dev:1612022-06-21 07:30:11.790 pm errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: rachioController.generateActivityFeedsEvent() is applicable for argument types: (java.lang.String) values: [is connected to Hubitat] (method generateActivityFeedsEvent)
dev:1612022-06-21 07:28:56.095 pm errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: rachioController.generateActivityFeedsEvent() is applicable for argument types: (java.lang.String) values: [is connected to Hubitat] (method generateActivityFeedsEvent)
dev:1612022-06-21 07:27:26.601 pm errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: rachioController.generateActivityFeedsEvent() is applicable for argument types: (java.lang.String) values: [is connected to Hubitat] (method generateActivityFeedsEvent)
dev:1612022-06-21 07:09:25.886 pm errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: rachioController.generateActivityFeedsEvent() is applicable for argument types: (java.lang.String) values: [is connected to Hubitat] (method generateActivityFeedsEvent)
Thanks that finally Fixed it!
Removed and re-installed the Rachio community integration. Then had to re-choose the devices in dashboard. Then had to re-select each tiles device. My dashboard then was all good.
What may have fixed it before that was to sign out of Rachio on their website then resign in?
In the Rachio Community app, you'll find the dashboard setup and link to display it on the dashboard a bit down the page. Just grab that link and add it to your dashboard as an image.
Thanks for all your help getting me back online with my Ranchio 12 zone.
I have two new in boxes that I will not need. again thank all of you guys for help
I have a simple rule using RM5 that notifies us when watering starts or finishes. I use either the open/close attribute or the switch (on/off) attribute to trigger start notification, and change in lastRun to trigger finish notification.
The problem, which I'm sure you've already figured out, is that this logic notifies me every time each zone starts and finishes. Ick. Has anyone done this successfully? Or anyone who is more familiar with the device handler know which attributes to interrogate to detect the start of watering (first zone) and the end of watering (last zone)?
Hope I'm posting at the right place for these questions. I was able to get the built-in app installed for Rachio and it worked fine, but then learning of HPM, I decided to see what the Rachio offerings in there might have. I was especially interested in getting a weather dashboard and displaying my watering days. So I followed all the directions via HPM and created a new dashboard. Everything seemed to work fine. All the sprinklers show up and work. However, for the life of me, I can't figure out how to add a graphic reflecting the watering days. What am I missing?
Also, I'm curious to know what others might be using Hubitat for with their Rachio. It seems like a popular thing to incorporate, but in my case I mostly set the Rachio and forget it. I do wish Rachio simply allowed for every other day watering with Weather Intelligence. This way it would just water the lawn every other day and then skip the days when it had rained. Instead, they make you choose specific days of the week, which is an odd number, so there is always an extra day or too many. I wonder if I could automate a fix for that in some way?
