Hi
I also have one of these and as you say, the driver won't work for it at all on Hubitat. I have found this one for SmartThings
When I use this in Hubitat though, it's not creating the child devices - The parent on/off works on channel one, but not on channel two.
Any chance you could help, I'm struggling to find a 2-gang dimmer module that works with Hubitat!
I've had a go at editing it and I have managed to get this, which creates the child devices, but none of the commands work on them:
* Moes ZigBee Switch
* Copyright 2020 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not
* use this file except in compliance with the License. You may obtain a copy
* of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
* License for the specific language governing permissions and limitations
* under the License.
public static String version() { return "v0.0.1.20210727" }
private getMODEL_MAP() {
'TS0601' : 3
metadata {
definition(name: "Moes Twin Zigbee Dimmer", namespace: "Moes", author: "Pumba", ocfDeviceType: "oic.d.light", vid: "Light") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Health Check"
capability "Switch"
capability "Switch Level"
command "childOn", ["string"]
command "childOff", ["string"]
command "childSetLevel", ["string", "string"]
//Moeshouse Switch
// 1 gang
fingerprint profileId: "0104", model: "TS0601", manufacturer: "_TZE200_amp6tsvy", endpointId: "01", inClusters: "0000,0004,0005,EF00", outClusters: "0019,000A", application: "42", deviceJoinName: "Moes Multi Switch 1"
// 2 gang dimmer
fingerprint profileId: "0104", model: "TS0601", manufacturer: "_TZE200_e3oitdyu", endpointId: "01", inClusters: "0000,0004,0005,EF00", outClusters: "0019,000A", application: "44", deviceJoinName: "Moes Multi Switch 1"
// 3 gang
fingerprint profileId: "0104", model: "TS0601", manufacturer: "_TZE200_tz32mtza", endpointId: "01", inClusters: "0000,0004,0005,EF00", outClusters: "0019,000A", application: "42", deviceJoinName: "Moes Multi Switch 1"
// Tile
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
// details(["switch", "refresh"])
details(["switch", "refresh", "level"])
def installed() {
//createChildDevices()
updateDataValue("onOff", "catchall")
refresh()
// Parse incoming device messages to generate events
Map map = [:]
//def event = zigbee.getEvent(description)
if (description?.startsWith('catchall:')) {
log.debug description
// call parseCatchAllMessage to parse the catchall message received
map = parseCatchAllMessage(description)
if (map != [:]) {
log.debug "ok send event: $map.name $map.value"
sendEvent(name: map.name, value: map.value)
else {
log.warn "DID NOT PARSE MESSAGE for description : $description"
private getChildEndpoint(String dni) {
dni.split(":")[-1] as Integer
def off() {
log.debug "called off"
zigbee.command(0xEF00, 0x0, "00010101000100") //kanaal 1
def on() {
log.debug "called on"
zigbee.command(0xEF00, 0x0, "00010101000101") //kanaal 1
def setLevel(value) {
log.debug "called setLevel with value $value"
if (value >= 0 && value <= 100) {
Map commandParams = [:]
String commandPayload = "0001020200040000" + zigbee.convertToHexString((value * 10) as Integer, 4) //kanaal 1
zigbee.command(0xEF00, 0x0, commandPayload)
def refresh() {
log.debug "called refresh"
zigbee.command(0xEF00, 0x0, "00020100")
//pauseExecution(1000)
//zigbee.command(0xEF00, 0x0, "0002020200")
def childOn(String dni) {
def childEndpoint = getChildEndpoint(dni)
def name = dni.split("-")[-1]
def cmd = zigbee.smartShield(text: "${name} on").format()
sendHubCommand(new hubitat.device.HubAction(cmd))
log.debug(" child on ${dni} ${childEndpoint} ")
zigbee.command(0xEF00, 0x0, "00000701000101") //kanaal 2
def childOff(String dni) {
def cmd = zigbee.smartShield(text: "${name} off").format()
log.debug " child off ${dni} ${childEndpoint} "
zigbee.command(0xEF00, 0x0, "00000701000100") //kanaal 2
def childSetLevel (String dni, Integer value) {
String commandPayload = "0000080200040000" + zigbee.convertToHexString((value * 10) as Integer, 4) //kanaal 2 ?
def configure() {
log.debug "Configuring Reporting and Bindings."
zigbee.onOffConfig() + zigbee.levelConfig() + zigbee.onOffRefresh() + zigbee.levelRefresh()
setupChildDevices()
private Map parseCatchAllMessage(String description) {
// Create a map from the raw zigbee message to make parsing more intuitive
def msg = zigbee.parse(description)
Map result = [:]
switch(msg.clusterId) {
case 0xEF00:
def attribute = getAttribute(msg.data)
def value = getAttributeValue(msg.data)
log.debug "173 Atribute ${attribute} AttributeValue ${value}"
switch (attribute) {
case "switch":
switch(value) {
case 0:
result = [
value: 'off',
data: [buttonNumber: 1],
descriptionText: "${device.displayName} button was pressed",
isStateChange: true
log.debug "185 ${device.displayName} button was pressed"
break;
case 1:
result = [
value: 'on',
isStateChange: true
log.debug "${device.displayName} button was pressed"
log.debug "297 ${result}"
break;
break;
case "switch2":
switch(value) {
case 0:
result = [
value: 'off',
data: [buttonNumber: 7],
isStateChange: true
log.debug "214 ${device.displayName} button was pressed"
break;
case 1:
result = [
value: 'on',
isStateChange: true
log.debug "227 ${result}"
break;
case "level":
int levelValue = value / 10
result = [
value: levelValue,
descriptionText: "${device.displayName} level was modified",
isStateChange: true
log.debug "241 result ${result}"
break;
case "level2":
result = [
value: levelValue,
isStateChange: true
log.debug "254 result ${result}"
break;
break;
return result
private String getAttribute(ArrayList _data) {
log.debug "282 data:${_data}"
String retValue = ""
if (_data[1] >0) {
if (_data[2] == 2 && _data[3] == 2 && _data[4] == 0) {
retValue = "level"
if (_data[2] == 1 && _data[3] == 1 && _data[4] == 0) {
retValue = "switch"
if (_data[2] == 8 && _data[3] == 2 && _data[4] == 0) {
retValue = "level2"
if (_data[2] == 7 && _data[3] == 1 && _data[4] == 0) {
retValue = "switch2"
log.debug "301 return ${retValue}"
return retValue
private int getAttributeValue(ArrayList _data) {
int retValue = 0
if (_data.size() >= 6) {
int dataLength = _data[5] as Integer
int power = 1;
for (i in dataLength..1) {
retValue = retValue + power * _data[i+5]
power = power * 256
return retValue
def setupChildDevices() {
if (debugLogging) log.debug "Parent setupChildDevices"
deleteObsoleteChildren()
def buttons = 0
switch (device.data.manufacturer) {
case '_TZE200_amp6tsvy':
buttons = 1
break
case '_TZE200_g1ib5ldv':
buttons = 2
break
case '_TZE200_e3oitdyu':
buttons = 2
break
case '_TZE200_tz32mtza':
buttons = 3
break
if (infoLogging) log.info "model: ${device.data.manufacturer} buttons: $buttons"
createChildDevices((int)buttons)
def createChildDevices(int buttons) {
if (debugLogging) log.debug "Parent createChildDevices"
if (buttons <= 1){
if (debugLogging) log.debug "This device have only: $buttons button, Child devices not needed."
return }
else
for (i in 1..buttons) {
def childId = "${device.id}-0${i}"
def existingChild = getChildDevices()?.find { it.deviceNetworkId == childId}
if (existingChild) {
if (infoLogging) log.info "Child device ${childId} already exists (${existingChild})"
else {
if (infoLogging) log.info "Creating device ${childId}"
addChildDevice("hubitat", "Generic Zigbee Dimmer", childId, [isComponent: true, name: "Switch EP0${i}", label: "${device.displayName} EP0${i}"])
def deleteObsoleteChildren() {
if (debugLogging) log.debug "Parent deleteChildren"
getChildDevices().each {child->
if (!child.deviceNetworkId.startsWith(device.id) || child.deviceNetworkId == "${device.id}-00") {
if (infoLogging) log.info "Deleting ${child.deviceNetworkId}"
deleteChildDevice(child.deviceNetworkId)
Chris
