I have greatly improved on @Byrin 's OWM Air quality driver.
OWM returns information in EU format (mg/m^3) and only has the EU AQI value.
It now returns the calculated (to the best of my ability) US AQI number as well as the EU AQI (Which is provided by OWM) and detailed information in US standard units.
Please credit Byrin and myself if you modify.
OpenWeatherMap-Air Quality - Detailed
Modified from Byrin's original
0.1.5 - Added user editable lat/long, user editable tile width
0.1.4 - Added AQI tile
0.1.3 - Changed the output. Now default output is AirQuality in US format. 2022-10-04
0.1.2 - Fixed "then" statement. (I'm getting too old for this.") 2022-10-03
0.1.1 - Changed Hex value returned to have # in front. Easier to assign to a light. 2022-10-01
static String version() { return '0.1.5' }
import groovy.transform.Field
metadata {
definition (name: "OpenWeatherMap-Air Quality", namespace: "AC7SS", author: "SJ") {
capability "AirQuality"
attribute "CO", "float"
attribute "NO", "float"
attribute "NO2", "float"
attribute "O3", "float"
attribute "SO2", "float"
attribute "PM2.5", "float"
attribute "PM10", "float"
attribute "NH3", "float"
// attribute "AQI", "int"
attribute "AQIColorCode", "string"
attribute "PrimaryFactor", "string"
attribute "AlertTile", "string"
command 'pollData'
preferences {
input 'apiKey', 'text', required: true, title: 'Type OpenWeatherMap.org API Key Here', defaultValue: null
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input 'locLat', 'text', title: 'Location Latitude', defaultValue: location.latitude
input 'locLon', 'text', title: 'Location Longitude', defaultValue: location.longitude
input 'tileWidth', 'int', title: 'Tile width', defaultValue: '125'
void pollAQI() {
if( apiKey == null ) {
return
Map ParamsAQI
ParamsAQI = [
uri: 'https://api.openweathermap.org/data/2.5/air_pollution?lat=' + (String)locLat + '&lon=' + (String)locLon + '&appid=' + (String)apiKey,
timeout: 20 ]
if (logEnable) log.debug "ParamsAQI:${ParamsAQI}"
asynchttpGet('pollAQIHandler', ParamsAQI)
void pollAQIHandler(resp, data) {
if(resp.getStatus() == 200 || resp.getStatus() == 207) {
Map aqi = parseJson(resp.data)
if(aqi.toString()==sNULL) {
pauseExecution(30000) //5 minute pause
pollAQI()
return
def name = 'airQualityIndex'
def value = aqi.list[0].main.aqi
def descriptionText = "${device.displayName} ${name} is ${value}"
// if (txtEnable) log.info "${descriptionText}"
// sendEvent(name: name,value: value,descriptionText: descriptionText,unit: unit)
// Here begins my modification (SJ)
def int aQItemp =0
def int aQI = 0
def aQIfactor = "none"
name = 'CO'
value = aqi.list[0].components.co
def convertedVal = Math.round(value/114.5)/10
if (convertedVal<4.5){
aQItemp = (50/4.4)*(convertedVal)
}else if (convertedVal<9.5){
aQItemp = (49/4.9)*(convertedVal-4.5)+51
}else if (convertedVal<12.5){
aQItemp = (49/2.9)*(convertedVal-9.5)+101
}else if (convertedVal<15.5){
aQItemp = (49/2.9)*(convertedVal-12.5)+151
}else if (convertedVal<30.5){
aQItemp = (99/14.9)*(convertedVal-15.5)+201
}else if (convertedVal<40.5){
aQItemp = (99/9.9)*(convertedVal-30.5)+301
}else {
aQItemp = (99/9.9)*(convertedVal-40.5)+401
aQI=aQItemp
aQIfactor = name
descriptionText = "${device.displayName} ${name} is ${convertedVal} AQI ${aQItemp}"
sendEvent(name: name,value: convertedVal,descriptionText: descriptionText,unit: "ppm")
name = 'NO2'
value = aqi.list[0].components.no2
convertedVal = Math.round(value/1.88)
if (convertedVal<54){
aQItemp = (50/53)*(convertedVal)
}else if (convertedVal<101){
aQItemp = (49/46)*(convertedVal-54)+51
}else if (convertedVal<361){
aQItemp = (49/259)*(convertedVal-101)+101
}else if (convertedVal<650){
aQItemp = (49/288)*(convertedVal-361)+151
}else if (convertedVal<1250){
aQItemp = (99/599)*(convertedVal-650)+201
}else if (convertedVal<1650){
aQItemp = (99/399)*(convertedVal-1250)+301
}else {
aQItemp = (99/399)*(convertedVal-1650)+401
if (aQItemp>aQI){
aQI=aQItemp
aQIfactor = name
sendEvent(name: name,value: convertedVal,descriptionText: descriptionText,unit: "ppb")
name = 'O3'
value = aqi.list[0].components.o3
convertedVal = Math.round(value/2)/1000
if (convertedVal<0.055){
aQItemp = (50/0.054)*(convertedVal)
}else if (convertedVal<0.071){
aQItemp = (49/0.15)*(convertedVal-0.054)+51
}else if (convertedVal<0.165){
aQItemp = (49/0.093)*(convertedVal-0.071)+101
}else if (convertedVal<0.205){
aQItemp = (49/0.039)*(convertedVal-0.165)+151
}else if (convertedVal<0.405){
aQItemp = (99/0.199)*(convertedVal-0.205)+201
}else if (convertedVal<0.505){
aQItemp = (99/0.099)*(convertedVal-0.405)+301
}else {
aQItemp = (99/0.099)*(convertedVal-0.505)+401
if (aQItemp>aQI){
aQI=aQItemp
aQIfactor = name
name = 'SO2'
value = aqi.list[0].components.so2
convertedVal = Math.round(value/2.62)
if (convertedVal<36){
aQItemp = (50/35)*(convertedVal)
}else if (convertedVal<76){
aQItemp = (49/39)*(convertedVal-36)+51
}else if (convertedVal<186){
aQItemp = (49/109)*(convertedVal-76)+101
}else if (convertedVal<305){
aQItemp = (49/118)*(convertedVal-186)+151
}else if (convertedVal<605){
aQItemp = (99/299)*(convertedVal-305)+201
}else if (convertedVal<805){
aQItemp = (99/199)*(convertedVal-605)+301
}else {
aQItemp = (99/199)*(convertedVal-805)+401
if (aQItemp>aQI){
aQI=aQItemp
aQIfactor = name
name = 'PM2.5'
value = Math.round(aqi.list[0].components.pm2_5*10)/10
convertedVal = value
if (convertedVal<12.1){
aQItemp = (50/12.0)*(convertedVal)
}else if (convertedVal<35.5){
aQItemp = (49/23.3)*(convertedVal-12.1)+51
}else if (convertedVal<55.5){
aQItemp = (49/19.9)*(convertedVal-35.5)+101
}else if (convertedVal<150.5){
aQItemp = (49/94.9)*(convertedVal-55.5)+151
}else if (convertedVal<250.5){
aQItemp = (99/99.9)*(convertedVal-150.5)+201
}else if (convertedVal<350.5){
aQItemp = (99/99.9)*(convertedVal-250.5)+301
}else {
aQItemp = (99/149.9)*(convertedVal-350.5)+401
if (aQItemp>aQI){
aQI=aQItemp
aQIfactor = name
sendEvent(name: name,value: value,descriptionText: descriptionText,unit: "mg/m^3")
name = 'PM10'
value = Math.round(aqi.list[0].components.pm10)
if (convertedVal<55){
aQItemp = (50/54)*(convertedVal)
}else if (convertedVal<155){
aQItemp = (49/99)*(convertedVal-55)+51
}else if (convertedVal<255){
aQItemp = (49/99)*(convertedVal-155)+101
}else if (convertedVal<355){
aQItemp = (49/99)*(convertedVal-255)+151
}else if (convertedVal<425){
aQItemp = (99/69)*(convertedVal-355)+201
}else if (convertedVal<505){
aQItemp = (99/79)*(convertedVal-425)+301
}else {
aQItemp = (99/99)*(convertedVal-505)+401
if (aQItemp>aQI){
aQI=aQItemp
aQIfactor = name
// def value = aqi.list[0].main.aqi
// def descriptionText = "${device.displayName} ${name} is ${value}"
// name = 'AQI'
descriptionText = "${device.displayName} ${name} is ${aQI} Condition is ${aQIfactor}"
sendEvent(name: name,value: aQI,descriptionText: 'US AQI',unit: aQIfactor)
name = 'PrimaryFactor'
descriptionText = "${device.displayName} ${name} is ${aQIfactor}"
sendEvent(name: name,value: aQIfactor,descriptionText: 'AQI Factor',unit: unit)
name = 'AQIColorCode'
def aQIcolor = "#7E0023"
// def aQIText = ""
if (aQI>1&&aQI<51) {
aQIcolor = '#00E400'
}else if (aQI<101&&aQI>50) {
aQIcolor = '#FFFF00'
}else if (aQI<151&&aQI>100) {
aQIcolor = '#FF7E00'
}else if (aQI<201&&aQI>150) {
aQIcolor = '#FF0000'
}else if (aQI<301&&aQI>200) {
aQIcolor = '#8F3F97'
descriptionText = "${device.displayName} ${name} is ${aQIcolor}"
sendEvent(name: 'AQIColorCode',value: aQIcolor ,descriptionText: 'US AQI Color Code',unit: "RGB")
// th{padding: 10px;}
String aTile
aTile = '<style>h3 {text-align: center;font-size:250%;color:Black;}p {text-align: center;font-size:100%;color:Black;}</style><table width = '
aTile += tileWidth
aTile +=' height = 70 align = "center" style="background-color:'
aTile += aQIcolor
aTile += '"><tr><th><h3>'
aTile += aQI
aTile += '</th></tr><tr><td><p>'
aTile += aQIfactor
aTile += '</td></tr></table>'
descriptionText = "${device.displayName} Tile is ${aTile}"
sendEvent(name: 'AlertTile', value: aTile )
void refresh() {
void installed() {
schedule("0 0/30 * 1/1 * ? *", pollAQI) //every half hour
void uninstalled() {
unschedule()
void pollData() {
pollAQI()
It's a little late for smoke season, but in time for next year!
