Here it is mate, I updated the name (royski) so I didnt overwrite yours while testing. Anything I added has //RK at the end
* Hubitat Import URL: https://raw.githubusercontent.com/sgrayban/Hubitat-Ports/master/Drivers/rpi/Raspberry-Pi-Stats.groovy
* Raspberry Pi Monitor
* Copyright Janos Elohazi
* Copyright Scott Grayban
* Ported to Hubitat by Scott Grayban with help from ogiewon
* Monitor your Raspberry Pi using SmartThings and Raspberry Pi Monitor <https://github.com/cl0udninja/raspberrypi.monitor>
* Licensed under the GNU v3 (https://www.gnu.org/licenses/gpl-3.0.en.html)
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* !!WARNING!! This driver does NOT auto refresh your PI Stats. You will need to create a RM to refresh them.
* Changes:
* 1.0.3 - Added auto logging off after 30 minutes (Royski)
* 1.0.2 - Added debug switch
* - Added version update check (Cobra)
* - Removed Tiles section HE doesn't use them
* - Lots of code cleanup
* 1.0.1 - Supports boards up to Raspberry Pi 3A+
* - Added attribute freeMemoryPercent
* 1.0.0 - Initial port
import groovy.json.*
metadata {
definition (name: "Raspberry Pi Stats (Royski)", namespace: "sgrayban", author: "Scott Grayban", importUrl: "https://raw.githubusercontent.com/sgrayban/Hubitat-Ports/master/Drivers/rpi/Raspberry-Pi-Stats.groovy"){
capability "Polling"
capability "Refresh"
capability "Temperature Measurement"
capability "Sensor"
attribute "cpuFrequency", "number"
attribute "freeMemory", "number"
attribute "freeMemoryPercent", "number"
attribute "cpuCoreVoltage", "number"
attribute "modelName", "string"
attribute "boardType", "string"
attribute "javaVersion", "string"
attribute "hostname", "string"
attribute "serialNumber", "string"
attribute "DriverVersion", "string"
attribute "DriverAuthor", "string"
attribute "DriverStatus", "string"
// attribute "DriverUpdate", "string"
preferences {
input("ip", "string", title:"IP Address", description: "cpuTemperature", defaultValue: "" ,required: true, displayDuringSetup: true)
input("port", "string", title:"Port", description: "8080", defaultValue: "8080" , required: true, displayDuringSetup: true)
input "refreshEvery", "enum", title: "Enable auto refresh every XX Minutes", required: false, defaultValue: false, //RK
options: [5:"5 minutes",10:"10 minutes",15:"15 minutes",30:"30 minutes"] //RK
input name: "debugOutput", type: "bool", title: "Enable debug logging?", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true //RK
def installed() {
log.debug "installed"
initialize();
// App Version *********************************************************************************
def setVersion(){
state.Version = "1.0.3"
state.InternalName = "RaspberryPiStats"
sendEvent(name: "DriverAuthor", value: "sgrayban")
sendEvent(name: "DriverVersion", value: state.Version)
sendEvent(name: "DriverStatus", value: state.Status)
def updated() {
log.info "Preferences updated..."
log.warn "Debug logging is: ${debugOutput == true}"
unschedule()
if (debugOutput) runIn(1800,logsOff)
"runEvery${refreshEvery}Minutes"(autorefresh) //RK
log.info "Refresh set for every ${refreshEvery} Minutes" //RK
version()
initialize();
def ping() {
logDebug "ping"
poll()
def initialize() {
if (txtEnable) log.info "initialize" //RK
refresh()
def logsOff(){
log.warn "debug logging disabled..."
device.updateSetting("debugOutput",[value:"false",type:"bool"])
// parse events into attributes
def parse(description) {
logDebug "Parsing '${description}'"
def msg = parseLanMessage(description)
def headerString = msg.header
def bodyString = msg.body
logDebug "received body:\n${bodyString}"
if(bodyString.trim() == "ok")
return
def json = null;
try{
json = new groovy.json.JsonSlurper().parseText(bodyString)
logDebug "${json}"
if(json == null){
logDebug "body object not parsed"
return
catch(e){
log.error("Failed to parse json e = ${e}")
return
logDebug "JSON '${json}'"
if (json.containsKey("cpuTemperature")) {
if (getTemperatureScale() == "C") {
sendEvent(name: "temperature", value: json.cpuTemperature)
} else {
def fahrenheit = json.cpuTemperature * 9 / 5 + 32
sendEvent(name: "temperature", value: fahrenheit)
if (json.containsKey("freeMemory")) {
sendEvent(name: "freeMemory", value: (json.freeMemory/1024/1024).toDouble().round(2))
if (json.containsKey("totalMemory")) {
sendEvent(name: "freeMemoryPercent", value: (json.freeMemory/json.totalMemory*100).toDouble().round())
if (json.containsKey("cpuCoreVoltage")) {
sendEvent(name: "cpuCoreVoltage", value: json.cpuCoreVoltage)
if (json.containsKey("modelName")) {
sendEvent(name: "modelName", value: json.modelName)
if (json.containsKey("boardType")) {
sendEvent(name: "boardType", value: json.boardType)
if (json.containsKey("javaVersion")) {
sendEvent(name: "javaVersion", value: json.javaVersion)
if (json.containsKey("hostname")) {
sendEvent(name: "hostname", value: json.hostname)
if (json.containsKey("serialNumber")) {
sendEvent(name: "serialNumber", value: json.serialNumber)
// handle commands
def poll() {
if (txtEnable) log.info "Executing 'poll'" //RK
getPiInfo()
def refresh() {
if (txtEnable) log.info "Executing 'refresh'" //RK
// version() // used for testing
getPiInfo()
// RK
def autorefresh() {//RK
if (txtEnable) log.info "Executing 'auto refresh'" //RK
getPiInfo()//RK
}//RK
private getPiInfo() {
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
def uri = "/api/pi"
def headers=[:]
headers.put("HOST", "${ip}:${port}")
headers.put("Accept", "application/json")
def hubAction = new hubitat.device.HubAction(
method: "GET",
path: uri,
headers: headers,
"${iphex}:${porthex}",
[callback: parse]
logDebug "Getting Pi data ${hubAction}"
hubAction
private String convertIPtoHex(ipAddress) {
logDebug "convertIPtoHex ${ipAddress} to hex"
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
return hex
private String convertPortToHex(port) {
logDebug "convertPortToHex ${port} to hex"
String hexport = port.toString().format( '%04x', port.toInteger() )
return hexport
private Integer convertHexToInt(hex) {
return Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
return [convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
def sync(ip, port) {
logDebug "sync ${ip} ${port}"
def existingIp = getDataValue("ip")
def existingPort = getDataValue("port")
if (ip && ip != existingIp) {
updateDataValue("ip", ip)
if (port && port != existingPort) {
updateDataValue("port", port)
def ipHex = convertIPToHex(ip)
def portHex = convertPortToHex(port)
device.deviceNetworkId = "${ipHex}:${portHex}"
private logDebug(msg) {
if (settings?.debugOutput || settings?.debugOutput == null) {
log.debug "$msg"
private dbCleanUp() {
unschedule()
state.remove("version")
state.remove("Version")
// Check Version ***** with great thanks and acknowlegment to Cobra (github CobraVmax) for his original code **************
def version(){
updatecheck()
schedule("0 0 18 1/1 * ? *", updatecheck) // Cron schedule
// schedule("0 0/1 * 1/1 * ? *", updatecheck) // Test Cron schedule
def updatecheck(){
setVersion()
def paramsUD = [uri: "https://sgrayban.github.io/Hubitat-Public/version.json"]
try {
httpGet(paramsUD) { respUD ->
// log.warn " Version Checking - Response Data: ${respUD.data}" // Troubleshooting Debug Code - Uncommenting this line should show the JSON response from your webserver
def copyrightRead = (respUD.data.copyright)
state.Copyright = copyrightRead
def newVerRaw = (respUD.data.versions.Driver.(state.InternalName))
def newVer = (respUD.data.versions.Driver.(state.InternalName).replace(".", ""))
def currentVer = state.Version.replace(".", "")
state.UpdateInfo = (respUD.data.versions.UpdateInfo.Driver.(state.InternalName))
state.author = (respUD.data.author)
if(newVer == "NLS"){
state.Status = "<b>** This driver is no longer supported by $state.author **</b>"
log.warn "** This driver is no longer supported by $state.author **"
else if(currentVer < newVer){
state.Status = "<b>New Version Available (Version: $newVerRaw)</b>"
log.warn "** There is a newer version of this driver available (Version: $newVerRaw) **"
log.warn "** $state.UpdateInfo **"
else if(currentVer > newVer){
state.Status = "<b>You are using a Test version of this Driver (Version: $newVerRaw)</b>"
else{
state.Status = "Current"
log.info "You are using the current version of this driver"
} // httpGet
} // try
catch (e) {
log.error "Something went wrong: CHECK THE JSON FILE AND IT'S URI - $e"
if(state.Status == "Current"){
state.UpdateInfo = "Up to date"
sendEvent(name: "DriverUpdate", value: state.UpdateInfo)
else {
