You're welcome.. Sounds awesome
Just saw this release and I am trying to wrap my head around it. Forgive my ignorance, but would this let me trigger actions on the Hubitat based on something like the webcam on my PC turning on (or off)?
Hi, I believe it will. as long as eventghost receives these events you would be able to send them to hubitat.
In EventGhost - make sure the checkbox at the bottom is unchecked and see if you get events when you turn it on/off
if not, look for a plugin:
https://www.google.com/search?q=eventghost+webcam
This is an awesome app!! Thank you for sharing!!!
Is it possible to get a notification if an EventGhost device isn't connected? I tried to set a trigger in Rule Machine for the custom attribute Connected, however RM isn't able to use that. The message RM gives me is "Not supported attribute type: BOOLEAN"
Thoughts?
Is it possible to use your app to copy a file into FileManager on the hub? Specifically a bin image like an svg or png?
Can i control spotify with this?
@gilshallem I've made a keystroke in EG. But why not working, can anyone show me how to make keystroke command in EG?
Was finally able to achieve a doorbell routine which plays an actual sound file and pops up a camera image on a screen without a recurring expense.
I noticed the driver either is or becomes quite chatty, at least in the number of logs recorded, when the PC loses network connectivity. Is this normal? Can the number of logs and potentially the frequency of the attempts to connect be reduced in any way when this happens?
Thanks,
Simon
I do not know about this integration specifically. I however have used this port for years for event ghost without any issue.
I believe it is simpler than the one in this thread, but has served well for a long time.
Comment out line 247:
// if (logEnable) log.debug "webSocketStatus- ${status}"
This will at least cut down on the debug entries. The warn level will still appear.
Sorry guys I'm traveling. I'll try to find time
No sweat. I'll probably fork your repo today and give you a PR.
Ha...there's a "Reconnect Delay" preference for reconnect attempts. It's defaulted to 1 second.
hi.. any body can help me to solve this problem?
in another pc its work, but in this pc not work
Without looking at it closely at there any variables that are not set, I e. After a reboot?
which variable?
It was a bit of a stab in the dark. I have a local web service that I call and it can change port, so I need to read in a config file that includes the port before I start calling the service. If I haven't done that I see what may be similar errors.
Was mostly looking to try and prompt some ideas for you as to what it could be in your setup, more than a specific cause.
sorry the problem resolve, my region problem. Thank you, sir,
