After recently installing a new Trane / American Standard HVAC system that utilizes the UC360 / UX360 Thermostat and installing the "[RE-RELEASE] Nexia Thermostat Manager (Trane Home)" by @waterboysh, I wanted a way to control my thermostat without much effort. This is my method to do that and if it helps others, please feel free to use. I welcome any feedback.
** This app is supplemental and does not work without the installation of the forementioned implementation being installed and configured.
What it does:
- Cold / Mild set points to auto switch between heating / cooling based on outdoor temps to allow auto change between seasons (Winter / Summer).
- Thermostat turns OFF when a contact sensor stays open (2 min) (user configurable to run the fan for circulation when not heating or cooling)
- 5 min delay on all contact sensors closing and re-applies outdoor-temp rules.
- Outdoor-temp rules with selectable primary/backup temperature sources (both local and cloud) + auto failover and Pushover alerts when outdoor temp sensors fail to report over X period of time (default is 3 hours) (fail safe to notify if temp isn't reporting to prevent thermostat getting stuck in OFF position in the middle of winter causing frozen pipes);
- OFF band (40-50Β°F) runs the fan 30min/hour (user configurable).
- Watchdogs re-assert OFF, fan phase, and mode-band setpoints if the cloud loses a write or hubitat hub is rebooted.
