Sorry, mode is not supported
thank you. I went bebopping around looking for a virtual mode driver or something I could hook into, and found 'CurrentMode' in the amazing @thebearmay Hub Information device.
The current display of multitile shows the tile source then a value.
would it be possible to have 'tile source' 'attribute' then value? maybe each with it's own on/off switch? edit In my case, the tile source is not nearly as important as the attribute name...
Anyways. Thanks as always! Coffee sent!
(I replaced five tiles with ONE!)
For more options, take a look at Tile Master
Always appreciated, thanks!
Anyway to the the ° and the % symbols in for temp and humidity attributes? Hard to read without them...
Not with the Simple version, but you should be able to do it in Tile Master. You could also use 'Tile Headers' with this Simple version.
Hope this helps
I'll give it a whirl thanx
Thank you. Bptworld
If you put a lot of information in a good way, it is less readable.
I think that the readability will be improved if the character color can be changed in Attributes.
Of course, I'm still using it satisfactorily well.
