[RELEASE] Tuya Wall Mount Thermostat (Water/Electric Floor Heating) Zigbee driver
No, I didn't mean to use webCoRE pistons instead of RM5 - currently, I don't have any pistons, all my automations are on RM5.
The only thing that I use from webCoRE at the moment is the Graphs - it is the former HubiGraph app. I replied to the question about what I am using for the graphs.
Another TRV. This one looks identical to the HY367 Immax, but has 1 less DP. Purchased from here,
res_04241e50cb132c0db1181b426a6119fe
Device Pairing Info
Manufacturer:	_TZE200_cpmgn2cf
Endpoint 01 application:	55
Endpoint 01 endpointId:	01
Endpoint 01 idAsInt:	1
Endpoint 01 inClusters:	0000,0004,0005,EF00
Endpoint 01 initialized:	true
Endpoint 01 manufacturer:	_TZE200_cpmgn2cf
Endpoint 01 model:	TS0601
Endpoint 01 outClusters:	0019,000A
Endpoint 01 profileId:	0104
Endpoint 01 stage:	4
Data Points
   "2":"Set temperature",
   "3":"Current temperature",
   "4":"Mode",
   "7":"Key Lock",
   "13":"Fault alarm",
   "44":"Temp Calibration",
   "102":"SetTemp.Min",
   "103":"SetTemp.Max",
   "104":"Window Parameter",
   "105":"Boost Time(S)",
   "106":"Valve Setting",
   "107":"ComfortTemp Set",
   "108":"EcoTemp Set",
   "109":"Valve Status",
   "110":"Battery Status",
   "111":"AutoMode Type",
   "112":"Workday Set",
   "113":"Restday Set",
   "114":"Holiday  Temperature",
   "115":"Window Status",
   "116":"KeyLock",
   "117":"Holiday Days"
Standard Instruction Set
Code	Type	Values
temp_set	Integer
  "unit": "°C",
  "min": 10,
  "max": 700,
  "scale": 1,
  "step": 5
mode	Enum
  "range": [
    "holiday",
    "auto",
    "manual",
    "comfort",
    "eco",
    "BOOST",
    "temp_auto"
child_lock	Boolean
"{true,false}"
roomtemp_calibrat	Integer
  "unit": "℃",
  "min": -90,
  "max": 90,
  "scale": 1,
  "step": 10
lowtemp	Integer
  "unit": "℃",
  "min": 1,
  "max": 15,
  "scale": 0,
  "step": 1
hightemp	Integer
  "unit": "℃",
  "min": 16,
  "max": 70,
  "scale": 0,
  "step": 1
wind	Raw
boost	Integer
  "unit": "",
  "min": 100,
  "max": 900,
  "scale": 0,
  "step": 100
valve_set	Enum
  "range": [
    "normal",
    "ForceOpen",
    "ForceClose"
comfort_temp	Integer
  "unit": "℃",
  "min": 1,
  "max": 70,
  "scale": 0,
  "step": 1
eco_temp	Integer
  "unit": "℃",
  "min": 1,
  "max": 70,
  "scale": 0,
  "step": 1
week_state	Enum
  "range": [
    "0",
    "1",
    "2"
Prog_Workday	Raw
Prog_Restday	Raw
Temp_holiday	Integer
  "unit": "℃",
  "min": 1,
  "max": 70,
  "scale": 0,
  "step": 1
Auto_Lock	Boolean
"{true,false}"
Days_Holiday	Integer
  "unit": "天",
  "min": 1,
  "max": 30,
  "scale": 0,
  "step": 1
Standard Status Set
Code	Type	Values
temp_set	Integer
  "unit": "°C",
  "min": 10,
  "max": 700,
  "scale": 1,
  "step": 5
temp_current	Integer
  "unit": "°C",
  "min": 0,
  "max": 700,
  "scale": 1,
  "step": 5
mode	Enum
  "range": [
    "holiday",
    "auto",
    "manual",
    "comfort",
    "eco",
    "BOOST",
    "temp_auto"
child_lock	Boolean
"{true,false}"
fault	Bitmap
  "label": [
    "1",
    "2",
    "3",
    "4",
    "5"
  "maxlen": 5
  "unit": "℃",
  "min": -90,
  "max": 90,
  "scale": 1,
  "step": 10
lowtemp	Integer
  "unit": "℃",
  "min": 1,
  "max": 15,
  "scale": 0,
  "step": 1
hightemp	Integer
  "unit": "℃",
  "min": 16,
  "max": 70,
  "scale": 0,
  "step": 1
wind	Raw
boost	Integer
  "unit": "",
  "min": 100,
  "max": 900,
  "scale": 0,
  "step": 100
valve_set	Enum
  "range": [
    "normal",
    "ForceOpen",
    "ForceClose"
  "unit": "℃",
  "min": 1,
  "max": 70,
  "scale": 0,
  "step": 1
eco_temp	Integer
  "unit": "℃",
  "min": 1,
  "max": 70,
  "scale": 0,
  "step": 1
valve	Integer
  "unit": "%",
  "min": 0,
  "max": 100,
  "scale": 0,
  "step": 1
power_state	Boolean
"{true,false}"
week_state	Enum
  "range": [
    "0",
    "1",
    "2"
Prog_Workday	Raw
Prog_Restday	Raw
  "unit": "℃",
  "min": 1,
  "max": 70,
  "scale": 0,
  "step": 1
windows_state	Boolean
"{true,false}"
Auto_Lock	Boolean
"{true,false}"
  "unit": "天",
  "min": 1,
  "max": 30,
  "scale": 0,
  "step": 1
If the DPs less one are matching, we could add it to the existing HY367 Product Profile ('Model Group' in this driver).
Thank you for the PR! :+1:, I will make some small changes and will push the updated version back.
The 'valve' should be a custom attribute, not a capability, as the Hubitat standard capability Valve adds automatically open() and close() methods that are usually not needed for TRVs/thermostats.
I will also add the newly sent events as custom attributes, otherwise they won't be accessible from RM5 rules.
Are you using any of the HE integrations to Alexa, Google or HomeKit?
I guess we could add it to HY367 and just log the missing DP functionality. Maybe a isWhatever(). I will be away for a few days, but intend to get the rest of the functionality working for HY367 after I get back.
Much appreciated on the valve issue, I don't yet know how everything works, was trying to get the valve to show up in my InfluxDB somehow, missing as of yet.
I am using Alexa, and have successfully changed the Setpoint. But, as with all integrations, it is not 100% working. I sometimes have to tell her to turn my Hue lights on twice, and to set the thermostat twice. It usually works the second time, if the first was unsuccessful, even though Alexa reports it as successful.
Hi @kkossev and all,
I have spent a lot of time searching for the right thermostst for my need but no luck so far so I am reaching out for your help.
My underfloor heating system is water based. I have 8 different zones controlled by separate 230v thermostats, each controlling an electric valve (Normaly Closed) with a relay rated 3 Amp. Each thermostat is located on the wall in the room it controls.
I would like to replace all thermostats to a smart thermostat (Zigbee to fit @kkossev driver if possible).
The current wall electric boxes are Gewiss 3 gang boxes which are 119mm wide and I would like to avoid replacing them with an EU box (55mm).
All thermostats on this post go well inside a 55 mm electric box but will not cover the 3 gang box I have as they are typically 86*86mm.
Did anyone see a suitable product I should look at?
Thanks,
@amithalp I don't have much experience with water-based underfloor heating systems...
As I understand it, you will reuse the existing electric valves and you are looking for new control thermostats only, that must fit into the existing electric boxes, that are 86*86mm.
Just out of curiosity, are these electric boxes used in Italy?
BTW, these are new, interesting and feature-reach thermostats that I discovered for myself in the last few days :
Hi @kkossev ,
Actually, the in-wall electric box is a standard (at least here in Israel) triple module box.
The dimentions are 119mm wide * 80mm tall
You can fill it with any Gewiss, Bticino or other brands' accessories.
The problem is that it seems most uthermostats are suitable for the smaller electric boxes that people ahrdly use anymore in my country.
Probably some adaptor plates exist aimed to accommodate EU style electrical devices into the 119mm wide * 80mm tall electrical boxes? Something that is produced / sold locally?
Anyone using the Tuya / Moes BRT-100 TRV can try the new driver:
[ALPHA] Tuya / Moes BRT-100 TRV driver
The code for this device remains in this driver, but any improvements will be done in the new driver in the future.
@kkossev,
I have set the hysteresis for the Tuya thermostat a few times.
Unfortunately, it does not seem to stick, any advise please?
Summary
Logs
dev:28492023-12-04 10:36:03.716 AMinfoTuya wall thermostat heatingSetpoint is: 18.0°C
dev:28492023-12-04 10:36:03.598 AMinfoTuya wall thermostat Thermostat mode reported is: heat
dev:28492023-12-04 10:35:58.732 AMinfoTuya wall thermostat AVATTO Program Mode (104) received is: off (0)
dev:28492023-12-04 10:35:57.241 AMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 10:35:57.104 AMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 10:35:56.979 AMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 10:35:56.625 AMinfoTuya wall thermostat Dead Zone temp (hysteresis) is: 0C (dp=106, fncmd=0)
dev:28492023-12-04 10:35:56.388 AMinfoTuya wall thermostat temperature calibration (correction) is: 0.0 (dp=27, fncmd=0)
dev:28492023-12-04 10:35:56.138 AMinfoTuya wall thermostat Update finished
dev:28492023-12-04 10:35:55.953 AMinfoDebug logging is false; Description text logging is true
dev:28492023-12-04 10:35:55.951 AMinfoForce manual is false; Resend failed is false
dev:28492023-12-04 10:35:55.948 AMinfoUpdating Tuya wall thermostat (Tuya Wall Thermostat) model TS0601 manufacturer _TZE200_ye5jkfsb modelGroupPreference = Auto detect (AVATTO)
If you change the hysteresis manually from the thermostat panel, is the new value reflected correctly in the driver? (always press F5 to refresh the web page)
Actually, I am not sure how to enter the settings menu on the panel, will need to find a manual. Thanks
Every device has different procedures for entering the system menu, for pairing, etc.. :frowning:
Found this on Aliexpress sellers page.
Looks like the hysteresis range is from 1-5, not 0.5.
Does it work if you set numerical only value?
I've entered 1.0 and it seems to be sticking.
Will check the settings on the panel later today.
@kkossev,
I've entered the panel settings during my lunch break and found the hysteris is still "0".
Changing it on the panel worked.
Unfortunately, it seems that everytime I save the preferences then the hysteresis gets reset to 0, see logs.
Summary
dev:28492023-12-04 02:08:48.785 PMinfoTuya wall thermostat heatingSetpoint is: 17.0°C
dev:28492023-12-04 02:08:48.684 PMinfoTuya wall thermostat Thermostat mode reported is: heat
dev:28492023-12-04 02:08:44.023 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 02:08:43.791 PMinfoTuya wall thermostat AVATTO Program Mode (104) received is: off (0)
dev:28492023-12-04 02:08:43.636 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 02:08:43.305 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 02:08:42.910 PMinfoTuya wall thermostat Dead Zone temp (hysteresis) is: 0C (dp=106, fncmd=0)
dev:28492023-12-04 02:08:42.667 PMinfoTuya wall thermostat temperature calibration (correction) is: 0.0 (dp=27, fncmd=0)
dev:28492023-12-04 02:08:42.510 PMinfoTuya wall thermostat Update finished
dev:28492023-12-04 02:08:42.435 PMinfoDebug logging is false; Description text logging is true
dev:28492023-12-04 02:08:42.434 PMinfoForce manual is false; Resend failed is false
dev:28492023-12-04 02:08:42.432 PMinfoUpdating Tuya wall thermostat (Tuya Wall Thermostat) model TS0601 manufacturer _TZE200_ye5jkfsb modelGroupPreference = Auto detect (AVATTO)
dev:28492023-12-04 02:06:57.997 PMinfoTuya wall thermostat heatingSetpoint is: 17.0°C
dev:28492023-12-04 02:06:57.912 PMinfoTuya wall thermostat Thermostat mode reported is: heat
dev:28492023-12-04 02:06:52.651 PMinfoTuya wall thermostat AVATTO Program Mode (104) received is: off (0)
dev:28492023-12-04 02:06:52.626 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 02:06:52.351 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 02:06:52.086 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 02:06:51.813 PMinfoTuya wall thermostat Dead Zone temp (hysteresis) is: 0C (dp=106, fncmd=0)
dev:28492023-12-04 02:06:51.658 PMinfoTuya wall thermostat temperature calibration (correction) is: 0.0 (dp=27, fncmd=0)
dev:28492023-12-04 02:06:51.413 PMinfoTuya wall thermostat Update finished
dev:28492023-12-04 02:06:51.337 PMinfoDebug logging is false; Description text logging is true
dev:28492023-12-04 02:06:51.336 PMinfoForce manual is false; Resend failed is false
dev:28492023-12-04 02:06:51.334 PMinfoUpdating Tuya wall thermostat (Tuya Wall Thermostat) model TS0601 manufacturer _TZE200_ye5jkfsb modelGroupPreference = Auto detect (AVATTO)
dev:28492023-12-04 01:26:34.633 PMinfoTuya wall thermostat temperature is: 20.0°C
dev:28492023-12-04 01:24:15.278 PMinfoTuya wall thermostat temperature is: 21.0°C
dev:28492023-12-04 01:24:02.222 PMinfoTuya wall thermostat heatingSetpoint is: 17.0°C
dev:28492023-12-04 01:24:02.025 PMinfoTuya wall thermostat Thermostat mode reported is: heat
dev:28492023-12-04 01:23:56.292 PMinfoTuya wall thermostat Antifreeze mode is on (1)
dev:28492023-12-04 01:23:56.215 PMinfoTuya wall thermostat Dead Zone temp (hysteresis) is: 1C (dp=106, fncmd=1)
dev:28492023-12-04 01:23:56.145 PMinfoTuya wall thermostat temperature calibration (correction) is: 0.0 (dp=27, fncmd=0)
dev:28492023-12-04 01:23:56.065 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 01:23:55.987 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 01:23:55.891 PMinfoTuya wall thermostat AVATTO Program Mode (104) received is: off (0)
dev:28492023-12-04 01:23:55.754 PMinfoTuya wall thermostat Sensor is: in (0)
dev:28492023-12-04 01:23:41.071 PMinfoTuya wall thermostat Antifreeze mode is on (1)
dev:28492023-12-04 01:23:40.929 PMinfoTuya wall thermostat Dead Zone temp (hysteresis) is: 1C (dp=106, fncmd=1)
dev:28492023-12-04 01:23:40.861 PMinfoTuya wall thermostat temperature calibration (correction) is: 0.0 (dp=27, fncmd=0)
dev:28492023-12-04 01:23:40.805 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 01:23:40.694 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 01:23:40.599 PMinfoTuya wall thermostat AVATTO Program Mode (104) received is: off (0)
dev:28492023-12-04 01:23:40.518 PMinfoTuya wall thermostat Sensor is: in (0)
dev:28492023-12-04 01:23:25.170 PMinfoTuya wall thermostat heatingSetpoint is: 17.0°C
dev:28492023-12-04 01:23:24.995 PMinfoTuya wall thermostat switchState reported is: OFF
dev:28492023-12-04 01:22:55.031 PMinfoTuya wall thermostat Dead Zone temp (hysteresis) is: 0C (dp=106, fncmd=0)
dev:28492023-12-04 01:22:54.878 PMinfoTuya wall thermostat AVATTO Program Mode (104) received is: off (0)
dev:28492023-12-04 01:22:54.858 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 01:22:54.716 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 01:22:54.498 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 01:22:54.357 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 01:22:54.198 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 01:22:54.086 PMinfoTuya wall thermostat AVATTO Max Temp Limit is: 32 C (dp=19, fncmd=32)
dev:28492023-12-04 01:22:53.918 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 01:22:53.705 PMinfoTuya wall thermostat Min temperature limit is: 10 C (dp=26, fncmd=10)
dev:28492023-12-04 01:22:53.278 PMinfoTuya wall thermostat temperature calibration (correction) is: 0.0 (dp=27, fncmd=0)
dev:28492023-12-04 01:22:53.129 PMinfoTuya wall thermostat Update finished
dev:28492023-12-04 01:22:52.860 PMinfoDebug logging is false; Description text logging is true
dev:28492023-12-04 01:22:52.858 PMinfoForce manual is false; Resend failed is false
dev:28492023-12-04 01:22:52.855 PMinfoUpdating Tuya wall thermostat (Tuya Wall Thermostat) model TS0601 manufacturer _TZE200_ye5jkfsb modelGroupPreference = Auto detect (AVATTO)
dev:28492023-12-04 01:22:52.705 PMinfoTuya wall thermostat Update finished
dev:28492023-12-04 01:22:52.602 PMinfoDebug logging is false; Description text logging is true
dev:28492023-12-04 01:22:52.600 PMinfoForce manual is false; Resend failed is false
dev:28492023-12-04 01:22:52.598 PMinfoUpdating Tuya wall thermostat (Tuya Wall Thermostat) model TS0601 manufacturer _TZE200_ye5jkfsb modelGroupPreference = Auto detect (AVATTO)
Hi @iEnam,
Good news - I reproduced and fixed the problem with the Avatto thermostat hysteresis setting. Will publish an update later tonight. Thank you for the detailed logs and the report!
I guess this change is only for the _TZE200_ye5jkfsb
My device is OK --> _TZE200_2ekuz3dz
Yes, the change is in only one line of code and affects the AVATTO thermostats only. The bug was in the conversion of the hysteresis preference from double to integer type. (AVATTO thermostats allow only integer values - 0, 1, 2, 3, etc.. while the BEOK thermostats allow centigrade values.
@iEnam - please update to the dev. branch version 1.3.7 2023/12/05 7:52 PM"
