[RELEASE] Simple MQTT Client Driver
Download: GitHub - sethkinast/hubitat-simple-mqtt · GitHub
This driver allows your hub to subscribe and publish to topics via an MQTT broker. Each topic is represented as a child device, which makes it easy to incorporate topics into Rule Machine, dashboards, and more.
The goal of this driver is to act as a simple bridge between Hubitat and other MQTT-speaking devices. The driver is not aware of what devices are on your hub and it does not attempt to publish their state changes. If your goal is to map all of your hub's devices to MQTT topics, you likely want to use a different driver like MQTT Link.
Topics
Instead of devices, this driver is built around MQTT topics. You can register as many topics as you want and performance will not be affected, as a single MQTT connection is shared by all child devices.
Once you register a topic, it appears as a child device under the MQTT client. This allows you to use the topic in several ways.
Publishing to the topic
Each topic has the Notification capability, which lets Hubitat send a notification to the topic. The notification is sent as the payload of an MQTT message to the topic.
Subscribing to the topic
Each topic acts as a Button, a Switch, and a Variable for use in Rule Machine or other apps.
  • Button: Any message received to the topic (even a null message) will fire a Button 1 pushed event. This event fires every time a message is received, even if the message is the same.
  • Switch: If the message is on, off, true, or false, the topic's switch will turn on or off.
    If the switch is already on, Hubitat doesn't treat turning it on again as a new event, which means you can repeatedly publish the state of your device without firing a rule over and over.
  • Variable: Any other message will be stored in the variable field on the device, allowing you to listen for a Custom Attribute change in Rule Machine, or display the variable on a dashboard. This allows you to track water or fuel levels, temperatures, and more.
Bidirectional communication
You can use the same topic to both send and receive. However, note that the device will also receive its OWN messages (until Hubitat supports MQTT v5).
For many use cases this is OK, but be careful not to create an infinite loop. If you need better support for this scenario, please open an issue to discuss.
Why another MQTT driver?
None of the existing ones did what I wanted, haha :slight_smile: Most of the existing generic drivers are designed to mirror the devices on your hub to MQTT. I wanted a simpler client that I could use to publish and subscribe to arbitrary topics.
This driver is tiny (200 LOC with the child device driver) and has no companion app. It's a very thin layer around existing Hubitat concepts (Notification, Button, Switch, and Variable), which makes it lightweight and pretty intuitive. It doesn't use custom commands, which makes it nicer to integrate into Rules. It is more resilient than some of the others at properly reconnecting to the broker if it loses connection.
There are lots of alternatives that are mostly focused on mapping your Hubitat devices to topics. Check some of them out to see if they suit your needs better!
Examples
Pause ad blocking on Pihole
I had a virtual Button in a dashboard that pauses the Pihole for 5 minutes. In the same Rule Machine rule, I can now also Listen for Button 1 pushed on hubitat/pause_pihole, and then use Rule Machine to POST to https://pi.hole/api/dns/blocking
Decide if it's a work-from-home day
In Rule Machine, trigger at 7am M-F. If my presence sensor is Present, send a Notification to hubitat/work_from_home, which other devices on my network are listening for (like the coffee machine and the air conditioner).
Monitor solar production
My solar monitoring system publishes the total energy produced that day to hubitat/solar_production. I can use the variable attribute on this topic to display the value in a dashboard.
Monitor heating oil tank
I have a smart oil gauge in my tank that broadcasts the oil level to hubitat/oilTankLevel. I can use the variable attribute and fire a rule when the level gets too low. Because I need to make a numeric comparison, I have to convert the string payload to a number (see example under Known limitations)
Known limitations
  • Sending a notification on a device also triggers its button push (see Bidirectional communication section above)
  • JSON payloads are received but not parsed, because only one string variable attribute is available. Parsing arbitrary payloads in a way that is useful requires more thought.
  • Changing the topic prefix does not update child devices since that would break existing automations.
  • Rule Machine does not support Momentary buttons, which is why you have to check "Button 1 pushed" in rules instead.
  • MQTT payloads are always strings. Rather than include logic in the driver to try to parse payloads and publish a bunch of different attributes, the variable of the topic is always a string. If your topic publishes numbers, use a rule like this in Rule Machine to convert it. (h/t @at9 and @bertabcd1234 for setting me onto this)
Thankyou for putting this together!
Perfect timing, as I just restored my energy monitoring MQTT Topic stream(s), and needed to pull some of them back into Hubitat and WatchTower.
Here's what that looks like, with a small number of the Topics coming from my EM (Brultech GEM):
The two graphs in the middle, for Solar and for the Kitchen Fridge, are sourced over MQTT from their respective breakers, whilst the more granular Consumption (Power) data is coming from INNR outlets.
... and yes, it's gloomy here today, hence the low Solar-generation :wink:
Awesome! The exact use case I was looking for when I wrote this driver!
I made tweaks to the Driver code, to better support my use-case (PowerMeter data) and the rules I needed to support my graphs, and the WT graphs themselves.
I needed to add my Solar circuits to find the total-solar and, with the data-as-strings, this was painful to do in RM.
The changes were basic:
Simple MQTT Topic
  • Add declaration for PowerMeter capability, similar to how you support Switch (etc)
Simple MQTT Client
  • Added support in the else case to test if the payload isNumber, and set the power value
You mentioned this in your Known limitations, so I haven't submitted a PR to change it (but can if you'd like).
The rest of the mods were isolated to my Watchtower [visual] tweaks. These also got simpler with the numeric Timeseries
The relevant parts now look like:
and Solar/Generation Summation rule is simply:
Yeah I struggled with a good agnostic way for this. Because I'm using numbers that aren't power (tank fill level, temperature)
I think just dumping into power is probably better for your fork rather than the driver but happy to hear more ideas! Strong typing doesn't play well with what we're doing and Hubitat doesn't use Generics haha
There's a fairly small list of numeric Capabilities defined for this platform, and a somewhat smaller list of ones natively "point-n-click" in the UI.
When I first looked, I was hoping for a variable_number as part of Variable, but no joy there.
Things like level/depth/distance being obv ones in the IoT space that are missing.
The Energy space is well covered, with ones like CurrentMeter, EnergyMeter, PowerMeter and VoltageMeasurement
If I needed the other Energy ones, I was planning to overload it a little and do something akin to this hack:
        } else if (parsedMessage.payload) {
            events += [name: 'variable', value: parsedMessage.payload]
            if (parsedMessage.payload.isNumber()) {
                val = parsedMessage.payload.toDouble()
                events += [name: 'power', value: val]
                events += [name: 'energy', value: val]
                events += [name: 'voltage', value: val]
                events += [name: 'amperage', value: val]
TemperatureMeasurement exists, but the water levels (except for a PCT-based one for something else) are broadly missing.
Ok, for now I'll leave it in my personal copy.
I found this alternative version from @bravenel:
Which requires two variables per device, but would allow everything to happen in Rule Machine.
The other thing I considered was just, like you said, a variable_num, that would be set anytime the MQTT payload was numeric. It just felt a little dirty so I didn't include it in v1.
@bravenel, there isn't a one-liner version of these two rules I'm missing, is there? Assign device attribute (string) to rule variable (decimal) as decimal ?
If you are using a device attribute, then RM is only going to offer up numeric/decimal attributes to assign to a decimal variable. So, yeah, it takes 2 steps.
This is a simple and brilliant piece of code!
I made some minor code tweaks to get the battery level that is published by the OwnTracks app on an old iPad, which I am using as a dashboard display. I can now easily control a switch to turn charging on and off based on the battery level.
Thanks for sharing this awesome code!
Simple MQTT sounds exactly like what I have been looking for.
I have MQTT mosquitto running on a Linux box, an Arduino with a temp sensor hitting it every 10 minutes. MQTT Explorer shows that part is working.
On Hubitat, I have loaded the Simple MQTT Client and the Simple MQTT Topic driver code.
In Devices, I see MQTT Client (with a question mark), but no children (topics).
MQTT is configured to the server IP address, and the Client logs show Status: Connection succeeded.
I am missing something, or a version compatibility issue?
It depends if you want to publish or subscribe to some topic from HE - You can do both, but to publish, you just need some RM code, to "publish" to your MQTT client device - See below.
To subscribe, you go into the MQTT client device, and "Add a Handler" which requires the topic that your subscribing to, that then creates a child device, that has a single "state attribute" of "payload. - You can then trigger RM on "payload" changes, parse the internal payload string to whatever, and do whatever you want in RM - See additional screenshots below, but hope that helps - Just ask if any of this is unclear.
Subscription:
Publish:
Looks like I have different driver codes.
My goal is to read the air temperature and motion sensors in my shop, which is in a different building. Publishing is working from small Arduino modules in that building.
Yes, you do - Sorry about that - My initial post was off topic here.
So I loaded up the Simple MQTT Client up on my development C7 (it's running the recent Beta release, but that shouldn't matter in this case) and using my production Mosquito broker, and was able to get a topic subscription working without much issue.
It sounds like you already got the MQTT Client Virtual device created, and via the debug logs, you we're able to see a successful connection from HE to the broker (so I'm going to ignore that aspect of the setup)
My setup looks like:
Then to setep a subscription you add the topic in the "Commands" section of your new Virtual MQTT client device - Then click "Run" - Im my test case, it looks like:
The corresponding topic setup in MQTT explorer looks like:
Once you click run, it will create a child device, of the name specified in the Topic "Label" ("Test-Voltage" in my example) - Then go to the child device and look at the Current State "Variable" field, and this child device is already subscribed to the topic, and the "Variable" will update with each MQTT payload change for this topic. See below:
That's where I stopped with my example, and the "Variable" is a string type, but you can reference the child device ("Test-Voltage" in my case) with RM, and trigger on Variable changes, or On/Off, per the 1st post of this thread. - If you payload is something complex (JSON, XML, etc), then your going to need to parse that string apart in RM (and it's not like RM has very many good string processing primitives) - But we'll deal with that worst case late, as I'm not clear what your temperature payload looks like.
Let me know if you need more details about working with the topic payload in RM, but that's pretty well described in the OP.
Thank you for taking the time to spin up a matching setup. The examples were a great help. I now have a section in my HD+ dashboard showing one of my sensors. This opens up many of my Android IoT devices to connect to my Hubitat. I will come back to your post when I get to the motion sensors. Thanks again!
Just wanted to say huge thanks for sharing this @interrobang !! :100:
I am just getting around to playing with lorawan and this is a perfect light weight solution to get started with as you mentioned.
I did recently learn that the LPS8v2 (vs just original LPS8) is the way to go for me. I want to use the simple OTAA to add devices, and then simple MQTT over to a broker (mosquitto on rpi5) where the hubitat can then subscribe to see the sensor data for these longer range things.
I was able to get the LPS8v2 sending mqtt json data that I then receive (by subscription) on the hubitat. But I wasn't seeing a good way to have different sensors/devices on the LPS8v2 publish as different devices yet. Is there any recommendation if I get all the sensor json values to the hub as one topic? Can I just parse each one as they come in and set maybe virtual devices as the values it sees?
Are there examples of this anyone has? Does this sound like a bad idea?
Ok, gemini gave me something that looks like a great start. It's working and I'll refine from here.
import groovy.json.JsonSlurper
definition(
    name: "JSON Event Parser App",
    namespace: "custom",
    author: "User",
    description: "Watches for JSON in a device attribute and parses it.",
    category: "Convenience",
    iconUrl: "",
    iconX2Url: ""
preferences {
    section("Settings") {
        input "targetDevice", "capability.*", title: "Monitor this Device", required: true
        input "targetAttribute", "string", title: "Attribute Name with JSON", required: true, defaultValue: "jsonData"
def installed() {
    initialize()
def updated() {
    unsubscribe()
    initialize()
def initialize() {
    // Subscribe to the attribute changes
    subscribe(targetDevice, targetAttribute, eventHandler)
    log.info "Subscribed to ${targetDevice.displayName} for attribute ${targetAttribute}"
def eventHandler(evt) {
    String jsonString = evt.value
    log.debug "Raw JSON received: ${jsonString}"
    if (jsonString) {
        try {
            // Parse the JSON string into a Map/List
            def slurper = new JsonSlurper()
            def parsedData = slurper.parseText(jsonString)
            // --- PARSING LOGIC ---
            // Extracting values using dot notation and Safe Navigation (?.)
            def devName = parsedData?.deviceInfo?.deviceName
            def tempF   = parsedData?.object?.temp_f1
            def vBat    = parsedData?.object?.vbat
            def rssi    = parsedData?.rxInfo ? parsedData.rxInfo[0]?.rssi : "N/A"
            log.info "--- ChirpStack Update ---"
            log.info "Device: ${devName}"
            log.info "Temp F: ${tempF}"
            log.info "Battery: ${vBat}V"
            log.info "Signal (RSSI): ${rssi}"
            // If you want to use these values for logic:
            if (tempF && tempF < 32) {
                log.warn "Freezing alert for ${devName}!"
        } catch (Exception e) {
            log.error "Failed to parse JSON: ${e.message}"
