Updates Released Today
Attribute Monitor & Activity Monitor 1.5.2:
Added support for cloud endpoints as a publishing option for tiles > 1,024 bytes. The default remains the use of File Manager. The main advantage of using a cloud endpoint instead of a file is that the content is now available outside your local area network.
To use a cloud endpoint you must first authorize the app code to use OAuth as shown below.
Accept the defaults and click Update
Publishing the tile to a Cloud Endpoint is as simple as going to the Publish Table options in your Tile Builder module and selecting Cloud Endpoint instead of File Manager.
Now click "Publish" and you are now using a Cloud Endpoint, that is all you need to do.
Example of a tile > 1,024 bytes available via a cloud endpoint over a cellular connection
These instructions are not yet in the documentation but they will be added soon.
This capability will be added to Multi-Attribute Monitor and Grid modules in the near future.
Thermostat 1.0.2: Add error handling for Thermostats that do not have a coolingSetpoint present, such as a floor heater, water heater etc. Also adds fine tuning option for the vertical and horizontal placement of the temperature display.
Many thanks to @thebearmay for sharing some code on Endpoints that inspired me to add this functionality to Tile Builder.
