codahq
February 23, 2019, 10:15am
1
I ported the old and broken SmartThings Mood Cube app and made a few improvements. It can be found here:
https://github.com/codahq/hubitat_codahq/blob/master/apps/mood-cube.groovy
There is some chatter about it here:
Unfortunately as it stands today it wouldn't actually work at all. I didn't do anything but port the ST app over that assumes the device supports three axis aka MultiSensor aka this:
https://docs.hubitat.com/index.php?title=Driver_Capability_List#ThreeAxis
So if the events the cube provides are just button clicks you won't even be able to select it as a device in the app. Does the driver also provide ThreeAxis? I could rework the app but there is probably something already better we could sā¦
Right now it only supports devices that implement:
Therefore it's really just for Samsung MultiSensors. I have a Xiaomi Cube on order and maybe I'll do something with that later. It has some extreme limitations as well but those are adopted and sort of explained in the linked chatter thread. The main purpose of this thread is for visibility.
luarmr
April 22, 2022, 7:32pm
2
I think was moved to:
* IMPORT URL: https://raw.githubusercontent.com/veeceeoh/xiaomi-hubitat/master/devicedrivers/xiaomi-cube-controller-hubitat.src/xiaomi-aqara-wireless-switch.groovy
* Xiaomi Mi Cube Controller - model MFKZQ01LM
* Device Driver for Hubitat Elevation hub
* Version: 0.3.3b
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Based on original SmartThings device handler code by Oleg "DroidSector" Smirnov and Artur Draga
* With contributions by alecm, alixjg, bspranger, gn0st1c, foz333, jmagnuson, mike.maxwell, rinkek, ronvandegraaf, snalee, tmleafs, twonk, & veeceeoh
* Reworked and additional code for use with Hubitat Elevation hub by veeceeoh
This file has been truncated. show original
I just got one of this devices and I am testing it out
