I have a temporary code update and instructions below to correct the source on your installation without re-installing. Instructions:
Open the Drivers Code page and open the "Samsung Wifi Speaker"
On line, add the updateDataValue code below after line 145. Save the changes.
Open your device and complete a Save Preferences.
Scrolling down to your device's data section, the input sources should look like the clip at the bottom.
On the device's page, run Input Source several times. This should scroll through the input sources of your device. (Note that when going to Bluetooth, it will take some time to transition to the next source. This is normal.)
Return to the CODE and delete the line you just added.
Get back to me if this fails or you have other issues.
Hi,
I have two speakers that are rather old, but they paired well with Smartthings and I can control them with the Samsung Multiroom App.
However, when I try to add to Hubitat using your integration they never get discovered.
My logs keep showing these every 15 seconds: app:5182020-10-14 19:54:37.923 debugSamsung Speakers Integration 3.3.4: ssdpDiscover app:5182020-10-14 19:54:22.606 debugSamsung Speakers Integration 3.3.4: ssdpDiscover
My speakers are the following Models:
Samsung R3 WAM3500WWB
Samsund Soundbar J8500 HW-J800WWB
Yes, refugee, but I didn't use your integration, I just used the official one. Even testing today they get added instantly when I click add device on ST.
On the application state, the speakers state is empty (speakers {}). I don't think you need a screenshot of that.
LAN Concern. The SmartThings and Hubitat Apps use the same discovery algorithms (I developed both). What is different on the LAN installation location (IP address, etc.) between the two.
WorkAround. I can create a manual installation version of the driver in several hours. But it will NOT have any group functions. Will do this if you are interested.
Thank you, a manual option would surely work, but only if it doesn't take too much of your time. Integrating these speakers is not that important to me to warrant such a time effort.
Hey, you won't believe it.
I decided to randomly try adding the speakers again today and the app discovered them correctly.
No idea why, but it's working now!
Thank you so much for the help once again
Has anyone here been able to play a playlist using the Multiroom app and then have TTS pause the playing, speak, and then resume the same playlist that was playing?
When I try any of the TTS commands my playlist is cleared out and doesn't resume playback, it gives some error about being unable to play in the app.
If I can't use the multiroom app's playlist, would be interested if anyone has successfully run their own local radio using https://icecast.org/ or something similar and had that as a preset.
By the way, thank you so much for this driver, we use it every day to keep our kids on schedule, it works great!
I used it just yesterday to play an announcement then resume a station. It is designed to do that, but does not always work (partially depending on station being played).
I have not used icecast. The driver does have a urlPreset that allows playing of station urls. If you can get the url command for an icecast station, then this should work (using add url preset).
I guess I should describe my goal, rather than what specifically I've been trying to do to accomplish it.
I'd like to shuffle play a playlist of MP3 files at specific times of day on the speaker. I'm fine if doing so requires some kind of server hosting the files. I can play an individual file, but setting it up to shuffle doesn't seem feasible without some custom scripting.
