Sage doorbell driver fixes problems with internal driver v2.8.4
Totally rewritten driver. Simulated battery using presence detection.
All works no problems reported.
I am only using the button 1 input as well but I just checked the device events and I am not seeing any events from the second button. Hmmm.
Ah, I am not using the built in driver for this device.
I am using this ported version.
Why no comment? Can we get this also fixed in.next release?
Extra unneeded events every 2 minutes cannot be good for hub load.
We are looking into it.
can you enable debug logging then post a screen shot of the live logs?
yeah, just noticed that.
I've added some logging in the next build so we can see what's going on.
Ran configure. No change.
If you want to send me code to try prior to next build im game.
Can you do another?, this time set off button 2 on the device.
I cannot set.off button 2 ..button 2 is not.connected to.anything.
I can do.button 1 and post it.
Ok
Data seems to be blank on a real press but not sure why there are multiple. It actually only rang once.
OK here is what im seeing after I started dumping the raw data.
Its sending cluster 0006 data and the driver is reading it as button 2 press....
[raw:catchall: 0000 0006 00 00 0040 00 F7F6 00 00 0000 00 00 F30000040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:F7F6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[F3, 00, 00, 04, 01, 01, 19, 00, 00]]
A valid door 2 press gives this
[raw:catchall: 0104 0006 12 01 0040 00 F7F6 01 00 0000 00 00 , profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:12, destinationEndpoint:01, options:0040, messageType:00, dni:F7F6, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[]]
Its reading both as a button 2 press
Weird thing is this didn't happen until hrs after the update. And on my other hub 24 hrs after the update.
