[RELEASE] Tile Master - Display multiple devices that can be Controlled from the tile!
Hi @bptworld,
I am trying to use the copy tile option to setup a new tile, copying a tile that includes some maker API controls, switches and text. When I try to copy the tile I get an exception indicating the "currentValue" method is not supported, I also see the same error in the logs:
app:9342020-07-15 15:30:38.225 errorjava.lang.IllegalArgumentException: Command 'currentValue' is not supported by device. on line 1685 (pageConfig)
I also see this error whenever I try to open the tile master app for the target tile I am trying to create, i.e. the tile where I wanted to paste the tile setup, and cannot go any further into the app for this new tile.
Are you able to take a look? Let me know if you need anymore info or want me to test anything.
Thanks,
Simon
