6122020-07-27 06:58:24.705 pm debugIn SensorMultilevelReport map is [value:44, unit:%, name:humidity]
dev:6122020-07-27 06:58:24.703 pm debugcmd.sensorType: 5
dev:6122020-07-27 06:58:24.700 pm debugcmd: SensorMultilevelReport(precision:0, scale:0, sensorType:5, sensorValue:[44], size:1, scaledSensorValue:44)
dev:6122020-07-27 06:58:24.698 pm debugSensorMultilevelReport V1...START
dev:6122020-07-27 06:58:24.694 pm debugParsing 'zw device: 38, command: 3105, payload: 05 01 2C , isMulticast: false'
dev:6122020-07-27 06:58:24.690 pm debugParse...START
dev:6122020-07-27 06:58:22.793 pm debugIn parse, map is null
dev:6122020-07-27 06:58:22.790 pm debugParameter: 15 value is: 0
dev:6122020-07-27 06:58:22.787 pm debug---CONFIGURATION REPORT V1--- Thermostat sent parameterNumber:15, size:1, value:0
dev:6122020-07-27 06:58:22.785 pm debugParsing 'zw device: 38, command: 7006, payload: 0F 01 00 , isMulticast: false'
dev:6122020-07-27 06:58:22.782 pm debugParse...START
dev:6122020-07-27 06:58:22.724 pm debugIn parse, map is [value:35, unit:C, displayed:true, name:heatingSetpoint]
dev:6122020-07-27 06:58:22.721 pm debugThermostatSetPointReport...END
dev:6122020-07-27 06:58:22.718 pm debugthermostatSetpoint is 35
dev:6122020-07-27 06:58:22.716 pm debugIn ThermostatSetpointReport map is [value:35, unit:C, displayed:true, name:heatingSetpoint]
dev:6122020-07-27 06:58:22.712 pm debugSetpoint Precision is 0
dev:6122020-07-27 06:58:22.710 pm debugSetpoint Scale is 1
dev:6122020-07-27 06:58:22.705 pm debugSetpoint Size is 1
dev:6122020-07-27 06:58:22.698 pm debugvalue is 35 and unit is C
dev:6122020-07-27 06:58:22.696 pm debugsetpoint requested is 35 and unit is F
dev:6122020-07-27 06:58:22.693 pm debugcmdScale is 1 before (this is the state variable), and F after
dev:6122020-07-27 06:58:22.690 pm debugThermostatSetpointReport...START
dev:6122020-07-27 06:58:22.686 pm debugParsing 'zw device: 38, command: 4303, payload: 01 09 23 , isMulticast: false'
dev:6122020-07-27 06:58:22.683 pm debugParse...START
dev:6122020-07-27 06:58:22.481 pm debugIn parse, map is [value:35, unit:C, displayed:true, name:heatingSetpoint]
dev:6122020-07-27 06:58:22.476 pm debugThermostatSetPointReport...END
dev:6122020-07-27 06:58:22.470 pm debugthermostatSetpoint is 35
dev:6122020-07-27 06:58:22.467 pm debugIn ThermostatSetpointReport map is [value:35, unit:C, displayed:true, name:heatingSetpoint]
dev:6122020-07-27 06:58:22.463 pm debugSetpoint Precision is 0
dev:6122020-07-27 06:58:22.451 pm debugSetpoint Scale is 1
dev:6122020-07-27 06:58:22.447 pm debugSetpoint Size is 1
dev:6122020-07-27 06:58:22.444 pm debugvalue is 35 and unit is C
dev:6122020-07-27 06:58:22.441 pm debugsetpoint requested is 35 and unit is F
dev:6122020-07-27 06:58:22.437 pm debugcmdScale is 1 before (this is the state variable), and F after
dev:6122020-07-27 06:58:22.433 pm debugThermostatSetpointReport...START
dev:6122020-07-27 06:58:22.429 pm debugParsing 'zw device: 38, command: 4303, payload: 01 09 23 , isMulticast: false'
dev:6122020-07-27 06:58:22.425 pm debugParse...START
dev:6122020-07-27 06:58:19.555 pm debugsetHeatingSetpoint...END
dev:6122020-07-27 06:58:19.550 pm debugsetpoint written is 18.0
dev:6122020-07-27 06:58:19.543 pm debugsetpoint requested is 18.0
dev:6122020-07-27 06:58:19.540 pm debugprecision is 0
dev:6122020-07-27 06:58:19.536 pm debuglocationScale is C
dev:6122020-07-27 06:58:19.533 pm debugstateScale is 1
dev:6122020-07-27 06:58:19.527 pm debugsetHeatingSetpoint...START
dev:6122020-07-27 06:58:13.218 pm debugdebug logging is enabled.
--- Live Log Started, waiting for events ---
