Logs
dev:19742023-05-28 08:58:21.326 PMinfoTuya
sensor humidity is 44.0 % RH (delayed)
dev:19742023-05-28 08:58:21.207 PMinfoTuya
sensor temperature is 24.1 °C (delayed)
dev:19742023-05-28 08:58:18.186 PMdebugTuya
sensor Tuya cluster confirmation for command 0x24 response 0x00 data = [24, 00]
dev:19742023-05-28 08:58:18.183 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:19742023-05-28 08:58:18.042 PMdebugTuya
sensor sending time data : [he cmd 0xE244 0x01 0xEF00 0x24 {00086473B25A6473C06A}, delay 2000]
dev:19742023-05-28 08:58:18.041 PMtraceTuya
sensor now is: 1685303898041
dev:19742023-05-28 08:58:18.035 PMdebugTuya
sensor time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 24 01 7900, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[79, 00]]
dev:19742023-05-28 08:58:18.032 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 24 01 7900, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[79, 00]]
dev:19742023-05-28 08:58:17.714 PMtraceTuya
sensor sendZigbeeCommands(cmd=[he raw 0xE244 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he raw 0xE244 1 0x01 0x0402 {10 00 00 00 00}, delay 200, he raw 0xE244 1 0x01 0x0405 {10 00 00 00 00}, delay 200])
dev:19742023-05-28 08:58:17.636 PMdebugTuya
sensor NOT PARSED : [raw:E24401000068040042105F545A453230305F6C6F63616E73716E0000002003010000204805000042065453303630310700003003FEFF003000, dni:E244, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_locansqn, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:19742023-05-28 08:58:17.629 PMdebugTuya
sensor parse() descMap = [raw:E24401000068040042105F545A453230305F6C6F63616E73716E0000002003010000204805000042065453303630310700003003FEFF003000, dni:E244, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_locansqn, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:19742023-05-28 08:58:16.836 PMdebugTuya
sensor NOT PARSED : [raw:E2440100001CDFFF420A926E062C66936E062C12, dni:E244, endpoint:01, cluster:0000, size:1C, attrId:FFDF, encoding:42, command:0A, value:n,fn,, clusterInt:0, attrInt:65503]
dev:19742023-05-28 08:58:16.833 PMdebugTuya
sensor parse() descMap = [raw:E2440100001CDFFF420A926E062C66936E062C12, dni:E244, endpoint:01, cluster:0000, size:1C, attrId:FFDF, encoding:42, command:0A, value:n,fn,, clusterInt:0, attrInt:65503]
dev:19742023-05-28 08:58:16.822 PMdebugTuya
dev:19742023-05-28 08:58:16.788 PMdebugTuya
dev:19742023-05-28 08:58:16.678 PMdebugTuya
sensor sending time data : [he cmd 0xE244 0x01 0xEF00 0x24 {00086473B2586473C068}, delay 2000]
dev:19742023-05-28 08:58:16.677 PMtraceTuya
sensor now is: 1685303896677
dev:19742023-05-28 08:58:16.671 PMdebugTuya
sensor time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 24 01 7400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[74, 00]]
dev:19742023-05-28 08:58:16.668 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 24 01 7400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[74, 00]]
dev:19742023-05-28 08:58:16.547 PMdebugTuya
sensor Tuya check-in message (attribute 0001 reported: 48)
dev:19742023-05-28 08:58:16.542 PMdebugTuya
sensor parse() descMap = [raw:E2440100001801002048E2FF2038E4FF2000, dni:E244, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:19742023-05-28 08:58:16.416 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 11 01 31B840, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[31, B8, 40]]
dev:19742023-05-28 08:58:16.303 PMdebugTuya
sensor DELAYING 5 seconds event : [value:44, name:humidity, unit:% RH, type:delayed, isStateChange:true, descriptionText:humidity is 44.0 % RH]
dev:19742023-05-28 08:58:16.299 PMtraceTuya
sensor dp_id=2 dp=2 fncmd=44 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:16.295 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 0072020200040000002C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 72, 02, 02, 00, 04, 00, 00, 00, 2C]]
dev:19742023-05-28 08:58:16.181 PMdebugTuya
sensor DELAYING 5 seconds event : [name:temperature, unit:°C, value:24.1, type:delayed, isStateChange:true, descriptionText:temperature is 24.1 °C]
dev:19742023-05-28 08:58:16.177 PMtraceTuya
sensor dp_id=2 dp=1 fncmd=241 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:16.172 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 007101020004000000F1, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 71, 01, 02, 00, 04, 00, 00, 00, F1]]
dev:19742023-05-28 08:58:16.057 PMinfoTuya
sensor reported humidity sensitivity 1 %
dev:19742023-05-28 08:58:16.055 PMtraceTuya
sensor dp_id=2 dp=20 fncmd=1 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:16.051 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 00701402000400000001, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 70, 14, 02, 00, 04, 00, 00, 00, 01]]
dev:19742023-05-28 08:58:15.934 PMinfoTuya
sensor reported temperature sensitivity 0.5 C
dev:19742023-05-28 08:58:15.932 PMtraceTuya
sensor dp_id=2 dp=19 fncmd=10 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.927 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 006F130200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6F, 13, 02, 00, 04, 00, 00, 00, 0A]]
dev:19742023-05-28 08:58:15.811 PMinfoTuya
sensor reported humidity max reporting interval 3600 seconds
dev:19742023-05-28 08:58:15.809 PMtraceTuya
sensor dp_id=2 dp=18 fncmd=150 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.805 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 006E1202000400000096, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6E, 12, 02, 00, 04, 00, 00, 00, 96]]
dev:19742023-05-28 08:58:15.688 PMinfoTuya
sensor reported temperature max reporting interval 3600 seconds
dev:19742023-05-28 08:58:15.686 PMtraceTuya
sensor dp_id=2 dp=17 fncmd=150 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.681 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 006D1102000400000096, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6D, 11, 02, 00, 04, 00, 00, 00, 96]]
dev:19742023-05-28 08:58:15.565 PMinfoTuya
sensor humidity alarm lower limit is 20
dev:19742023-05-28 08:58:15.564 PMtraceTuya
sensor dp_id=2 dp=13 fncmd=20 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.560 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 006C0D02000400000014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6C, 0D, 02, 00, 04, 00, 00, 00, 14]]
dev:19742023-05-28 08:58:15.442 PMinfoTuya
sensor humidity alarm upper limit is 60
dev:19742023-05-28 08:58:15.441 PMtraceTuya
sensor dp_id=2 dp=12 fncmd=60 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.436 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 006B0C0200040000003C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6B, 0C, 02, 00, 04, 00, 00, 00, 3C]]
dev:19742023-05-28 08:58:15.321 PMinfoTuya
sensor reported temperature alarm lower limit 0.0 C
dev:19742023-05-28 08:58:15.319 PMtraceTuya
sensor dp_id=2 dp=11 fncmd=0 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.314 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 006A0B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6A, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:19742023-05-28 08:58:15.199 PMinfoTuya
sensor reported temperature alarm upper limit 39.0 C
dev:19742023-05-28 08:58:15.197 PMtraceTuya
sensor dp_id=2 dp=10 fncmd=390 fncmd_len=4 (index=0)
dev:19742023-05-28 08:58:15.192 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 00690A02000400000186, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 69, 0A, 02, 00, 04, 00, 00, 01, 86]]
dev:19742023-05-28 08:58:15.074 PMinfoTuya
sensor Temperature scale reported by device is: Celsius
dev:19742023-05-28 08:58:15.073 PMtraceTuya
sensor dp_id=4 dp=9 fncmd=0 fncmd_len=1 (index=0)
dev:19742023-05-28 08:58:15.069 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 02 01 00680904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 68, 09, 04, 00, 01, 00]]
dev:19742023-05-28 08:58:13.144 PMdebugTuya
dev:19742023-05-28 08:58:13.141 PMdebugTuya
dev:19742023-05-28 08:58:13.020 PMdebugTuya
sensor sending time data : [he cmd 0xE244 0x01 0xEF00 0x24 {00086473B2556473C065}, delay 2000]
dev:19742023-05-28 08:58:13.019 PMtraceTuya
sensor now is: 1685303893019
dev:19742023-05-28 08:58:13.013 PMdebugTuya
sensor time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 24 01 6600, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[66, 00]]
dev:19742023-05-28 08:58:13.009 PMdebugTuya
sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E244 01 00 0000 24 01 6600, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E244, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[66, 00]]
dev:19742023-05-28 08:58:11.908 PMdebugTuya
dev:19742023-05-28 08:58:11.892 PMdebugTuya
dev:19742023-05-28 08:58:11.829 PMinfoTuya
sensor battery is 145 %
dev:19742023-05-28 08:58:11.825 PMwarnTuya
sensor batteryPercentage rawValue corrected to 200
dev:19742023-05-28 08:58:11.818 PMdebugTuya
sensor getBatteryPercentageResult: rawValue = 290 -> 145%
dev:19742023-05-28 08:58:11.795 PMtraceTuya
sensor dp_id=2 dp=4 fncmd=145 fncmd_len=4 (index=0)
