[RELEASE] Tuya Scene Switch TS004F driver (w/ healthStatus)
Hi MF,
Thank you for the logs. It seems that we have a more complicated Tuya-specific handshake problem here.... or the problem may be on the other side, as there are no reports for such a problem on other home automation systems ....
[quote="maffpt, post:284, topic:92823"]
dev:35362025-09-02 10:29:05.182debugSeletor G-01 catchall descMap: [raw:catchall: 0000 0002 00 00 0040 00 3DC4 00 00 0000 00 00 0B0000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DC4, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0B, 00, 00]]
dev:35362025-09-02 10:29:05.181debugSeletor G-01 description is catchall: 0000 0002 00 00 0040 00 3DC4 00 00 0000 00 00 0B0000
[/quote]
This is a Node Descriptor request (0x0002) sent by the device, but HE is either not responding, or the Tuya device does not like something in the response (we do not see the HE system platform responses here).
Troubleshooting this issue will take time.
This one should be easier to add, when I have the chance (now working on a solution for adding more Tuya mmWave devices to the driver, and this may take a week or two).
Have you tried some of the HE system drivers - this is a standard IAS device, and may work with 'frient Panic Button' as example? Pair the device again to the hub after changing the driver.
Thank you!
I previously tried every driver I have that listed "panic" OR "button" in the name (setting the 2 SOS buttons I have to "device" as the driver in between and cleaning out states, etc.) -- no joy,
BUT, I had not tried re-pairing when changing the driver. So I tried the following process today:
(1) set driver to DEVICE and clear states, etc.
(2) select a new driver from this list: Frient Panic Button; Aeotec Panic Button; Frient Smart Button; Samsung Zigbee button; Tuya Scene Switch T3400F.
(3) re-pair (the 2 buttons I have do re-pair quite readily).
(4) push the button and look for an event.
OUTCOME: no joy, no driver in this latest set shows any event.
So I'm really hoping you can come to the rescue when you have time!
Hi
You won't believe ...
I used your Double Luck Voodoo procedure and I was able to connect the device and it's working fine- no problem at all.
It really looks like magic!
Thanks!
Pushed an update to version 2.8.3 2025-10-07 - added TS0041 _TZ3000_rsqqkdxv (thanks @sbohrer)
This introduces support for a new button type that was not available in earlier versions.
AliExpress: (link)
Might this Tuya button be bubbling to the top of your queue?
Pair it with this driver already assigned and the Debug logs enabled… anything in the live logs?
ver. 2.8.4 2025-10-20 - added IMOU Emergency Alarm Button ZE1
fingerprint profileId:'0104', endpointId:'01', inClusters:'0000,0001,0003,0500,0B05', outClusters: '0003', model: 'ZE2-EN', manufacturer: 'MultIR', deviceJoinName: 'IMOU Emergency Alarm Button ZE1'
Supports single click, double click, and held events.
Also available from many distributors in Europe / Asia.
Seems to be a quality device (it is not Tuya! :slight_smile: ).
Re-paired, with your driver, debug logging on:
dev:8862025-10-20 04:55:50.667 PMwarn
Remote - Panic Button 2 TU UNHANDLED event for button 0, lastButtonNumber=0
dev:8862025-10-20 04:55:50.665 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0000 0002 00 00 0040 00 E062 00 00 0000 00 00 250000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E062, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[25, 00, 00]]
dev:8862025-10-20 04:55:50.664 PMdebug
Remote - Panic Button 2 TU unprocessed catchall from cluster 2 sourceEndpoint 00
dev:8862025-10-20 04:55:50.663 PMdebug
dev:8862025-10-20 04:55:50.662 PMdebug
Remote - Panic Button 2 TU description is catchall: 0000 0002 00 00 0040 00 E062 00 00 0000 00 00 250000
dev:8862025-10-20 04:55:45.668 PMwarn
dev:8862025-10-20 04:55:45.666 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0000 0002 00 00 0040 00 E062 00 00 0000 00 00 240000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E062, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[24, 00, 00]]
dev:8862025-10-20 04:55:45.665 PMdebug
dev:8862025-10-20 04:55:45.663 PMdebug
dev:8862025-10-20 04:55:45.662 PMdebug
Remote - Panic Button 2 TU description is catchall: 0000 0002 00 00 0040 00 E062 00 00 0000 00 00 240000
dev:8862025-10-20 04:55:40.671 PMwarn
dev:8862025-10-20 04:55:40.669 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0000 0002 00 00 0040 00 E062 00 00 0000 00 00 230000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E062, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[23, 00, 00]]
dev:8862025-10-20 04:55:40.668 PMdebug
dev:8862025-10-20 04:55:40.665 PMdebug
dev:8862025-10-20 04:55:40.663 PMdebug
Remote - Panic Button 2 TU description is catchall: 0000 0002 00 00 0040 00 E062 00 00 0000 00 00 230000
dev:8862025-10-20 04:55:40.289 PMdebug
Remote - Panic Button 2 TU skipping Basic cluster 0000 response
dev:8862025-10-20 04:55:40.286 PMdebug
Remote - Panic Button 2 TU raw: descMap: [raw:E06201000064040042105F545A453230305F6E6F6A736A746A320000002003010000209005000042065453303630310700003003FEFF86, dni:E062, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZE200_nojsjtj2, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:90, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:8862025-10-20 04:55:40.281 PMwarn
Remote - Panic Button 2 TU exception caught while procesing event read attr - raw: E06201000064040042105F545A453230305F6E6F6A736A746A320000002003010000209005000042065453303630310700003003FEFF86, dni: E062, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F6E6F6A736A746A320000002003010000209005000042065453303630310700003003FEFF86
dev:8862025-10-20 04:55:40.277 PMdebug
Remote - Panic Button 2 TU description is read attr - raw: E06201000064040042105F545A453230305F6E6F6A736A746A320000002003010000209005000042065453303630310700003003FEFF86, dni: E062, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F6E6F6A736A746A320000002003010000209005000042065453303630310700003003FEFF86
dev:8862025-10-20 04:55:40.098 PMinfo
Remote - Panic Button 2 TU received device announcement, Device network ID: E062
dev:8862025-10-20 04:55:40.096 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0000 0013 00 00 0040 00 E062 00 00 0000 00 00 2262E056803A03E338C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E062, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[22, 62, E0, 56, 80, 3A, 03, E3, 38, C1, A4, 80]]
dev:8862025-10-20 04:55:40.095 PMdebug
Remote - Panic Button 2 TU description is catchall: 0000 0013 00 00 0040 00 E062 00 00 0000 00 00 2262E056803A03E338C1A480
dev:8862025-10-20 04:55:40.043 PMtrace
Remote - Panic Button 2 TU sendZigbeeCommands(cmd=[he raw 0xE062 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200])
dev:8862025-10-20 04:55:40.038 PMinfo
Remote - Panic Button 2 TU battery reporting interval not changed.
dev:8862025-10-20 04:55:40.035 PMdebug
Remote - Panic Button 2 TU Configuring device model TS0601 manufacturer _TZE200_nojsjtj2 ...
dev:8862025-10-20 04:54:55.356 PMwarn
dev:8862025-10-20 04:54:55.355 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00761A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 76, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:54:55.354 PMdebug
Remote - Panic Button 2 TU unprocessed catchall from cluster 61184 sourceEndpoint 01
dev:8862025-10-20 04:54:55.352 PMdebug
dev:8862025-10-20 04:54:55.350 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00761A04000100
dev:8862025-10-20 04:54:54.048 PMwarn
dev:8862025-10-20 04:54:54.046 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00751A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 75, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:54:54.045 PMdebug
dev:8862025-10-20 04:54:54.044 PMdebug
dev:8862025-10-20 04:54:54.043 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00751A04000100
dev:8862025-10-20 04:54:52.462 PMwarn
dev:8862025-10-20 04:54:52.460 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00741A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 74, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:54:52.458 PMdebug
dev:8862025-10-20 04:54:52.457 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00741A04000100
dev:8862025-10-20 04:54:48.605 PMwarn
dev:8862025-10-20 04:54:48.603 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00731A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 73, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:54:48.602 PMdebug
dev:8862025-10-20 04:54:48.600 PMdebug
dev:8862025-10-20 04:54:48.599 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00731A04000100
dev:8862025-10-20 04:53:52.190 PMwarn
dev:8862025-10-20 04:53:52.188 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00721A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 72, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:53:52.187 PMdebug
dev:8862025-10-20 04:53:52.185 PMdebug
dev:8862025-10-20 04:53:52.184 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00721A04000100
dev:8862025-10-20 04:53:49.304 PMwarn
dev:8862025-10-20 04:53:49.302 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00711A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 71, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:53:49.300 PMdebug
dev:8862025-10-20 04:53:49.299 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00711A04000100
dev:8862025-10-20 04:53:45.464 PMwarn
dev:8862025-10-20 04:53:45.462 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00701A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 70, 1A, 04, 00, 01, 00]]
dev:8862025-10-20 04:53:45.461 PMdebug
dev:8862025-10-20 04:53:45.459 PMdebug
dev:8862025-10-20 04:53:45.458 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 00701A04000100
dev:8862025-10-20 04:53:36.607 PMinfo
Remote - Panic Button 2 TU battery is 100 %
dev:8862025-10-20 04:53:36.606 PMdebug
Remote - Panic Button 2 TU Event enter: [name:battery, value:100.0]
dev:8862025-10-20 04:53:36.605 PMdebug
Remote - Panic Button 2 TU description is read attr - raw: 82E401000110210020C82000201C, dni: 82E4, endpoint: 01, cluster: 0001, size: 10, attrId: 0021, encoding: 20, command: 0A, value: C82000201C
dev:8862025-10-20 04:53:36.105 PMwarn
dev:8862025-10-20 04:53:36.103 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 006E0302000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6E, 03, 02, 00, 04, 00, 00, 00, 64]]
dev:8862025-10-20 04:53:36.102 PMdebug
dev:8862025-10-20 04:53:36.100 PMdebug
dev:8862025-10-20 04:53:36.099 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 006E0302000400000064
dev:8862025-10-20 04:53:30.263 PMdebug
Remote - Panic Button 2 TU updated()
dev:8862025-10-20 04:53:26.572 PMinfo
dev:8862025-10-20 04:53:26.571 PMdebug
dev:8862025-10-20 04:53:26.569 PMdebug
dev:8862025-10-20 04:53:26.035 PMwarn
dev:8862025-10-20 04:53:26.012 PMdebug
Remote - Panic Button 2 TU catchall descMap: [raw:catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 006C0302000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:82E4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6C, 03, 02, 00, 04, 00, 00, 00, 64]]
dev:8862025-10-20 04:53:26.011 PMdebug
dev:8862025-10-20 04:53:26.009 PMdebug
dev:8862025-10-20 04:53:26.008 PMdebug
Remote - Panic Button 2 TU description is catchall: 0104 EF00 01 01 0040 00 82E4 01 00 0000 02 01 006C0302000400000064
dev:8862025-10-20 04:53:20.462 PMdebug
dev:8862025-10-20 04:53:16.627 PMdebug
dev:8862025-10-20 04:53:16.536 PMinfo
dev:8862025-10-20 04:53:15.995 PMinfo
Remote - Panic Button 2 TU is online
dev:8862025-10-20 04:53:15.979 PMinfo
Remote - Panic Button 2 TU InitializeVars()... fullInit = false
dev:8862025-10-20 04:53:15.974 PMdebug
Remote - Panic Button 2 TU updating the settings from the current driver version UNKNOWN to the new version 2.8.3 2025/10/07 8:07 AM
dev:8862025-10-20 04:52:50.752 PMwarn
configure...
dev:8862025-10-20 07:43:55.357 AMinfo
Remote - Panic Button 2 TU battery is 100%
I just installed a _TZ3000_rsqqkdxv button; it spams wildly different battery levels every few TENTHS of seconds (see below). Any way to shut it up??
dev:9312025-10-20 07:45:33.374 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 78 %
dev:9312025-10-20 07:45:33.187 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 46 %
dev:9312025-10-20 07:45:33.152 PMinfo
dev:9312025-10-20 07:45:33.140 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 89 %
dev:9312025-10-20 07:45:32.848 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 45 %
dev:9312025-10-20 07:45:32.244 PMinfo
dev:9312025-10-20 07:45:31.800 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 50 %
dev:9312025-10-20 07:45:31.748 PMinfo
dev:9312025-10-20 07:45:31.481 PMinfo
dev:9312025-10-20 07:45:31.362 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 90 %
dev:9312025-10-20 07:45:31.318 PMinfo
dev:9312025-10-20 07:45:31.157 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 80 %
dev:9312025-10-20 07:45:30.864 PMinfo
dev:9312025-10-20 07:45:30.856 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 81 %
dev:9312025-10-20 07:45:30.571 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 91 %
dev:9312025-10-20 07:45:30.258 PMinfo
dev:9312025-10-20 07:45:30.088 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 56 %
dev:9312025-10-20 07:45:29.894 PMinfo
dev:9312025-10-20 07:45:29.803 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 54 %
Enable the Debug logging to see what Zigbee messages are causing this.
Here you go -- I enabled the device (disabled previously as too spammy) with Debug logging enabled, and then pushed the button (note: I had to trim about 12000 characters off the top of the log to fit within the forum constraint)
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:84.0]
dev:9312025-10-20 10:00:26.044 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020A8, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: A8
dev:9312025-10-20 10:00:25.907 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 84 %
dev:9312025-10-20 10:00:25.906 PMdebug
dev:9312025-10-20 10:00:25.904 PMdebug
dev:9312025-10-20 10:00:25.781 PMinfo
dev:9312025-10-20 10:00:25.780 PMdebug
dev:9312025-10-20 10:00:25.779 PMdebug
dev:9312025-10-20 10:00:25.675 PMinfo
dev:9312025-10-20 10:00:25.674 PMdebug
dev:9312025-10-20 10:00:25.639 PMdebug
dev:9312025-10-20 10:00:25.502 PMinfo
dev:9312025-10-20 10:00:25.501 PMdebug
dev:9312025-10-20 10:00:25.500 PMdebug
dev:9312025-10-20 10:00:25.379 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 83 %
dev:9312025-10-20 10:00:25.378 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:83.0]
dev:9312025-10-20 10:00:25.376 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020A6, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: A6
dev:9312025-10-20 10:00:25.239 PMinfo
dev:9312025-10-20 10:00:25.238 PMdebug
dev:9312025-10-20 10:00:25.236 PMdebug
dev:9312025-10-20 10:00:25.112 PMinfo
dev:9312025-10-20 10:00:25.111 PMdebug
dev:9312025-10-20 10:00:25.110 PMdebug
dev:9312025-10-20 10:00:25.025 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 79 %
dev:9312025-10-20 10:00:25.024 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:79.0]
dev:9312025-10-20 10:00:25.022 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B39010001082100209E, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 9E
dev:9312025-10-20 10:00:24.688 PMinfo
dev:9312025-10-20 10:00:24.686 PMdebug
dev:9312025-10-20 10:00:24.685 PMdebug
dev:9312025-10-20 10:00:24.583 PMinfo
dev:9312025-10-20 10:00:24.582 PMdebug
dev:9312025-10-20 10:00:24.580 PMdebug
dev:9312025-10-20 10:00:24.478 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 69 %
dev:9312025-10-20 10:00:24.477 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:69.0]
dev:9312025-10-20 10:00:24.475 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B39010001082100208A, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 8A
dev:9312025-10-20 10:00:24.441 PMinfo
dev:9312025-10-20 10:00:24.440 PMdebug
dev:9312025-10-20 10:00:24.438 PMdebug
dev:9312025-10-20 10:00:24.237 PMinfo
dev:9312025-10-20 10:00:24.236 PMdebug
dev:9312025-10-20 10:00:24.235 PMdebug
dev:9312025-10-20 10:00:24.066 PMinfo
dev:9312025-10-20 10:00:24.065 PMdebug
dev:9312025-10-20 10:00:24.064 PMdebug
dev:9312025-10-20 10:00:24.055 PMinfo
dev:9312025-10-20 10:00:24.054 PMdebug
dev:9312025-10-20 10:00:24.052 PMdebug
dev:9312025-10-20 10:00:24.046 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 68 %
dev:9312025-10-20 10:00:24.011 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:68.0]
dev:9312025-10-20 10:00:24.009 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B390100010821002088, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 88
dev:9312025-10-20 10:00:23.790 PMinfo
dev:9312025-10-20 10:00:23.789 PMdebug
dev:9312025-10-20 10:00:23.787 PMdebug
dev:9312025-10-20 10:00:23.652 PMinfo
dev:9312025-10-20 10:00:23.651 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:80.0]
dev:9312025-10-20 10:00:23.650 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020A0, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: A0
dev:9312025-10-20 10:00:23.522 PMinfo
dev:9312025-10-20 10:00:23.521 PMdebug
dev:9312025-10-20 10:00:23.519 PMdebug
dev:9312025-10-20 10:00:23.374 PMinfo
dev:9312025-10-20 10:00:23.373 PMdebug
dev:9312025-10-20 10:00:23.371 PMdebug
dev:9312025-10-20 10:00:23.269 PMinfo
dev:9312025-10-20 10:00:23.268 PMdebug
dev:9312025-10-20 10:00:23.266 PMdebug
dev:9312025-10-20 10:00:23.034 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 70 %
dev:9312025-10-20 10:00:23.033 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:70.0]
dev:9312025-10-20 10:00:23.032 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B39010001082100208C, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 8C
dev:9312025-10-20 10:00:22.902 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 71 %
dev:9312025-10-20 10:00:22.900 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:71.0]
dev:9312025-10-20 10:00:22.899 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B39010001082100208E, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 8E
dev:9312025-10-20 10:00:22.872 PMinfo
dev:9312025-10-20 10:00:22.872 PMdebug
dev:9312025-10-20 10:00:22.870 PMdebug
dev:9312025-10-20 10:00:22.831 PMinfo
dev:9312025-10-20 10:00:22.831 PMdebug
dev:9312025-10-20 10:00:22.829 PMdebug
dev:9312025-10-20 10:00:22.556 PMinfo
dev:9312025-10-20 10:00:22.555 PMdebug
dev:9312025-10-20 10:00:22.553 PMdebug
dev:9312025-10-20 10:00:22.547 PMinfo
dev:9312025-10-20 10:00:22.546 PMdebug
dev:9312025-10-20 10:00:22.544 PMdebug
dev:9312025-10-20 10:00:22.249 PMinfo
dev:9312025-10-20 10:00:22.248 PMdebug
dev:9312025-10-20 10:00:22.247 PMdebug
dev:9312025-10-20 10:00:21.939 PMinfo
dev:9312025-10-20 10:00:21.938 PMdebug
dev:9312025-10-20 10:00:21.936 PMdebug
dev:9312025-10-20 10:00:21.809 PMinfo
dev:9312025-10-20 10:00:21.808 PMdebug
dev:9312025-10-20 10:00:21.806 PMdebug
dev:9312025-10-20 10:00:21.779 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 72 %
dev:9312025-10-20 10:00:21.778 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:72.0]
dev:9312025-10-20 10:00:21.776 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B390100010821002090, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 90
dev:9312025-10-20 10:00:21.545 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 86 %
dev:9312025-10-20 10:00:21.544 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:86.0]
dev:9312025-10-20 10:00:21.542 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020AC, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: AC
dev:9312025-10-20 10:00:21.348 PMinfo
dev:9312025-10-20 10:00:21.347 PMdebug
dev:9312025-10-20 10:00:21.345 PMdebug
dev:9312025-10-20 10:00:21.210 PMinfo
dev:9312025-10-20 10:00:21.210 PMdebug
dev:9312025-10-20 10:00:21.208 PMdebug
dev:9312025-10-20 10:00:21.092 PMinfo
dev:9312025-10-20 10:00:21.091 PMdebug
dev:9312025-10-20 10:00:21.089 PMdebug
dev:9312025-10-20 10:00:20.935 PMinfo
dev:9312025-10-20 10:00:20.934 PMdebug
dev:9312025-10-20 10:00:20.932 PMdebug
dev:9312025-10-20 10:00:20.783 PMinfo
dev:9312025-10-20 10:00:20.782 PMdebug
dev:9312025-10-20 10:00:20.780 PMdebug
dev:9312025-10-20 10:00:20.643 PMinfo
dev:9312025-10-20 10:00:20.642 PMdebug
dev:9312025-10-20 10:00:20.641 PMdebug
dev:9312025-10-20 10:00:20.512 PMinfo
dev:9312025-10-20 10:00:20.511 PMdebug
dev:9312025-10-20 10:00:20.510 PMdebug
dev:9312025-10-20 10:00:20.410 PMinfo
dev:9312025-10-20 10:00:20.409 PMdebug
dev:9312025-10-20 10:00:20.407 PMdebug
dev:9312025-10-20 10:00:20.239 PMinfo
dev:9312025-10-20 10:00:20.238 PMdebug
dev:9312025-10-20 10:00:20.236 PMdebug
dev:9312025-10-20 10:00:20.099 PMinfo
dev:9312025-10-20 10:00:20.098 PMdebug
dev:9312025-10-20 10:00:20.097 PMdebug
dev:9312025-10-20 10:00:19.992 PMinfo
dev:9312025-10-20 10:00:19.991 PMdebug
dev:9312025-10-20 10:00:19.989 PMdebug
dev:9312025-10-20 10:00:19.844 PMinfo
dev:9312025-10-20 10:00:19.843 PMdebug
dev:9312025-10-20 10:00:19.841 PMdebug
dev:9312025-10-20 10:00:19.720 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 87 %
dev:9312025-10-20 10:00:19.719 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:87.0]
dev:9312025-10-20 10:00:19.717 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020AE, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: AE
dev:9312025-10-20 10:00:19.596 PMinfo
dev:9312025-10-20 10:00:19.595 PMdebug
dev:9312025-10-20 10:00:19.593 PMdebug
dev:9312025-10-20 10:00:19.430 PMinfo
dev:9312025-10-20 10:00:19.429 PMdebug
dev:9312025-10-20 10:00:19.428 PMdebug
dev:9312025-10-20 10:00:19.299 PMinfo
dev:9312025-10-20 10:00:19.298 PMdebug
dev:9312025-10-20 10:00:19.296 PMdebug
dev:9312025-10-20 10:00:19.157 PMinfo
dev:9312025-10-20 10:00:19.156 PMdebug
dev:9312025-10-20 10:00:19.155 PMdebug
dev:9312025-10-20 10:00:19.019 PMinfo
dev:9312025-10-20 10:00:19.018 PMdebug
dev:9312025-10-20 10:00:19.017 PMdebug
dev:9312025-10-20 10:00:18.864 PMinfo
dev:9312025-10-20 10:00:18.864 PMdebug
dev:9312025-10-20 10:00:18.862 PMdebug
dev:9312025-10-20 10:00:18.708 PMinfo
dev:9312025-10-20 10:00:18.707 PMdebug
dev:9312025-10-20 10:00:18.705 PMdebug
dev:9312025-10-20 10:00:18.580 PMinfo
dev:9312025-10-20 10:00:18.579 PMdebug
dev:9312025-10-20 10:00:18.578 PMdebug
dev:9312025-10-20 10:00:18.439 PMinfo
dev:9312025-10-20 10:00:18.438 PMdebug
dev:9312025-10-20 10:00:18.435 PMdebug
dev:9312025-10-20 10:00:18.310 PMinfo
dev:9312025-10-20 10:00:18.309 PMdebug
dev:9312025-10-20 10:00:18.307 PMdebug
dev:9312025-10-20 10:00:18.166 PMinfo
dev:9312025-10-20 10:00:18.165 PMdebug
dev:9312025-10-20 10:00:18.163 PMdebug
dev:9312025-10-20 10:00:18.088 PMinfo
dev:9312025-10-20 10:00:18.087 PMdebug
dev:9312025-10-20 10:00:18.038 PMdebug
dev:9312025-10-20 10:00:17.926 PMinfo
dev:9312025-10-20 10:00:17.924 PMdebug
dev:9312025-10-20 10:00:17.923 PMdebug
dev:9312025-10-20 10:00:17.765 PMinfo
dev:9312025-10-20 10:00:17.764 PMdebug
dev:9312025-10-20 10:00:17.762 PMdebug
dev:9312025-10-20 10:00:17.630 PMinfo
dev:9312025-10-20 10:00:17.629 PMdebug
dev:9312025-10-20 10:00:17.628 PMdebug
dev:9312025-10-20 10:00:17.491 PMinfo
dev:9312025-10-20 10:00:17.490 PMdebug
dev:9312025-10-20 10:00:17.489 PMdebug
dev:9312025-10-20 10:00:17.320 PMinfo
dev:9312025-10-20 10:00:17.319 PMdebug
dev:9312025-10-20 10:00:17.318 PMdebug
dev:9312025-10-20 10:00:17.187 PMinfo
dev:9312025-10-20 10:00:17.186 PMdebug
dev:9312025-10-20 10:00:17.184 PMdebug
dev:9312025-10-20 10:00:17.021 PMinfo
dev:9312025-10-20 10:00:17.021 PMdebug
dev:9312025-10-20 10:00:17.019 PMdebug
dev:9312025-10-20 10:00:16.885 PMinfo
dev:9312025-10-20 10:00:16.883 PMdebug
dev:9312025-10-20 10:00:16.880 PMdebug
dev:9312025-10-20 10:00:16.665 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 88 %
dev:9312025-10-20 10:00:16.664 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:88.0]
dev:9312025-10-20 10:00:16.662 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020B0, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: B0
dev:9312025-10-20 10:00:16.522 PMinfo
dev:9312025-10-20 10:00:16.521 PMdebug
dev:9312025-10-20 10:00:16.520 PMdebug
dev:9312025-10-20 10:00:16.384 PMinfo
dev:9312025-10-20 10:00:16.383 PMdebug
dev:9312025-10-20 10:00:16.382 PMdebug
dev:9312025-10-20 10:00:16.249 PMinfo
dev:9312025-10-20 10:00:16.248 PMdebug
dev:9312025-10-20 10:00:16.245 PMdebug
dev:9312025-10-20 10:00:16.107 PMinfo
dev:9312025-10-20 10:00:16.106 PMdebug
dev:9312025-10-20 10:00:16.104 PMdebug
dev:9312025-10-20 10:00:16.020 PMinfo
dev:9312025-10-20 10:00:16.018 PMdebug
dev:9312025-10-20 10:00:16.016 PMdebug
dev:9312025-10-20 10:00:15.792 PMinfo
dev:9312025-10-20 10:00:15.791 PMdebug
dev:9312025-10-20 10:00:15.789 PMdebug
dev:9312025-10-20 10:00:15.751 PMinfo
dev:9312025-10-20 10:00:15.750 PMdebug
dev:9312025-10-20 10:00:15.748 PMdebug
dev:9312025-10-20 10:00:15.560 PMinfo
dev:9312025-10-20 10:00:15.516 PMdebug
dev:9312025-10-20 10:00:15.514 PMdebug
dev:9312025-10-20 10:00:15.381 PMinfo
dev:9312025-10-20 10:00:15.380 PMdebug
dev:9312025-10-20 10:00:15.378 PMdebug
dev:9312025-10-20 10:00:15.255 PMinfo
dev:9312025-10-20 10:00:15.254 PMdebug
dev:9312025-10-20 10:00:15.252 PMdebug
dev:9312025-10-20 10:00:15.116 PMinfo
dev:9312025-10-20 10:00:15.115 PMdebug
dev:9312025-10-20 10:00:15.113 PMdebug
dev:9312025-10-20 10:00:14.996 PMinfo
dev:9312025-10-20 10:00:14.995 PMdebug
dev:9312025-10-20 10:00:14.993 PMdebug
dev:9312025-10-20 10:00:14.894 PMinfo
dev:9312025-10-20 10:00:14.892 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:89.0]
dev:9312025-10-20 10:00:14.850 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020B2, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: B2
dev:9312025-10-20 10:00:14.711 PMinfo
dev:9312025-10-20 10:00:14.709 PMdebug
dev:9312025-10-20 10:00:14.708 PMdebug
dev:9312025-10-20 10:00:14.565 PMinfo
dev:9312025-10-20 10:00:14.564 PMdebug
dev:9312025-10-20 10:00:14.563 PMdebug
dev:9312025-10-20 10:00:14.439 PMinfo
dev:9312025-10-20 10:00:14.437 PMdebug
dev:9312025-10-20 10:00:14.435 PMdebug
dev:9312025-10-20 10:00:14.300 PMinfo
dev:9312025-10-20 10:00:14.299 PMdebug
dev:9312025-10-20 10:00:14.297 PMdebug
dev:9312025-10-20 10:00:14.166 PMinfo
dev:9312025-10-20 10:00:14.165 PMdebug
dev:9312025-10-20 10:00:14.163 PMdebug
dev:9312025-10-20 10:00:14.010 PMinfo
dev:9312025-10-20 10:00:14.009 PMdebug
dev:9312025-10-20 10:00:14.007 PMdebug
dev:9312025-10-20 10:00:13.874 PMinfo
dev:9312025-10-20 10:00:13.874 PMdebug
dev:9312025-10-20 10:00:13.872 PMdebug
dev:9312025-10-20 10:00:13.700 PMinfo
dev:9312025-10-20 10:00:13.699 PMdebug
dev:9312025-10-20 10:00:13.697 PMdebug
dev:9312025-10-20 10:00:13.598 PMinfo
dev:9312025-10-20 10:00:13.597 PMdebug
dev:9312025-10-20 10:00:13.595 PMdebug
dev:9312025-10-20 10:00:13.398 PMinfo
dev:9312025-10-20 10:00:13.397 PMdebug
dev:9312025-10-20 10:00:13.395 PMdebug
dev:9312025-10-20 10:00:13.222 PMinfo
dev:9312025-10-20 10:00:13.221 PMdebug
dev:9312025-10-20 10:00:13.219 PMdebug
dev:9312025-10-20 10:00:13.088 PMinfo
dev:9312025-10-20 10:00:13.087 PMdebug
dev:9312025-10-20 10:00:13.086 PMdebug
dev:9312025-10-20 10:00:12.966 PMinfo
dev:9312025-10-20 10:00:12.965 PMdebug
dev:9312025-10-20 10:00:12.964 PMdebug
dev:9312025-10-20 10:00:12.821 PMinfo
dev:9312025-10-20 10:00:12.820 PMdebug
dev:9312025-10-20 10:00:12.819 PMdebug
dev:9312025-10-20 10:00:12.681 PMinfo
dev:9312025-10-20 10:00:12.680 PMdebug
dev:9312025-10-20 10:00:12.679 PMdebug
dev:9312025-10-20 10:00:12.607 PMinfo
dev:9312025-10-20 10:00:12.606 PMdebug
dev:9312025-10-20 10:00:12.604 PMdebug
dev:9312025-10-20 10:00:12.415 PMinfo
dev:9312025-10-20 10:00:12.414 PMdebug
dev:9312025-10-20 10:00:12.413 PMdebug
dev:9312025-10-20 10:00:12.310 PMinfo
dev:9312025-10-20 10:00:12.309 PMdebug
dev:9312025-10-20 10:00:12.307 PMdebug
dev:9312025-10-20 10:00:12.080 PMinfo
dev:9312025-10-20 10:00:12.079 PMdebug
dev:9312025-10-20 10:00:12.077 PMdebug
dev:9312025-10-20 10:00:11.931 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 75 %
dev:9312025-10-20 10:00:11.930 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:75.0]
dev:9312025-10-20 10:00:11.929 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B390100010821002096, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 96
dev:9312025-10-20 10:00:11.745 PMinfo
dev:9312025-10-20 10:00:11.744 PMdebug
dev:9312025-10-20 10:00:11.742 PMdebug
dev:9312025-10-20 10:00:11.572 PMinfo
dev:9312025-10-20 10:00:11.571 PMdebug
dev:9312025-10-20 10:00:11.569 PMdebug
dev:9312025-10-20 10:00:11.449 PMinfo
dev:9312025-10-20 10:00:11.448 PMdebug
dev:9312025-10-20 10:00:11.447 PMdebug
dev:9312025-10-20 10:00:11.364 PMinfo
dev:9312025-10-20 10:00:11.363 PMdebug
dev:9312025-10-20 10:00:11.362 PMdebug
dev:9312025-10-20 10:00:11.170 PMinfo
dev:9312025-10-20 10:00:11.169 PMdebug
dev:9312025-10-20 10:00:11.167 PMdebug
dev:9312025-10-20 10:00:11.096 PMinfo
dev:9312025-10-20 10:00:11.095 PMdebug
dev:9312025-10-20 10:00:11.093 PMdebug
dev:9312025-10-20 10:00:10.918 PMinfo
dev:9312025-10-20 10:00:10.917 PMdebug
dev:9312025-10-20 10:00:10.915 PMdebug
dev:9312025-10-20 10:00:10.716 PMinfo
dev:9312025-10-20 10:00:10.715 PMdebug
dev:9312025-10-20 10:00:10.713 PMdebug
dev:9312025-10-20 10:00:10.592 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 74 %
dev:9312025-10-20 10:00:10.591 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:74.0]
dev:9312025-10-20 10:00:10.590 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B390100010821002094, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 94
dev:9312025-10-20 10:00:10.454 PMinfo
dev:9312025-10-20 10:00:10.453 PMdebug
dev:9312025-10-20 10:00:10.451 PMdebug
dev:9312025-10-20 10:00:10.315 PMinfo
dev:9312025-10-20 10:00:10.314 PMdebug
dev:9312025-10-20 10:00:10.313 PMdebug
dev:9312025-10-20 10:00:10.297 PMinfo
dev:9312025-10-20 10:00:10.296 PMdebug
dev:9312025-10-20 10:00:10.294 PMdebug
dev:9312025-10-20 10:00:10.162 PMinfo
dev:9312025-10-20 10:00:10.161 PMdebug
dev:9312025-10-20 10:00:10.159 PMdebug
dev:9312025-10-20 10:00:10.045 PMinfo
dev:9312025-10-20 10:00:10.044 PMdebug
dev:9312025-10-20 10:00:10.043 PMdebug
dev:9312025-10-20 10:00:09.989 PMinfo
dev:9312025-10-20 10:00:09.988 PMdebug
dev:9312025-10-20 10:00:09.987 PMdebug
dev:9312025-10-20 10:00:09.907 PMinfo
dev:9312025-10-20 10:00:09.906 PMdebug
dev:9312025-10-20 10:00:09.905 PMdebug
dev:9312025-10-20 10:00:09.731 PMinfo
dev:9312025-10-20 10:00:09.730 PMdebug
dev:9312025-10-20 10:00:09.729 PMdebug
dev:9312025-10-20 10:00:09.654 PMinfo
dev:9312025-10-20 10:00:09.601 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:90.0]
dev:9312025-10-20 10:00:09.599 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020B4, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: B4
dev:9312025-10-20 10:00:09.433 PMinfo
dev:9312025-10-20 10:00:09.432 PMdebug
dev:9312025-10-20 10:00:09.431 PMdebug
dev:9312025-10-20 10:00:09.292 PMinfo
dev:9312025-10-20 10:00:09.291 PMdebug
dev:9312025-10-20 10:00:09.290 PMdebug
dev:9312025-10-20 10:00:09.167 PMinfo
dev:9312025-10-20 10:00:09.166 PMdebug
dev:9312025-10-20 10:00:09.164 PMdebug
dev:9312025-10-20 10:00:09.017 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 76 %
dev:9312025-10-20 10:00:09.016 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:76.0]
dev:9312025-10-20 10:00:09.015 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B390100010821002098, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: 98
dev:9312025-10-20 10:00:08.866 PMinfo
dev:9312025-10-20 10:00:08.866 PMdebug
dev:9312025-10-20 10:00:08.864 PMdebug
dev:9312025-10-20 10:00:08.692 PMinfo
dev:9312025-10-20 10:00:08.691 PMdebug
dev:9312025-10-20 10:00:08.690 PMdebug
dev:9312025-10-20 10:00:08.515 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU button 1 was pushed
dev:9312025-10-20 10:00:08.514 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU **TS0041 Single Pushed** via Cluster 0006/Command 02
dev:9312025-10-20 10:00:08.512 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU catchall descMap: [raw:catchall: 0104 0006 01 01 0040 00 2B39 01 00 0000 02 00 , profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2B39, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:00, data:[]]
dev:9312025-10-20 10:00:08.510 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is catchall: 0104 0006 01 01 0040 00 2B39 01 00 0000 02 00
dev:9312025-10-20 10:00:08.485 PMinfo
Remote - Alarm Cancel Button - Office Door Frame TU battery is 93 %
dev:9312025-10-20 10:00:08.484 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:93.0]
dev:9312025-10-20 10:00:08.482 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020BA, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: BA
dev:9312025-10-20 10:00:08.348 PMinfo
dev:9312025-10-20 10:00:08.347 PMdebug
dev:9312025-10-20 10:00:08.346 PMdebug
dev:9312025-10-20 10:00:08.258 PMinfo
dev:9312025-10-20 10:00:08.257 PMdebug
dev:9312025-10-20 10:00:08.205 PMdebug
dev:9312025-10-20 10:00:08.104 PMinfo
dev:9312025-10-20 10:00:08.103 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU Event enter: [name:battery, value:81.0]
dev:9312025-10-20 10:00:08.101 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU description is read attr - raw: 2B3901000108210020A2, dni: 2B39, endpoint: 01, cluster: 0001, size: 08, attrId: 0021, encoding: 20, command: 0A, value: A2
dev:9312025-10-20 09:59:52.400 PMdebug
Remote - Alarm Cancel Button - Office Door Frame TU updated()
Thanks!
.... Remove the battery from the device; it will deplete quickly if battery reports are sent so frequently. :frowning: Note. that simply disabling the device from HE web page does not stop it from hammering the Zigbee network.
I have one or two ideas to try later.
Good to know!
From the logs, I see that Tuya DP 0x03 is used for reporting the battery level (100%), but the other DP 0x1A value is always zero.... not usable...
I assume you have tried pressing the button after pairing, but there is no indication of a button press.
After reviewing the code, I’m unsure how to proceed. Everything seems normal.
Try to explicitely configure the reporting time period for this device :
After saving the settings, pair the button again to your hub (without deleting it).
Correct. At present, those buttons are useless for HE: paired but non-functional.
I had already set an explicit reporting time period of 12 hours. No difference, the logs I posted were with that setting.
BUT -- re-pairing WORKED! Only button actions show in the logs now.
I thought that I had double-paired this button, since that is my SOP for Tuya devices, but I guess I missed this one!
Thank you so much for taking time to help!
OK, it seems that battery level is still reported, but just every 10 minutes, which I suppose is fine (hopefully the battery will last a while at that rate!). The battery reporting interval preference was reset to "default" when I re-paired it, so I'll try a longer interval.
Weirdly, the log vacillates between voltage and percentage:
dev:9312025-10-21 03:44:16.247 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.8 V
dev:9312025-10-21 03:34:23.183 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 03:24:27.980 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU battery is 57 %
dev:9312025-10-21 03:14:34.802 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU battery is 55 %
dev:9312025-10-21 03:04:41.599 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU battery is 56 %
dev:9312025-10-21 02:54:48.398 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 02:44:54.822 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 02:35:01.187 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 02:25:07.458 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 02:15:12.262 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 02:05:18.752 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 01:55:24.068 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.7 V
dev:9312025-10-21 01:45:30.572 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU battery is 66 %
dev:9312025-10-21 01:35:34.885 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU battery is 66 %
dev:9312025-10-21 01:25:40.362 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU battery is 65 %
dev:9312025-10-21 01:15:46.432 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU batteryVoltage is 2.8 V
dev:9312025-10-21 01:05:53.579 PMinfoRemote - Alarm Cancel Button - Office Door Frame TU button 1 was pushed
edit:just saw that you are aware of this..
will try some stuff from this thread.
hello!
trying to get these 2 switches to work proper:
6way switch:
Manufacturer _TZ3000_nrfkrgf4
Model TS0046
Tuya Version 1.0.4
4way switch:
Manufacturer _TZ3000_bgtzm4ny
Model TS0044
Tuya Version 2.1.3
the device commands page reports button pushes and held, only double tap goes back to 1 after the taps..
i cant see the buttons for use in other apps.. trying to use the buttons with the dimmer button controller. when i open the app i can only configue button 1..
same for both buttons.
this is the event log when i push button 1 on the 4way:
dev:552025-11-15 14:19:06.643
info
Button 4Way 1 switch is off null
dev:552025-11-15 14:19:06.642
debug
Button 4Way 1 Event enter: [name:switch, value:off]
dev:552025-11-15 14:19:06.640
debug
Button 4Way 1 description is read attr - raw: CDE50200060800001000, dni: CDE5, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
dev:552025-11-15 14:19:06.392
info
Button 4Way 1 button 1 was held
dev:552025-11-15 14:19:06.390
debug
Button 4Way 1 TS0041 Held via Cluster 0006/Command 00
dev:552025-11-15 14:19:06.389
debug
Button 4Way 1 catchall descMap: [raw:catchall: 0104 0006 02 01 0040 00 CDE5 01 00 0000 00 00 , profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:CDE5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:]
dev:552025-11-15 14:19:06.386
debug
Button 4Way 1 description is catchall: 0104 0006 02 01 0040 00 CDE5 01 00 0000 00 00
dev:552025-11-15 14:19:06.139
info
Button 4Way 1 button 2 was pushed
dev:552025-11-15 14:19:06.138
debug
Button 4Way 1 catchall descMap: [raw:catchall: 0104 0006 02 01 0040 00 CDE5 01 00 0000 FD 00 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:CDE5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:FD, direction:00, data:[00]]
dev:552025-11-15 14:19:06.136
debug
Button 4Way 1 description is catchall: 0104 0006 02 01 0040 00 CDE5 01 00 0000 FD 00 00
very new to whole home auto..
seems strange that i can use the button in button controllers apps, but not in the dim controller. other switches look fine in the dim controller.
thx for any help! especially to krasimir..after only 4 weeks i already used a lot of your code!
