[Release] NOAA Weather Alerts
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
C8 2.3.9.143
Getting this error after one test alert ( which took about 15 min to go from activation to hearing the test alert. Also in the logs the warning says device caused hub overload - the device in the log is the google mini used to broadcast the alert. The google mini is not used for anything else.
