[RELEASE] Tasmota Sync - Native and Real-time Synchronization between Hubitat and Tasmota 11 or later
Yes, I had done an Initialize. Here is a picture of the state variables, as well as the Hubitat log after doing an initialize (with debug level set to 3).
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:58.282 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣🐶 🛑 ..watchdog: Finished.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:58.278 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣🐶 ....watchdog: All normal. Not in a transaction.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.645 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣💨 ..hubitatResponse: Exiting
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.641 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..hubitatResponse: Closing Transaction
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.636 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..updateStatus: Complete:Success
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.628 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣**hubitatResponse**: **Setting device handler values to match device.**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.622 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....hubitatResponse: RSSI: 100
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.616 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....hubitatResponse: Flags are Action:STATE ActionValue:None
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.612 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....hubitatResponse: Raw data is: {"TIME":"2023-11-20T02:31:55","UPTIME":"0T00:02:22","UPTIMESEC":142,"HEAP":24,"SLEEPMODE":"DYNAMIC","SLEEP":50,"LOADAVG":19,"MQTTCOUNT":0,"POWER1":"OFF","POWER2":"OFF","WIFI":{"AP":1,"SSID":"HOMESWEETHOME","BSSID":"80:2A:A8:15:60:F7","CHANNEL":11,"MODE":"11N","RSSI":100,"SIGNAL":-47,"LINKCOUNT":1,"DOWNTIME":"0T00:00:04"}}.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.606 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣🏁 ..hubitatResponse: Entering, data received
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.602 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣💨 ..parse: Exit to hubitatResponse()
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.597 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....parse: TSync is: false.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.593 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....parse: StatusSync is: false.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.587 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....parse: body is {"Time":"2023-11-20T02:31:55","Uptime":"0T00:02:22","UptimeSec":142,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"HomeSweetHome","BSSId":"80:2A:A8:15:60:F7","Channel":11,"Mode":"11n","RSSI":100,"Signal":-47,"LinkCount":1,"Downtime":"0T00:00:04"}}
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.576 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......parse: data is mac:DC4F22FA2AFD, ip:c0a80118, port:50, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LVR5cGU6IGFwcGxpY2F0aW9uL2pzb24NClNlcnZlcjogVGFzbW90YS8xMS4xLjAgKEVTUDgyODUpDQpDYWNoZS1Db250cm9sOiBuby1jYWNoZSwgbm8tc3RvcmUsIG11c3QtcmV2YWxpZGF0ZQ0KUHJhZ21hOiBuby1jYWNoZQ0KRXhwaXJlczogLTENCkFjY2VwdC1SYW5nZXM6IG5vbmUNClRyYW5zZmVyLUVuY29kaW5nOiBjaHVua2VkDQpDb25uZWN0aW9uOiBjbG9zZQ0K, body:eyJUaW1lIjoiMjAyMy0xMS0yMFQwMjozMTo1NSIsIlVwdGltZSI6IjBUMDA6MDI6MjIiLCJVcHRpbWVTZWMiOjE0MiwiSGVhcCI6MjQsIlNsZWVwTW9kZSI6IkR5bmFtaWMiLCJTbGVlcCI6NTAsIkxvYWRBdmciOjE5LCJNcXR0Q291bnQiOjAsIlBPV0VSMSI6Ik9GRiIsIlBPV0VSMiI6Ik9GRiIsIldpZmkiOnsiQVAiOjEsIlNTSWQiOiJIb21lU3dlZXRIb21lIiwiQlNTSWQiOiI4MDoyQTpBODoxNTo2MDpGNyIsIkNoYW5uZWwiOjExLCJNb2RlIjoiMTFuIiwiUlNTSSI6MTAwLCJTaWduYWwiOi00NywiTGlua0NvdW50IjoxLCJEb3dudGltZSI6IjBUMDA6MDA6MDQifX0=
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:54.565 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣🏁 ..parse: Entering, data received.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.299 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣💨 ..callTasmota: Exiting
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.292 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..updateStatus: Sent:STATE
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.285 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: hubaction: GET /cm?user=null&password=null&cmnd=STATE%20None HTTP/1.1 Accept: */* User-Agent: Linux UPnP/1.0 Hubitat HOST: 192.168.1.24:80
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.279 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: Path: /cm?user=null&password=null&cmnd=STATE%20None
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.275 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......cleanURL: Returning fixed path: /cm?user=null&password=null&cmnd=STATE%20None
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.269 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......cleanURL: Fixing path: /cm?user=null&password=null&cmnd=STATE None
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.238 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: Starting Watchdog
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.235 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣📞 ....callTasmota: Opening Transaction
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:53.228 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣📞 **callTasmota**: **Sending command: STATE**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:52.743 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣🐶 🛑 ..watchdog: Finished.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:52.740 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣🐶 ....watchdog: All normal. Not in a transaction.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.114 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣💨 **statusResponse**: **Exiting**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.111 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..statusResponse: Closing Transaction
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.108 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..updateStatus: Complete:Success
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.103 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣**statusResponse**: **STATUS 8 - SENSOR values processed.**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.096 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....statusResponse: ****************** Data Processed ******************
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.083 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....statusResponse: De-duping attribute names. Attribute is: HUMIDITY Count is: 0
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.078 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....statusResponse: De-duping attribute names. Attribute is: TEMPERATURE Count is: 0
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.071 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....statusResponse: ****************** Items Processed ******************
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.064 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..statusResponse: STATUSSNS Time is: 2023-11-20T02:31:49
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.059 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......statusResponse: Item is: TIME
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.054 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......statusResponse: Item is: SWITCH3
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.049 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....statusResponse: ****************** Extracted Items and Sensors ******************
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.042 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......statusResponse: Add item: TIME
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.037 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......statusResponse: Add item: SWITCH3
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.032 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..statusResponse: STATUSSNS is: [SWITCH3:OFF, TIME:2023-11-20T02:31:49]
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.024 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......adjustBody: Adjusted Body {"STATUSSNS":{"TIME":"2023-11-20T02:31:49","SWITCH3":"OFF"}}
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.020 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......adjustBody: Received body is: {"STATUSSNS":{"TIME":"2023-11-20T02:31:49","SWITCH3":"OFF"}}
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.015 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣💨 ..parse: Exit to statusResponse()
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.008 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....parse: TSync is: false.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:48.004 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....parse: StatusSync is: true.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.998 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣....parse: body is {"StatusSNS":{"Time":"2023-11-20T02:31:49","Switch3":"OFF"}}
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.991 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......parse: data is mac:DC4F22FA2AFD, ip:c0a80118, port:50, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LVR5cGU6IGFwcGxpY2F0aW9uL2pzb24NClNlcnZlcjogVGFzbW90YS8xMS4xLjAgKEVTUDgyODUpDQpDYWNoZS1Db250cm9sOiBuby1jYWNoZSwgbm8tc3RvcmUsIG11c3QtcmV2YWxpZGF0ZQ0KUHJhZ21hOiBuby1jYWNoZQ0KRXhwaXJlczogLTENCkFjY2VwdC1SYW5nZXM6IG5vbmUNClRyYW5zZmVyLUVuY29kaW5nOiBjaHVua2VkDQpDb25uZWN0aW9uOiBjbG9zZQ0K, body:eyJTdGF0dXNTTlMiOnsiVGltZSI6IjIwMjMtMTEtMjBUMDI6MzE6NDkiLCJTd2l0Y2gzIjoiT0ZGIn19
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.965 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣🏁 ..parse: Entering, data received.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.860 PM[info](http://192.168.1.79/logs#)Tasmota Sync - Universal Multi Sensor Driver reloaded with sensor type All
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.853 PM[info](http://192.168.1.79/logs#)SwitchCount is: 1
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.766 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......remainingTime: Remaining time 4926
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.761 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣💨 ..callTasmota: Exiting
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.753 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..updateStatus: Sent:STATUS 8
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.747 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: hubaction: GET /cm?user=null&password=null&cmnd=STATUS%208 HTTP/1.1 Accept: */* User-Agent: Linux UPnP/1.0 Hubitat HOST: 192.168.1.24:80
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.741 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: Path: /cm?user=null&password=null&cmnd=STATUS%208
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.737 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......cleanURL: Returning fixed path: /cm?user=null&password=null&cmnd=STATUS%208
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.732 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......cleanURL: Fixing path: /cm?user=null&password=null&cmnd=STATUS 8
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.697 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: Starting Watchdog
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.694 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣📞 ....callTasmota: Opening Transaction
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.687 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣📞 **callTasmota**: **Sending command: STATUS 8**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.683 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..refresh: Getting sensor data.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.680 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣⚡ **Action**: **Refresh started....**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.666 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..Initialize: pollFrequency value: 0
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.662 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣2️⃣⚡ ....Action: DNI: C0A80118 is correct. Not updated.
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.657 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......updateDeviceNetworkID: Settings are:192.168.1.24
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:47.646 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣⚡ **Action**: **Initialize/Update Device**
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:44.847 PM[info](http://192.168.1.79/logs#)Tasmota Sync - Universal Multi Sensor Driver reloaded with sensor type All
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:44.843 PM[info](http://192.168.1.79/logs#)SwitchCount is: 1
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.161 PM[info](http://192.168.1.79/logs#)Tasmota Sync - Universal Multi Sensor Driver reloaded with sensor type All
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.156 PM[info](http://192.168.1.79/logs#)SwitchCount is: 1
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.118 PM[info](http://192.168.1.79/logs#)Garage Door - *️⃣1️⃣..updateStatus: Attributes Cleared - Refresh Browser!
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.078 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: switch4
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.072 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: switch3
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.065 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: switch2
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.058 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: switch1
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.052 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: switch
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.046 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: type
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.039 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: pulse
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.033 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: flowRate
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.027 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: active
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.020 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: uid
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.014 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: absRaw
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.007 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: weightRaw
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:40.000 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: weight
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.994 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: stage
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.987 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: energy
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.980 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: event
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.973 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: ambTmp
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.966 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: objTmp
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.960 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: proximity
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.953 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: cct
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.946 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: ambient
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.939 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: green
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.931 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: blue
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.924 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: red
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.916 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: data
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.908 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: bits
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.901 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: protocol
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.894 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: ms
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.887 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d7
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.880 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d6
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.873 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d5
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.865 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d4
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.858 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d3
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.851 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d2
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.842 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d1
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.834 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: d0
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.828 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: rate
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.821 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: soundPressureLevel
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.814 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: ultraViolet
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.807 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: gas
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.800 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: pressure
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.794 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: illuminance
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.787 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: dewPoint
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.780 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: totalStartTime
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.773 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: period
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.766 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: frequency
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.759 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: factor
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.752 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: reactivePower
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.746 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: apparentPower
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.739 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: today
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.732 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: yesterday
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.725 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: total
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.717 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: voltage
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.710 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: power
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.703 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: current
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.696 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: distance
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.689 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: pH
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.682 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: range
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.674 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: tvoc
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.667 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: resistance
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.659 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: pm25
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.652 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: ECO
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.645 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: ECO2
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.639 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: airQualityIndex
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.633 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: roll
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.626 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: pitch
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.620 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: yaw
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.614 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: gyroZAxis
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.607 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: gyroYAxis
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.601 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: gyroXAxis
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.595 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: accelZAxis
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.588 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: accelYAxis
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.582 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: accelXAxis
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.576 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: humidity
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.569 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: temperature3
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.562 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: temperature2
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.554 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: temperature1
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.548 PM[debug](http://192.168.1.79/logs#)Garage Door - *️⃣*️⃣*️⃣3️⃣......clearAttributes: Clearing attribute: temperature
[dev:513](http://192.168.1.79/logs#)2023-11-19 05:31:39.544 PM[info](http://192.168.1.79/logs#)Garage Door - 0️⃣**clearAttributes**: **Clearing All Attributes**
Here is the configuration of the Tasmota device:
Any ideas?
Thanks for your help.
Did you post this after the last time we communicated. I thought you had it figured and I can see SWITCH3 being detected in your trace log. Should get created on the first sync.
Yes, I did post this after the last time we communicated. As you note, it does show SWITCH3 being detected, but it never gets shown under the "State Variables" or "Current States". That is the point that I am stuck at.
