just installed my R3 today and was curious how people are using this with automation. i feel like i can just set the schedule in the app, what benefits does adding it to HE offer?
I have several Orbit garden hose valves for areas not covered by the sprinkler system. By using the Rachio and Orbit integrations in HE, I can mirror the zones from Rachio into Orbit. This allows me to do all my scheduling in the Rachio app, treating the Orbit hose valves as if they were Rachio zones.
Also, I use the Rachio dashboard display on my weather dashboard - a clear, clean six-day forecast that also shows me watering status.
This is interesting. Can you explain more about how you set this up?
Install and configure both the Rachio and Orbit integrations. Then for each zone to mirror, have a rule that says
Trigger: Rachio Zone 6 valve changes
If Rachio Zone 6 open, then open Orbit Hose Timer 1, else close Orbit Hose Timer 1.
I did have some challenges getting the new fake Rachio zones working but this had nothing to do with their being "fake" but rather new zones added to existing setup. Refer to post #42 upthread.
Unrelated, but another use I make of the Rachio integration is to expose a "Enable Sprinkler System" switch which is a open/close relay connected to a Rachio sensor port. I turn this off if I plan to mow the yard in the morning, for example. [This probably could be done with the integration alone without a relay, but I already had the relay and wire in my previous controller.]
That is cool. So, do you have to have an unused Rachio zone, which I guess works fine if you had the extras on the Rachio side and wanted to add an Orbit timer to an area that wasn't covered by your main sprinkler system?
Exactly. I have an 8-zone Rachio and only four actual sprinkler zones. There are two areas of my yard that I expanded grass into recently that aren't covered by underground sprinklers yet, but I want to make sure they get watered during the fall planting season. So I use the Orbit hose timers on hoses/sprinklers above ground as a temporary solution. This allows me to use the Rachio scheduling, weather awareness, and makes sure no two zones are watering at the same time.
I am planning on doing this. Orbit has a bunch of hose timers. What model actually connects to HE?
Search the forums for Orbit B-Hyve. I use the Orbit 21005 B-hyve Bluetooth Hose Faucet Timer, integration done by @KurtSanders, but I think there are more choices. Best to discuss the Orbit stuff in an Orbit thread.
Hey @JustinL, this is a real nit, but I'll ask anyway....
In the main Rachio device, there an attribute "DeviceWatch-DeviceStatus". I'd love to use the value in that field in RM to notify us when my Rachio goes offline. Except for whatever reason, that one variable does not seem to be accessible via RM. Not sure why.
I have two homes far apart from one another, and I've gotten caught flat-footed a couple times with internet issues or whatever, and didn't know the unit was offline until the grass had already been damaged.
you could look to use something like [UPDATED] HTTP Presence Sensor to ping your rachio
yeah that's another good way to do it. I noticed a few other attributes are not accessible to RM as well.
v 2.1.5 makes DeviceWatch-DeviceStatus accessible to RM
Can someone help?
New to Hubitat and is my first install.
Trying to integrate Ranchio 3.
The Rachio 3 integration does work, But not getting status on Hubitat Dashboard when the Rachio if controlled by its Phone app or manual control on the unit.
Searched the community board but did not find an answer that worked.
Using the Valve Template is that right?
Tried the Switch template acted the same.
The dashboard template does turn zones on and off ok and does show status on the Rachio 3 phone app.
But if turn a zone on and off via phone app or manual control via the Rachio 3 does not show status on the Dashboard.
Would the Rules Machine set to poll Rachio 3 work?
If so, could someone provide me an example of how to use RM for Polling Rachio 3?
Thanks! Ops forgot to say if I refresh the Rachio 3 zone it does trigger status in the Dashboard.
There's probably a better answer as to why the dashboard tile isn't reflecting a change of the Rachio zone done through Rachio. But to answer about RM being able to see the change, definitely yes. I do all my control in the Rachio scheduler, and mirror some Rachio zones to Orbit BHyve garden hose valves.
Do you mean the native Rachio mobile app or this or the native HE apps?
I have one of these now and am contemplating what automatons to do this summer when it will kick in for real!
The native Rachio mobile app. I like the weather intelligence available on it.
On HE, I use both the Rachio and Orbit BHyze integrations, but the only thing I do in HE is mirror Rachio to Bhyve.
HAL9000 thanks for quick help response!
Can you help with the better answer you mentioned?
I do not have any actual valves connected yet to the Rachio, only bench testing Racio 3 connection to Hubitat for testing what works with Hubitat. Purchased two Hubitat one for each daughter house and testing what devices work with Hubitat. again thanks
Oh, re-read the thread here.... I have the Costco 12 zone R3. Sounds like I need to return it for a different model. Does the 8 zone R3 integrate better?
I meant there's probably a way to do what you want with the dashboard tile, but I'll yield to someone else on the dashboard questions.
As to what you can do with HE RM and Rachio, I suspect there is a way to do whatever you'd like. The Costco Rachio should work fine. For testing purposes, your Rachio doesn't care whether you have valves connected or not .. play away to see what works and what doesn't.
Can you help?
Removed and re-installed the built in Rachio app attempting to fix dashboard status not following when manually turning a zone on or off with the Rachio android phone app or manually with the dial on the Rachio unit.
After re-install of built in Rachio app cannot get the dashboard to install a tile for Rachio?
the "add a tile" page opens but never show Rachio zones in the "Pick a Device" box.
Ranchio controller and zones show in the Devices page ok.
Note: I'm new to Hubitat and Rachio. and how to use this community board. How to attach the log file?
Did you go into the Hubitat Dashboards app, select the dashboard you are working with, and list the newly added devices as one that dashboard can access? If you forgot to do that, you are not alone .. it happens to me all the time.
