I made tweaks to the Driver code, to better support my use-case (PowerMeter data) and the rules I needed to support my graphs, and the WT graphs themselves.
I needed to add my Solar circuits to find the total-solar and, with the data-as-strings, this was painful to do in RM.
The changes were basic:
Simple MQTT Topic
- Add declaration for
PowerMetercapability, similar to how you supportSwitch(etc)
Simple MQTT Client
- Added support in the else case to test if the payload isNumber, and set the
powervalue
You mentioned this in your Known limitations, so I haven't submitted a PR to change it (but can if you'd like).
The rest of the mods were isolated to my Watchtower [visual] tweaks. These also got simpler with the numeric Timeseries
The relevant parts now look like:
and Solar/Generation Summation rule is simply:
