[RELEASE] Tuya Zigbee Valve driver (w/ healthStatus)
Here's what I gathered from the device data and logs:
Data:
  • endpointId: 01
  • application: 48
  • manufacturer: _TZE200_akjefhj5
  • model: TS0601
Logs from "Configure"
dev:11222023-01-20 00:11:51.528debugFaucet parseZHAcommand writeAttributeResponse cluster: E001 status:86
dev:11222023-01-20 00:11:51.525debugFaucet Desc Map: [raw:catchall: 0104 E001 01 01 0040 00 62D8 00 00 0000 04 01 8610D0, profileId:0104, clusterId:E001, clusterInt:57345, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 10, D0]]
dev:11222023-01-20 00:11:51.519debugFaucet description is catchall: 0104 E001 01 01 0040 00 62D8 00 00 0000 04 01 8610D0
dev:11222023-01-20 00:11:49.976warnFaucet Switch state is not supported -> Switch polling will be disabled.
dev:11222023-01-20 00:11:49.973debugFaucet Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 62D8 00 00 0000 0B 01 0682, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[06, 82]]
dev:11222023-01-20 00:11:49.966debugFaucet description is catchall: 0104 0006 01 01 0040 00 62D8 00 00 0000 0B 01 0682
dev:11222023-01-20 00:11:48.469infoFaucet Received bind response, data=[DE, 00] (Sequence Number:DE, Status: Success)
dev:11222023-01-20 00:11:48.466debugFaucet Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 62D8 00 00 0000 00 00 DE00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:62D8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DE, 00]]
dev:11222023-01-20 00:11:48.459debugFaucet description is catchall: 0000 8021 00 00 0040 00 62D8 00 00 0000 00 00 DE00
dev:11222023-01-20 00:11:46.988debugFaucet Model is : TS0601
dev:11222023-01-20 00:11:46.985debugFaucet Tuya check-in message (attribute 0001 reported: 48)
dev:11222023-01-20 00:11:46.981debugFaucet zclVersion is : 03
dev:11222023-01-20 00:11:46.978debugFaucet Manufacturer is : _TZE200_akjefhj5
dev:11222023-01-20 00:11:46.975debugFaucet Desc Map: [raw:62D801000068040042105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000, dni:62D8, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_akjefhj5, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:11222023-01-20 00:11:46.964warnexception caught while parsing description: read attr - raw: 62D801000068040042105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000, dni: 62D8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000
dev:11222023-01-20 00:11:46.953debugFaucet description is read attr - raw: 62D801000068040042105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000, dni: 62D8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000
dev:11222023-01-20 00:11:46.792debugFaucet sendZigbeeCommands (cmd=[he raw 0x62D8 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, zdo bind 0x62D8 0x01 0x01 6 {94DEB8FFFEB0F7B3} {}, delay 2000, he cr 0x62D8 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x62D8 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:11222023-01-20 00:11:46.787debugFaucet setting powerOnBehaviour to last state (2)
dev:11222023-01-20 00:11:46.757traceFaucet polling..
dev:11222023-01-20 00:11:46.754debugFaucet sending refresh() command...
dev:11222023-01-20 00:11:46.748infoFaucet configure()..
dev:11222023-01-20 00:11:20.918infoFaucet Countdown (07) is: 75
dev:11222023-01-20 00:11:20.915traceFaucet Tuya cluster cmd=07 value=75 ()
dev:11222023-01-20 00:11:20.900debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 0025070200040000004B, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 25, 07, 02, 00, 04, 00, 00, 00, 4B]]
dev:11222023-01-20 00:11:20.890debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 0025070200040000004B
Logs from "Open"
dev:11222023-01-20 00:13:18.901warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00290B0200040000021C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 29, 0B, 02, 00, 04, 00, 00, 02, 1C]]
dev:11222023-01-20 00:13:18.898warnTuya unknown attribute: 0029=0B=0200 data.size() = 10 value: 540}
dev:11222023-01-20 00:13:18.895traceFaucet Tuya cluster cmd=0B value=540 ()
dev:11222023-01-20 00:13:18.892debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00290B0200040000021C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 29, 0B, 02, 00, 04, 00, 00, 02, 1C]]
dev:11222023-01-20 00:13:18.883debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00290B0200040000021C
dev:11222023-01-20 00:13:06.090warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00280B02000400000258, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 28, 0B, 02, 00, 04, 00, 00, 02, 58]]
dev:11222023-01-20 00:13:06.087warnTuya unknown attribute: 0028=0B=0200 data.size() = 10 value: 600}
dev:11222023-01-20 00:13:06.084traceFaucet Tuya cluster cmd=0B value=600 ()
dev:11222023-01-20 00:13:06.081debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00280B02000400000258, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 28, 0B, 02, 00, 04, 00, 00, 02, 58]]
dev:11222023-01-20 00:13:06.074debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00280B02000400000258
dev:11222023-01-20 00:13:05.974warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00270C04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 27, 0C, 04, 00, 01, 01]]
dev:11222023-01-20 00:13:05.971warnTuya unknown attribute: 0027=0C=0400 data.size() = 7 value: 1}
dev:11222023-01-20 00:13:05.968traceFaucet Tuya cluster cmd=0C value=1 ()
dev:11222023-01-20 00:13:05.965debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00270C04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 27, 0C, 04, 00, 01, 01]]
dev:11222023-01-20 00:13:05.958debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00270C04000101
dev:11222023-01-20 00:13:05.900infoFaucet Faucet is open [digital]
dev:11222023-01-20 00:13:05.868debugFaucet Valve state changed from closed to open
dev:11222023-01-20 00:13:05.863traceFaucet Tuya cluster cmd=01 value=1 ()
dev:11222023-01-20 00:13:05.859debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00260101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 26, 01, 01, 00, 01, 01]]
dev:11222023-01-20 00:13:05.852debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 00260101000101
dev:11222023-01-20 00:13:05.842debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:11222023-01-20 00:13:05.836debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 00 00 0000 0B 01 0000
dev:11222023-01-20 00:13:04.589debugFaucet sendZigbeeCommands (cmd=[he cmd 0x62D8 0x01 0xEF00 0x00 {000F0101000101} {}, delay 200])
dev:11222023-01-20 00:13:04.557traceFaucet sendTuyaCommand = [he cmd 0x62D8 0x01 0xEF00 0x00 {000F0101000101} {}, delay 200]
dev:11222023-01-20 00:13:04.550debugFaucet opening
Lots from "Close"
dev:11222023-01-20 00:14:39.469warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002F0C04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2F, 0C, 04, 00, 01, 02]]
dev:11222023-01-20 00:14:39.466warnTuya unknown attribute: 002F=0C=0400 data.size() = 7 value: 2}
dev:11222023-01-20 00:14:39.414traceFaucet Tuya cluster cmd=0C value=2 ()
dev:11222023-01-20 00:14:39.411debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002F0C04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2F, 0C, 04, 00, 01, 02]]
dev:11222023-01-20 00:14:39.404debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002F0C04000102
dev:11222023-01-20 00:14:39.304warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002E0502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2E, 05, 02, 00, 04, 00, 00, 00, 00]]
dev:11222023-01-20 00:14:39.301warnTuya unknown attribute: 002E=05=0200 data.size() = 10 value: 0}
dev:11222023-01-20 00:14:39.298traceFaucet Tuya cluster cmd=05 value=0 ()
dev:11222023-01-20 00:14:39.295debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002E0502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2E, 05, 02, 00, 04, 00, 00, 00, 00]]
dev:11222023-01-20 00:14:39.288debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002E0502000400000000
dev:11222023-01-20 00:14:39.176warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002D0602000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2D, 06, 02, 00, 04, 00, 00, 00, 00]]
dev:11222023-01-20 00:14:39.172warnTuya unknown attribute: 002D=06=0200 data.size() = 10 value: 0}
dev:11222023-01-20 00:14:39.169traceFaucet Tuya cluster cmd=06 value=0 ()
dev:11222023-01-20 00:14:39.166debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002D0602000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2D, 06, 02, 00, 04, 00, 00, 00, 00]]
dev:11222023-01-20 00:14:39.159debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002D0602000400000000
dev:11222023-01-20 00:14:39.061warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002C0F02000400000078, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2C, 0F, 02, 00, 04, 00, 00, 00, 78]]
dev:11222023-01-20 00:14:39.057warnTuya unknown attribute: 002C=0F=0200 data.size() = 10 value: 120}
dev:11222023-01-20 00:14:39.054traceFaucet Tuya cluster cmd=0F value=120 ()
dev:11222023-01-20 00:14:39.051debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002C0F02000400000078, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2C, 0F, 02, 00, 04, 00, 00, 00, 78]]
dev:11222023-01-20 00:14:39.044debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002C0F02000400000078
dev:11222023-01-20 00:14:38.949infoFaucet Faucet is closed [digital]
dev:11222023-01-20 00:14:38.922debugFaucet Valve state changed from open to closed
dev:11222023-01-20 00:14:38.919traceFaucet Tuya cluster cmd=01 value=0 ()
dev:11222023-01-20 00:14:38.916debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002B0101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2B, 01, 01, 00, 01, 00]]
dev:11222023-01-20 00:14:38.909debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002B0101000100
dev:11222023-01-20 00:14:38.865debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:11222023-01-20 00:14:38.852debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 00 00 0000 0B 01 0000
dev:11222023-01-20 00:14:38.708debugFaucet sendZigbeeCommands (cmd=[he cmd 0x62D8 0x01 0xEF00 0x00 {00100101000100} {}, delay 200])
dev:11222023-01-20 00:14:38.678traceFaucet sendTuyaCommand = [he cmd 0x62D8 0x01 0xEF00 0x00 {00100101000100} {}, delay 200]
dev:11222023-01-20 00:14:38.663debugFaucet closing
dev:11222023-01-20 00:14:18.840warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002A0B020004000001E0, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2A, 0B, 02, 00, 04, 00, 00, 01, E0]]
dev:11222023-01-20 00:14:18.837warnTuya unknown attribute: 002A=0B=0200 data.size() = 10 value: 480}
dev:11222023-01-20 00:14:18.834traceFaucet Tuya cluster cmd=0B value=480 ()
dev:11222023-01-20 00:14:18.831debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002A0B020004000001E0, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:62D8, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2A, 0B, 02, 00, 04, 00, 00, 01, E0]]
dev:11222023-01-20 00:14:18.824debugFaucet description is catchall: 0104 EF00 01 01 0040 00 62D8 01 00 0000 01 01 002A0B020004000001E0
Thank you, I have now all the data that I need. WIll check what can be done for this device during the weekend.
I fear that is the case, working similar to a solenoid valve setup I have for another project (coffee reservoir fill). The valves are open only when power is applied and closed when no power is available. However, this "anti freeze" feature seems to imply they designed it to stay open for longer periods, but the wording and actual way it works (or doesn't work) are a mystery to me.
Let me know if I can provide anything more. Fingers crossed there's some way I could have it stay on without battery drain. It's easily the cheapest (by price) device of this kind I've seen so far. The actual valve is a lot sturdier looking when in hand than the pictures on Amazon imply.
Can you test again using the development branch version 1.0.5 (the link from the second post, or use the Import button within HE driver editor).
Make sure the Debug logs are on. Please remove the batteries for 1 minute, then insert the batteries again and send me the logs that follow the power on cycle. You can use the forum editor cog wheel tool to hide the long logs.
Here's the log after removing batteries, waiting a few minutes, then putting them back in.:
Summary
dev:11262023-01-22 22:14:35.398infoFaucet timer time left (0B) is: 60 seconds
dev:11262023-01-22 22:14:35.396traceFaucet Tuya cluster cmd=0B value=60 ()
dev:11262023-01-22 22:14:35.393debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00120B0200040000003C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 12, 0B, 02, 00, 04, 00, 00, 00, 3C]]
dev:11262023-01-22 22:14:35.388debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00120B0200040000003C
dev:11262023-01-22 22:14:35.310debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:11262023-01-22 22:14:35.306debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 0000
dev:11262023-01-22 22:14:34.026debugFaucet sendZigbeeCommands (cmd=[he cmd 0x6F6D 0x01 0xEF00 0x00 {00030B0200040000003C} {}, delay 200])
dev:11262023-01-22 22:14:34.024traceFaucet sendTuyaCommand = [he cmd 0x6F6D 0x01 0xEF00 0x00 {00030B0200040000003C} {}, delay 200]
dev:11262023-01-22 22:14:34.018debugFaucet setting the irrigation timer to 60 seconds
dev:11262023-01-22 22:14:32.280debugFaucet parseZHAcommand writeAttributeResponse cluster: E001 status:86
dev:11262023-01-22 22:14:32.277debugFaucet Desc Map: [raw:catchall: 0104 E001 01 01 0040 00 6F6D 00 00 0000 04 01 8610D0, profileId:0104, clusterId:E001, clusterInt:57345, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 10, D0]]
dev:11262023-01-22 22:14:32.272debugFaucet description is catchall: 0104 E001 01 01 0040 00 6F6D 00 00 0000 04 01 8610D0
dev:11262023-01-22 22:14:29.260warnFaucet standard ZCL Switch state is not supported.
dev:11262023-01-22 22:14:29.257debugFaucet Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 6F6D 00 00 0000 0B 01 0682, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[06, 82]]
dev:11262023-01-22 22:14:29.252debugFaucet description is catchall: 0104 0006 01 01 0040 00 6F6D 00 00 0000 0B 01 0682
dev:11262023-01-22 22:14:28.120traceFaucet polling..
dev:11262023-01-22 22:14:28.119debugFaucet sending refresh() command...
dev:11262023-01-22 22:14:27.828infoFaucet Received bind response, data=[20, 00] (Sequence Number:20, Status: Success)
dev:11262023-01-22 22:14:27.825debugFaucet Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 6F6D 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:11262023-01-22 22:14:27.820debugFaucet description is catchall: 0000 8021 00 00 0040 00 6F6D 00 00 0000 00 00 2000
dev:11262023-01-22 22:14:27.813debugFaucet Model is : TS0601
dev:11262023-01-22 22:14:27.811debugFaucet Tuya check-in message (attribute 0001 reported: 48)
dev:11262023-01-22 22:14:27.810debugFaucet zclVersion is : 03
dev:11262023-01-22 22:14:27.808debugFaucet Manufacturer is : _TZE200_akjefhj5
dev:11262023-01-22 22:14:27.803debugFaucet Desc Map: [raw:6F6D01000068040042105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000, dni:6F6D, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_akjefhj5, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:11262023-01-22 22:14:27.796warnexception caught while parsing description: read attr - raw: 6F6D01000068040042105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000, dni: 6F6D, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000
dev:11262023-01-22 22:14:27.785debugFaucet description is read attr - raw: 6F6D01000068040042105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000, dni: 6F6D, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F616B6A6566686A350000002003010000204805000042065453303630310700003003FEFF003000
dev:11262023-01-22 22:14:26.509debugFaucet sendZigbeeCommands (cmd=[he raw 0x6F6D 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, zdo bind 0x6F6D 0x01 0x01 6 {94DEB8FFFEB0F7B3} {}, delay 2000, he cr 0x6F6D 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x6F6D 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:11262023-01-22 22:14:26.504debugFaucet setting powerOnBehaviour to last state (2)
dev:11262023-01-22 22:14:26.466traceFaucet polling..
dev:11262023-01-22 22:14:26.465debugFaucet sending refresh() command...
dev:11262023-01-22 22:14:26.456infoFaucet configure()..
dev:11262023-01-22 22:14:24.479infoFaucet timer_state (work state) (0C) is: enabled (off) (2)
dev:11262023-01-22 22:14:24.477traceFaucet Tuya cluster cmd=0C value=2 ()
dev:11262023-01-22 22:14:24.474debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00110C04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 11, 0C, 04, 00, 01, 02]]
dev:11262023-01-22 22:14:24.469debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00110C04000102
dev:11262023-01-22 22:14:24.365infoFaucet SASWELL measuredValue (dp=05) is: 0 (data=[00, 10, 05, 02, 00, 04, 00, 00, 00, 00])
dev:11262023-01-22 22:14:24.363traceFaucet Tuya cluster cmd=05 value=0 ()
dev:11262023-01-22 22:14:24.359debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00100502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 10, 05, 02, 00, 04, 00, 00, 00, 00]]
dev:11262023-01-22 22:14:24.354debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00100502000400000000
dev:11262023-01-22 22:14:24.238warnmap= [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000F0602000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0F, 06, 02, 00, 04, 00, 00, 00, 00]]
dev:11262023-01-22 22:14:24.237warnTuya unknown attribute: 000F=06=0200 data.size() = 10 value: 0}
dev:11262023-01-22 22:14:24.234traceFaucet Tuya cluster cmd=06 value=0 ()
dev:11262023-01-22 22:14:24.231debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000F0602000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0F, 06, 02, 00, 04, 00, 00, 00, 00]]
dev:11262023-01-22 22:14:24.226debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000F0602000400000000
dev:11262023-01-22 22:14:24.145infoFaucet last valve open duration (0F) is: 0 seconds
dev:11262023-01-22 22:14:24.143traceFaucet Tuya cluster cmd=0F value=0 ()
dev:11262023-01-22 22:14:24.115debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000E0F02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0E, 0F, 02, 00, 04, 00, 00, 00, 00]]
dev:11262023-01-22 22:14:24.110debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000E0F02000400000000
dev:11262023-01-22 22:14:24.029infoFaucet Faucet is closed [digital]
dev:11262023-01-22 22:14:23.984debugFaucet Valve state changed from open to closed
dev:11262023-01-22 22:14:23.982traceFaucet Tuya cluster cmd=01 value=0 ()
dev:11262023-01-22 22:14:23.979debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000D0101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0D, 01, 01, 00, 01, 00]]
dev:11262023-01-22 22:14:23.974debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000D0101000100
dev:11262023-01-22 22:14:23.937debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:11262023-01-22 22:14:23.932debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 0000
dev:11262023-01-22 22:14:22.556debugFaucet sendZigbeeCommands (cmd=[he cmd 0x6F6D 0x01 0xEF00 0x00 {00020101000100} {}, delay 200])
dev:11262023-01-22 22:14:22.481traceFaucet sendTuyaCommand = [he cmd 0x6F6D 0x01 0xEF00 0x00 {00020101000100} {}, delay 200]
dev:11262023-01-22 22:14:22.476debugFaucet closing
dev:11262023-01-22 22:14:20.477infoFaucet timer time left (0B) is: 600 seconds
dev:11262023-01-22 22:14:20.475traceFaucet Tuya cluster cmd=0B value=600 ()
dev:11262023-01-22 22:14:20.472debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000C0B02000400000258, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0C, 0B, 02, 00, 04, 00, 00, 02, 58]]
dev:11262023-01-22 22:14:20.466debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000C0B02000400000258
dev:11262023-01-22 22:14:20.386infoFaucet timer_state (work state) (0C) is: active (on) (1)
dev:11262023-01-22 22:14:20.384traceFaucet Tuya cluster cmd=0C value=1 ()
dev:11262023-01-22 22:14:20.380debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000B0C04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0B, 0C, 04, 00, 01, 01]]
dev:11262023-01-22 22:14:20.375debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000B0C04000101
dev:11262023-01-22 22:14:20.283infoFaucet Faucet is open [digital]
dev:11262023-01-22 22:14:20.230debugFaucet Valve state changed from closed to open
dev:11262023-01-22 22:14:20.228traceFaucet Tuya cluster cmd=01 value=1 ()
dev:11262023-01-22 22:14:20.224debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000A0101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0A, 01, 01, 00, 01, 01]]
dev:11262023-01-22 22:14:20.219debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 000A0101000101
dev:11262023-01-22 22:14:20.164debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:11262023-01-22 22:14:20.159debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 0000
dev:11262023-01-22 22:14:19.786debugFaucet sendZigbeeCommands (cmd=[he cmd 0x6F6D 0x01 0xEF00 0x00 {00010101000101} {}, delay 200])
dev:11262023-01-22 22:14:19.750traceFaucet sendTuyaCommand = [he cmd 0x6F6D 0x01 0xEF00 0x00 {00010101000101} {}, delay 200]
dev:11262023-01-22 22:14:19.743debugFaucet opening
dev:11262023-01-22 22:13:37.399infoFaucet Tuya specific command: cluster=EF00 command=11 data=[00, 06, 40]
dev:11262023-01-22 22:13:37.395debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 11 01 000640, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 06, 40]]
dev:11262023-01-22 22:13:37.390debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 11 01 000640
dev:11262023-01-22 22:13:17.303debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:11262023-01-22 22:13:17.299debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 2400
dev:11262023-01-22 22:13:17.199debugFaucet sending time data : [he cmd 0x6F6D 0x01 0xEF00 0x24 {000863CDFB4D63CDB4FD}, delay 2000]
dev:11262023-01-22 22:13:17.198traceFaucet now is: 1674443597197
dev:11262023-01-22 22:13:17.192debugFaucet time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 24 01 0005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 05]]
dev:11262023-01-22 22:13:17.189debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 24 01 0005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 05]]
dev:11262023-01-22 22:13:17.184debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 24 01 0005
dev:11262023-01-22 22:13:13.744debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:11262023-01-22 22:13:13.739debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 00 00 0000 0B 01 2400
dev:11262023-01-22 22:13:13.394debugFaucet sending time data : [he cmd 0x6F6D 0x01 0xEF00 0x24 {000863CDFB4963CDB4F9}, delay 2000]
dev:11262023-01-22 22:13:13.392traceFaucet now is: 1674443593392
dev:11262023-01-22 22:13:13.384debugFaucet time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 24 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 00]]
dev:11262023-01-22 22:13:13.380debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 24 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 00]]
dev:11262023-01-22 22:13:13.375debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 24 01 0000
dev:11262023-01-22 22:13:13.274infoFaucet SASWELL RawToCycleTimer2 (11) is: 0
dev:11262023-01-22 22:13:13.272traceFaucet Tuya cluster cmd=11 value=0 ()
dev:11262023-01-22 22:13:13.268debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00081100000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 08, 11, 00, 00, 01, 00]]
dev:11262023-01-22 22:13:13.263debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00081100000100
dev:11262023-01-22 22:13:13.156infoFaucet SASWELL RawToCycleTimer1 (10) is: 0
dev:11262023-01-22 22:13:13.154traceFaucet Tuya cluster cmd=10 value=0 ()
dev:11262023-01-22 22:13:13.150debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00071000000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 07, 10, 00, 00, 01, 00]]
dev:11262023-01-22 22:13:13.144debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00071000000100
dev:11262023-01-22 22:13:13.020infoFaucet battery (07) is: 75 %
dev:11262023-01-22 22:13:13.018traceFaucet Tuya cluster cmd=07 value=75 ()
dev:11262023-01-22 22:13:13.014debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 0006070200040000004B, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 06, 07, 02, 00, 04, 00, 00, 00, 4B]]
dev:11262023-01-22 22:13:13.009debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 0006070200040000004B
dev:11262023-01-22 22:13:12.905infoFaucet timer_state (work state) (0C) is: enabled (off) (2)
dev:11262023-01-22 22:13:12.899traceFaucet Tuya cluster cmd=0C value=2 ()
dev:11262023-01-22 22:13:12.894debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00050C04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 05, 0C, 04, 00, 01, 02]]
dev:11262023-01-22 22:13:12.889debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00050C04000102
dev:11262023-01-22 22:13:12.799debugFaucet Ignored duplicated switch event for model TS0601
dev:11262023-01-22 22:13:12.793traceFaucet Tuya cluster cmd=01 value=0 ()
dev:11262023-01-22 22:13:12.767debugFaucet Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00040101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6F6D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 04, 01, 01, 00, 01, 00]]
dev:11262023-01-22 22:13:12.762debugFaucet description is catchall: 0104 EF00 01 01 0040 00 6F6D 01 00 0000 01 01 00040101000100
dev:11262023-01-22 22:13:12.157debugFaucet Tuya specific attribute FFE4 reported: 01
dev:11262023-01-22 22:13:12.156debugFaucet Tuya specific attribute FFE2 reported: 1F
dev:11262023-01-22 22:13:12.154debugFaucet Tuya check-in message (attribute 0001 reported: 48)
dev:11262023-01-22 22:13:12.145debugFaucet Desc Map: [raw:6F6D0100001801002048E2FF201FE4FF2001, dni:6F6D, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:01, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:11262023-01-22 22:13:12.135debugFaucet description is read attr - raw: 6F6D0100001801002048E2FF201FE4FF2001, dni: 6F6D, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 48E2FF201FE4FF2001
dev:11262023-01-22 22:13:06.953infoFaucet Received device announcement, data=[81, 6D, 6F, B3, F7, B0, FE, FF, B8, DE, 94, 80] (Sequence Number:81, Device network ID: 6F6D, Capability Information: 80)
dev:11262023-01-22 22:13:06.942debugFaucet Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 6F6D 00 00 0000 00 00 816D6FB3F7B0FEFFB8DE9480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6F6D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[81, 6D, 6F, B3, F7, B0, FE, FF, B8, DE, 94, 80]]
dev:11262023-01-22 22:13:06.935debugFaucet description is catchall: 0000 0013 00 00 0040 00 6F6D 00 00 0000 00 00 816D6FB3F7B0FEFFB8DE9480
I will already say, thank you for being so prompt on this. I see the battery percentage from the new version of the driver and some setting it appears can be used to set the amount of time the device will stay on. I'm not sure if there's a way to specify "infinite" though, or if leaving it on has any undesired effects (battery drain, burn the valve out, etc.).
I do see this "timer state" that could maybe be set to be disabled to leave the valve set to on indefinitely? Let me know if you can glean anything on that part from the logs, or if you need me to experiment further and provide more logs. Thank you so much!
Version 1.1.0 was pushed for update via HPM.
Contains all the changes for SASWELL Irrigation Timer and the new healthCheck attribute. Currently, the offline status will be reported after 12 hours without any data received from the valve.
Does anyone know if this valve actuator will work on Hubitat?
Tuya Smart Zigbee Water Valve Actuator WiFi Gas Valve Controller Fit DN15 DN20 DN25 DN32 Pipe Support Alexa Google Yandex Alice
https://a.aliexpress.com/_m0Rkkqq
Actually I'm going to use it to control a small gate (open/close).
With Tuya devices you never know... But I think there is a very good chance for success, this valve looks like the model that is supported in this driver.
So i just got the sprinkler/water irrigation valve. Listed as _TZE200_sh1btabb.
Paired with no issues. Driver works great to open and close, BUT it will only stay open for 60 seconds, then automatically close.
Ive deleted and repaired. Same result.
Ive set the drivers irrigation timer to 300 seconds and the logs show "setting the irrigation timer to 300 seconds". But it doesnt seem to take. It will still close after 60 seconds.
Any ideas? Is there a trick to getting the irrigation timer to actually set?
Is there water running through it? It senses how much water is flowing through it. I thought it shut off if there was no flow for a minute.
Actually no. Just was bench testing it. Never thought about it shutting off with no flow.
I'll get it hooked up and test again sometime today.
On the note of it sensing flow, @kkossev any way to display that?
I am not aware if this model can sense whether there is a water flow or not... Is this mentioned anywhere in the leaflet that usually comes with the device?
Mine shows flow in the logs. I’ll try to hook it up to a faucet today and see what it says
I believe it was, but naturally, I cant find the leaflet now.
Here are the logs showing "WaterConsumed".
Just included the "info" logs. Will get the full debug logs if requested.
Summary
2023-02-08 09:46:38.729 AM[info]Tuya Battery (6C) is: 100
2023-02-08 09:46:35.277 AM[info]Tuya IrrigationStartTime (65) is: 825897779
2023-02-08 09:46:35.153 AM[info]Tuya Water Valve State (dp=02) is: 1 (data=[00, 50, 02, 01, 00, 01, 01])
2023-02-08 09:46:35.024 AM[info]Tuya WaterConsumed (6F) is: 0
2023-02-08 09:46:34.901 AM[info]Tuya Water Valve State (dp=02) is: 1 (data=[00, 4E, 02, 01, 00, 01, 01])
2023-02-08 09:46:34.779 AM[info]Tuya IrrigationEndTime (66) is: 842674995
2023-02-08 09:46:34.685 AM[info]Tuya Tuya is open [physical]
2023-02-08 09:46:34.637 AM[info]Tuya Water Valve State (dp=02) is: 1 (data=[00, 4C, 02, 01, 00, 01, 01])
Also noticed a log entry for temperature.
@kkossev, I enabled debug logging on my valve after connecting it to a faucet. I then turned it on and off physically, then digitally, then off by irrigation timer. BTW, the irrigation timer function seems to need sent after the valve is open.
Got mine hooked up to to test if flow would prevent the 60 second automatic shut off and it did not. Still closed after 60 seconds. Logs below.
Summary
dev:65862023-02-08 03:28:35.963 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:28:35.960 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:28:35.957 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B86C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B8, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:28:35.951 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B86C02000400000064
dev:65862023-02-08 03:28:33.666 PMinfoTuya LastIrrigationDuration (72) is: 808202544
dev:65862023-02-08 03:28:33.662 PMtraceTuya Tuya cluster cmd=72 value=808202544 ()
dev:65862023-02-08 03:28:33.659 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B77203000B30303A30313A30302C3130, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B7, 72, 03, 00, 0B, 30, 30, 3A, 30, 31, 3A, 30, 30, 2C, 31, 30]]
dev:65862023-02-08 03:28:33.652 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B77203000B30303A30313A30302C3130
dev:65862023-02-08 03:28:33.552 PMinfoTuya IrrigationEndTime (66) is: 943338290
dev:65862023-02-08 03:28:33.547 PMtraceTuya Tuya cluster cmd=66 value=943338290 ()
dev:65862023-02-08 03:28:33.540 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B66603000830353A32383A3332, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B6, 66, 03, 00, 08, 30, 35, 3A, 32, 38, 3A, 33, 32]]
dev:65862023-02-08 03:28:33.534 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B66603000830353A32383A3332
dev:65862023-02-08 03:28:33.510 PMinfoTuya Tuya is closed [physical]
dev:65862023-02-08 03:28:33.410 PMdebugTuya Valve state changed from open to closed
dev:65862023-02-08 03:28:33.407 PMinfoTuya Water Valve State (dp=02) is: 0 (data=[00, B5, 02, 01, 00, 01, 00])
dev:65862023-02-08 03:28:33.404 PMtraceTuya Tuya cluster cmd=02 value=0 ()
dev:65862023-02-08 03:28:33.401 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B50201000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B5, 02, 01, 00, 01, 00]]
dev:65862023-02-08 03:28:33.395 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B50201000100
dev:65862023-02-08 03:28:33.296 PMinfoTuya ?CurrentTempurature? (6A) is: 0
dev:65862023-02-08 03:28:33.293 PMtraceTuya Tuya cluster cmd=6A value=0 ()
dev:65862023-02-08 03:28:33.290 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B46A02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B4, 6A, 02, 00, 04, 00, 00, 00, 00]]
dev:65862023-02-08 03:28:33.283 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B46A02000400000000
dev:65862023-02-08 03:28:28.345 PMinfoTuya WaterConsumed (6F) is: 10
dev:65862023-02-08 03:28:28.342 PMtraceTuya Tuya cluster cmd=6F value=10 ()
dev:65862023-02-08 03:28:28.339 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B36F0200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B3, 6F, 02, 00, 04, 00, 00, 00, 0A]]
dev:65862023-02-08 03:28:28.332 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B36F0200040000000A
dev:65862023-02-08 03:28:23.420 PMinfoTuya WaterConsumed (6F) is: 9
dev:65862023-02-08 03:28:23.417 PMtraceTuya Tuya cluster cmd=6F value=9 ()
dev:65862023-02-08 03:28:23.414 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B26F02000400000009, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B2, 6F, 02, 00, 04, 00, 00, 00, 09]]
dev:65862023-02-08 03:28:23.408 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B26F02000400000009
dev:65862023-02-08 03:28:23.298 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:28:23.294 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:28:23.291 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B16C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B1, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:28:23.286 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B16C02000400000064
dev:65862023-02-08 03:28:22.702 PMinfoTuya Received device announcement, data=[03, 5A, 08, F9, F3, 2F, 18, F5, 38, C1, A4, 80] (Sequence Number:03, Device network ID: 085A, Capability Information: 80)
dev:65862023-02-08 03:28:22.699 PMdebugTuya Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 085A 00 00 0000 00 00 035A08F9F32F18F538C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[03, 5A, 08, F9, F3, 2F, 18, F5, 38, C1, A4, 80]]
dev:65862023-02-08 03:28:22.693 PMdebugTuya description is catchall: 0000 0013 00 00 0040 00 085A 00 00 0000 00 00 035A08F9F32F18F538C1A480
dev:65862023-02-08 03:28:18.105 PMinfoTuya WaterConsumed (6F) is: 8
dev:65862023-02-08 03:28:18.102 PMtraceTuya Tuya cluster cmd=6F value=8 ()
dev:65862023-02-08 03:28:18.099 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B06F02000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B0, 6F, 02, 00, 04, 00, 00, 00, 08]]
dev:65862023-02-08 03:28:18.093 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B06F02000400000008
dev:65862023-02-08 03:28:12.152 PMinfoTuya WaterConsumed (6F) is: 7
dev:65862023-02-08 03:28:12.149 PMtraceTuya Tuya cluster cmd=6F value=7 ()
dev:65862023-02-08 03:28:12.146 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AF6F02000400000007, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, AF, 6F, 02, 00, 04, 00, 00, 00, 07]]
dev:65862023-02-08 03:28:12.140 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AF6F02000400000007
dev:65862023-02-08 03:28:09.544 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:28:09.541 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:28:09.538 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AE6C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, AE, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:28:09.532 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AE6C02000400000064
dev:65862023-02-08 03:28:06.736 PMinfoTuya WaterConsumed (6F) is: 6
dev:65862023-02-08 03:28:06.733 PMtraceTuya Tuya cluster cmd=6F value=6 ()
dev:65862023-02-08 03:28:06.730 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AD6F02000400000006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, AD, 6F, 02, 00, 04, 00, 00, 00, 06]]
dev:65862023-02-08 03:28:06.724 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AD6F02000400000006
dev:65862023-02-08 03:28:01.287 PMinfoTuya WaterConsumed (6F) is: 5
dev:65862023-02-08 03:28:01.284 PMtraceTuya Tuya cluster cmd=6F value=5 ()
dev:65862023-02-08 03:28:01.281 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AC6F02000400000005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, AC, 6F, 02, 00, 04, 00, 00, 00, 05]]
dev:65862023-02-08 03:28:01.274 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AC6F02000400000005
dev:65862023-02-08 03:27:56.779 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:27:56.776 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:27:56.773 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AB6C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, AB, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:27:56.766 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AB6C02000400000064
dev:65862023-02-08 03:27:55.820 PMinfoTuya WaterConsumed (6F) is: 4
dev:65862023-02-08 03:27:55.817 PMtraceTuya Tuya cluster cmd=6F value=4 ()
dev:65862023-02-08 03:27:55.814 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AA6F02000400000004, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, AA, 6F, 02, 00, 04, 00, 00, 00, 04]]
dev:65862023-02-08 03:27:55.808 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00AA6F02000400000004
dev:65862023-02-08 03:27:50.296 PMinfoTuya WaterConsumed (6F) is: 3
dev:65862023-02-08 03:27:50.293 PMtraceTuya Tuya cluster cmd=6F value=3 ()
dev:65862023-02-08 03:27:50.290 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A96F02000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A9, 6F, 02, 00, 04, 00, 00, 00, 03]]
dev:65862023-02-08 03:27:50.284 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A96F02000400000003
dev:65862023-02-08 03:27:44.770 PMinfoTuya WaterConsumed (6F) is: 2
dev:65862023-02-08 03:27:44.767 PMtraceTuya Tuya cluster cmd=6F value=2 ()
dev:65862023-02-08 03:27:44.764 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A86F02000400000002, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A8, 6F, 02, 00, 04, 00, 00, 00, 02]]
dev:65862023-02-08 03:27:44.758 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A86F02000400000002
dev:65862023-02-08 03:27:44.111 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:27:44.108 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:27:44.104 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A76C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A7, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:27:44.098 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A76C02000400000064
dev:65862023-02-08 03:27:39.088 PMinfoTuya WaterConsumed (6F) is: 1
dev:65862023-02-08 03:27:39.084 PMtraceTuya Tuya cluster cmd=6F value=1 ()
dev:65862023-02-08 03:27:39.081 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A66F02000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A6, 6F, 02, 00, 04, 00, 00, 00, 01]]
dev:65862023-02-08 03:27:39.075 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A66F02000400000001
dev:65862023-02-08 03:27:35.435 PMinfoTuya IrrigationStartTime (65) is: 926561074
dev:65862023-02-08 03:27:35.432 PMtraceTuya Tuya cluster cmd=65 value=926561074 ()
dev:65862023-02-08 03:27:35.429 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A56503000830353A32373A3332, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A5, 65, 03, 00, 08, 30, 35, 3A, 32, 37, 3A, 33, 32]]
dev:65862023-02-08 03:27:35.423 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A56503000830353A32373A3332
dev:65862023-02-08 03:27:35.306 PMinfoTuya Tuya is open [physical]
dev:65862023-02-08 03:27:35.274 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, A4, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:27:35.271 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:27:35.268 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A40201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A4, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:27:35.260 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A40201000101
dev:65862023-02-08 03:27:34.741 PMinfoTuya Tuya is open [physical]
dev:65862023-02-08 03:27:34.691 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, A4, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:27:34.688 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:27:34.686 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A40201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A4, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:27:34.680 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A40201000101
dev:65862023-02-08 03:27:34.253 PMinfoTuya WaterConsumed (6F) is: 0
dev:65862023-02-08 03:27:34.250 PMtraceTuya Tuya cluster cmd=6F value=0 ()
dev:65862023-02-08 03:27:34.246 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A36F02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A3, 6F, 02, 00, 04, 00, 00, 00, 00]]
dev:65862023-02-08 03:27:34.240 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A36F02000400000000
dev:65862023-02-08 03:27:34.092 PMdebugTuya Ignored duplicated switch event for model TS0601
dev:65862023-02-08 03:27:34.089 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, A2, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:27:34.086 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:27:34.083 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A20201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A2, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:27:34.076 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A20201000101
dev:65862023-02-08 03:27:33.972 PMdebugTuya Ignored duplicated switch event for model TS0601
dev:65862023-02-08 03:27:33.969 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, A1, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:27:33.966 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:27:33.963 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A10201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A1, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:27:33.957 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A10201000101
dev:65862023-02-08 03:27:33.820 PMinfoTuya IrrigationEndTime (66) is: 943338290
dev:65862023-02-08 03:27:33.816 PMtraceTuya Tuya cluster cmd=66 value=943338290 ()
dev:65862023-02-08 03:27:33.813 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A06603000830353A32383A3332, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, A0, 66, 03, 00, 08, 30, 35, 3A, 32, 38, 3A, 33, 32]]
dev:65862023-02-08 03:27:33.806 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00A06603000830353A32383A3332
dev:65862023-02-08 03:27:33.692 PMinfoTuya Tuya is open [digital]
dev:65862023-02-08 03:27:33.651 PMdebugTuya Valve state changed from closed to open
dev:65862023-02-08 03:27:33.647 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, 9F, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:27:33.644 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:27:33.640 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 009F0201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 9F, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:27:33.634 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 009F0201000101
dev:65862023-02-08 03:27:33.620 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:65862023-02-08 03:27:33.615 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000
dev:65862023-02-08 03:27:33.590 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:65862023-02-08 03:27:33.585 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000
dev:65862023-02-08 03:27:33.537 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:65862023-02-08 03:27:33.532 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000
dev:65862023-02-08 03:27:30.993 PMdebugTuya sendZigbeeCommands (cmd=[he cmd 0x085A 0x01 0xEF00 0x00 {00380201000101} {}, delay 200, he cmd 0x085A 0x01 0xEF00 0x00 {00390201000101} {}, delay 200])
dev:65862023-02-08 03:27:30.950 PMdebugTuya opening WaterIrrigationValve cmds = [he cmd 0x085A 0x01 0xEF00 0x00 {00380201000101} {}, delay 200, he cmd 0x085A 0x01 0xEF00 0x00 {00390201000101} {}, delay 200]
dev:65862023-02-08 03:27:30.947 PMtraceTuya sendTuyaCommand = [he cmd 0x085A 0x01 0xEF00 0x00 {00390201000101} {}, delay 200]
dev:65862023-02-08 03:27:30.943 PMtraceTuya sendTuyaCommand = [he cmd 0x085A 0x01 0xEF00 0x00 {00380201000101} {}, delay 200]
dev:65862023-02-08 03:27:30.936 PMdebugTuya opening
Tested again, this time I set the irrigation timer to 120 seconds after opening. The timer did not take and it still closed after 60 seconds. Logs below.
Summary
dev:65862023-02-08 03:33:26.665 PMinfoTuya LastIrrigationDuration (72) is: 808202544
dev:65862023-02-08 03:33:26.662 PMtraceTuya Tuya cluster cmd=72 value=808202544 ()
dev:65862023-02-08 03:33:26.659 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00D17203000B30303A30313A30302C3130, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, D1, 72, 03, 00, 0B, 30, 30, 3A, 30, 31, 3A, 30, 30, 2C, 31, 30]]
dev:65862023-02-08 03:33:26.652 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00D17203000B30303A30313A30302C3130
dev:65862023-02-08 03:33:26.554 PMinfoTuya IrrigationEndTime (66) is: 859451957
dev:65862023-02-08 03:33:26.551 PMtraceTuya Tuya cluster cmd=66 value=859451957 ()
dev:65862023-02-08 03:33:26.548 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00D06603000830353A33333A3235, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, D0, 66, 03, 00, 08, 30, 35, 3A, 33, 33, 3A, 32, 35]]
dev:65862023-02-08 03:33:26.540 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00D06603000830353A33333A3235
dev:65862023-02-08 03:33:26.496 PMinfoTuya Tuya is closed [physical]
dev:65862023-02-08 03:33:26.422 PMdebugTuya Valve state changed from open to closed
dev:65862023-02-08 03:33:26.419 PMinfoTuya Water Valve State (dp=02) is: 0 (data=[00, CF, 02, 01, 00, 01, 00])
dev:65862023-02-08 03:33:26.416 PMtraceTuya Tuya cluster cmd=02 value=0 ()
dev:65862023-02-08 03:33:26.413 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CF0201000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, CF, 02, 01, 00, 01, 00]]
dev:65862023-02-08 03:33:26.408 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CF0201000100
dev:65862023-02-08 03:33:26.295 PMinfoTuya ?CurrentTempurature? (6A) is: 0
dev:65862023-02-08 03:33:26.292 PMtraceTuya Tuya cluster cmd=6A value=0 ()
dev:65862023-02-08 03:33:26.289 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CE6A02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, CE, 6A, 02, 00, 04, 00, 00, 00, 00]]
dev:65862023-02-08 03:33:26.283 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CE6A02000400000000
dev:65862023-02-08 03:33:23.770 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:33:23.767 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:33:23.764 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CD6C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, CD, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:33:23.758 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CD6C02000400000064
dev:65862023-02-08 03:33:21.639 PMinfoTuya WaterConsumed (6F) is: 10
dev:65862023-02-08 03:33:21.636 PMtraceTuya Tuya cluster cmd=6F value=10 ()
dev:65862023-02-08 03:33:21.633 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CC6F0200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, CC, 6F, 02, 00, 04, 00, 00, 00, 0A]]
dev:65862023-02-08 03:33:21.626 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CC6F0200040000000A
dev:65862023-02-08 03:33:15.702 PMinfoTuya WaterConsumed (6F) is: 9
dev:65862023-02-08 03:33:15.699 PMtraceTuya Tuya cluster cmd=6F value=9 ()
dev:65862023-02-08 03:33:15.696 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CB6F02000400000009, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, CB, 6F, 02, 00, 04, 00, 00, 00, 09]]
dev:65862023-02-08 03:33:15.690 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CB6F02000400000009
dev:65862023-02-08 03:33:11.068 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:33:11.066 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:33:11.063 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CA6C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, CA, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:33:11.056 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00CA6C02000400000064
dev:65862023-02-08 03:33:10.301 PMinfoTuya WaterConsumed (6F) is: 8
dev:65862023-02-08 03:33:10.298 PMtraceTuya Tuya cluster cmd=6F value=8 ()
dev:65862023-02-08 03:33:10.295 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C96F02000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C9, 6F, 02, 00, 04, 00, 00, 00, 08]]
dev:65862023-02-08 03:33:10.289 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C96F02000400000008
dev:65862023-02-08 03:33:04.886 PMinfoTuya WaterConsumed (6F) is: 7
dev:65862023-02-08 03:33:04.883 PMtraceTuya Tuya cluster cmd=6F value=7 ()
dev:65862023-02-08 03:33:04.880 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C86F02000400000007, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C8, 6F, 02, 00, 04, 00, 00, 00, 07]]
dev:65862023-02-08 03:33:04.874 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C86F02000400000007
dev:65862023-02-08 03:32:59.449 PMinfoTuya WaterConsumed (6F) is: 6
dev:65862023-02-08 03:32:59.446 PMtraceTuya Tuya cluster cmd=6F value=6 ()
dev:65862023-02-08 03:32:59.443 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C76F02000400000006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C7, 6F, 02, 00, 04, 00, 00, 00, 06]]
dev:65862023-02-08 03:32:59.437 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C76F02000400000006
dev:65862023-02-08 03:32:58.411 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:32:58.408 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:32:58.405 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C66C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C6, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:32:58.399 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C66C02000400000064
dev:65862023-02-08 03:32:53.993 PMinfoTuya WaterConsumed (6F) is: 5
dev:65862023-02-08 03:32:53.990 PMtraceTuya Tuya cluster cmd=6F value=5 ()
dev:65862023-02-08 03:32:53.987 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C56F02000400000005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C5, 6F, 02, 00, 04, 00, 00, 00, 05]]
dev:65862023-02-08 03:32:53.981 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C56F02000400000005
dev:65862023-02-08 03:32:48.517 PMinfoTuya WaterConsumed (6F) is: 4
dev:65862023-02-08 03:32:48.514 PMtraceTuya Tuya cluster cmd=6F value=4 ()
dev:65862023-02-08 03:32:48.511 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C46F02000400000004, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C4, 6F, 02, 00, 04, 00, 00, 00, 04]]
dev:65862023-02-08 03:32:48.503 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C46F02000400000004
dev:65862023-02-08 03:32:45.642 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:32:45.639 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:32:45.636 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C36C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C3, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:32:45.628 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C36C02000400000064
dev:65862023-02-08 03:32:43.004 PMinfoTuya WaterConsumed (6F) is: 3
dev:65862023-02-08 03:32:43.001 PMtraceTuya Tuya cluster cmd=6F value=3 ()
dev:65862023-02-08 03:32:42.998 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C26F02000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C2, 6F, 02, 00, 04, 00, 00, 00, 03]]
dev:65862023-02-08 03:32:42.992 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C26F02000400000003
dev:65862023-02-08 03:32:37.474 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:65862023-02-08 03:32:37.469 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000
dev:65862023-02-08 03:32:37.463 PMinfoTuya WaterConsumed (6F) is: 2
dev:65862023-02-08 03:32:37.460 PMtraceTuya Tuya cluster cmd=6F value=2 ()
dev:65862023-02-08 03:32:37.457 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C16F02000400000002, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C1, 6F, 02, 00, 04, 00, 00, 00, 02]]
dev:65862023-02-08 03:32:37.451 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C16F02000400000002
dev:65862023-02-08 03:32:33.303 PMdebugTuya sendZigbeeCommands (cmd=[he cmd 0x085A 0x01 0xEF00 0x00 {003C0B02000400000078} {}, delay 200])
dev:65862023-02-08 03:32:33.300 PMtraceTuya sendTuyaCommand = [he cmd 0x085A 0x01 0xEF00 0x00 {003C0B02000400000078} {}, delay 200]
dev:65862023-02-08 03:32:33.294 PMdebugTuya setting the irrigation timer to 120 seconds
dev:65862023-02-08 03:32:32.428 PMinfoTuya Battery (6C) is: 100
dev:65862023-02-08 03:32:32.425 PMtraceTuya Tuya cluster cmd=6C value=100 ()
dev:65862023-02-08 03:32:32.422 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C06C02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C0, 6C, 02, 00, 04, 00, 00, 00, 64]]
dev:65862023-02-08 03:32:32.415 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00C06C02000400000064
dev:65862023-02-08 03:32:31.828 PMinfoTuya WaterConsumed (6F) is: 1
dev:65862023-02-08 03:32:31.826 PMtraceTuya Tuya cluster cmd=6F value=1 ()
dev:65862023-02-08 03:32:31.823 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BF6F02000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BF, 6F, 02, 00, 04, 00, 00, 00, 01]]
dev:65862023-02-08 03:32:31.816 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BF6F02000400000001
dev:65862023-02-08 03:32:28.150 PMinfoTuya IrrigationStartTime (65) is: 842674741
dev:65862023-02-08 03:32:28.146 PMtraceTuya Tuya cluster cmd=65 value=842674741 ()
dev:65862023-02-08 03:32:28.143 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BE6503000830353A33323A3235, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BE, 65, 03, 00, 08, 30, 35, 3A, 33, 32, 3A, 32, 35]]
dev:65862023-02-08 03:32:28.136 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BE6503000830353A33323A3235
dev:65862023-02-08 03:32:27.590 PMinfoTuya Tuya is open [physical]
dev:65862023-02-08 03:32:27.561 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, BD, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:32:27.558 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:32:27.555 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BD0201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BD, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:32:27.549 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BD0201000101
dev:65862023-02-08 03:32:27.220 PMinfoTuya Tuya is open [physical]
dev:65862023-02-08 03:32:27.169 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, BD, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:32:27.165 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:32:27.162 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BD0201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BD, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:32:27.156 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BD0201000101
dev:65862023-02-08 03:32:27.134 PMinfoTuya Tuya is open [physical]
dev:65862023-02-08 03:32:27.090 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, BD, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:32:27.086 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:32:27.081 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BD0201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BD, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:32:27.065 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BD0201000101
dev:65862023-02-08 03:32:26.884 PMinfoTuya WaterConsumed (6F) is: 0
dev:65862023-02-08 03:32:26.881 PMtraceTuya Tuya cluster cmd=6F value=0 ()
dev:65862023-02-08 03:32:26.878 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BC6F02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BC, 6F, 02, 00, 04, 00, 00, 00, 00]]
dev:65862023-02-08 03:32:26.871 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BC6F02000400000000
dev:65862023-02-08 03:32:26.759 PMdebugTuya Ignored duplicated switch event for model TS0601
dev:65862023-02-08 03:32:26.756 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, BB, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:32:26.754 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:32:26.751 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BB0201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BB, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:32:26.744 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BB0201000101
dev:65862023-02-08 03:32:26.633 PMinfoTuya IrrigationEndTime (66) is: 859451957
dev:65862023-02-08 03:32:26.630 PMtraceTuya Tuya cluster cmd=66 value=859451957 ()
dev:65862023-02-08 03:32:26.627 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BA6603000830353A33333A3235, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BA, 66, 03, 00, 08, 30, 35, 3A, 33, 33, 3A, 32, 35]]
dev:65862023-02-08 03:32:26.620 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00BA6603000830353A33333A3235
dev:65862023-02-08 03:32:26.506 PMinfoTuya Tuya is open [physical]
dev:65862023-02-08 03:32:26.456 PMdebugTuya Valve state changed from closed to open
dev:65862023-02-08 03:32:26.452 PMinfoTuya Water Valve State (dp=02) is: 1 (data=[00, B9, 02, 01, 00, 01, 01])
dev:65862023-02-08 03:32:26.449 PMtraceTuya Tuya cluster cmd=02 value=1 ()
dev:65862023-02-08 03:32:26.446 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B90201000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, B9, 02, 01, 00, 01, 01]]
dev:65862023-02-08 03:32:26.440 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 01 00 0000 02 01 00B90201000101
dev:65862023-02-08 03:32:26.416 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:65862023-02-08 03:32:26.389 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000
dev:65862023-02-08 03:32:26.315 PMdebugTuya Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:085A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:65862023-02-08 03:32:26.309 PMdebugTuya description is catchall: 0104 EF00 01 01 0040 00 085A 00 00 0000 0B 01 0000
dev:65862023-02-08 03:32:21.493 PMdebugTuya sendZigbeeCommands (cmd=[he cmd 0x085A 0x01 0xEF00 0x00 {003A0201000101} {}, delay 200, he cmd 0x085A 0x01 0xEF00 0x00 {003B0201000101} {}, delay 200])
dev:65862023-02-08 03:32:21.447 PMdebugTuya opening WaterIrrigationValve cmds = [he cmd 0x085A 0x01 0xEF00 0x00 {003A0201000101} {}, delay 200, he cmd 0x085A 0x01 0xEF00 0x00 {003B0201000101} {}, delay 200]
dev:65862023-02-08 03:32:21.444 PMtraceTuya sendTuyaCommand = [he cmd 0x085A 0x01 0xEF00 0x00 {003B0201000101} {}, delay 200]
dev:65862023-02-08 03:32:21.440 PMtraceTuya sendTuyaCommand = [he cmd 0x085A 0x01 0xEF00 0x00 {003A0201000101} {}, delay 200]
dev:65862023-02-08 03:32:21.436 PMdebugTuya opening
