[Release] Magic Home Wifi (Drivers) + MagicHome Manager (App)
Cool. Meetings all day. Didn’t have time to test things out on my side. Glad you got it working.
Thanks for lending a hand :slight_smile:
Glad it’s working! Been a heavy couple days for me, and I haven’t looked on the forums at all.
Still haven't forgotten about you ... unfortunately still haven't gotten time to dig in.
Seems my v8 bulbs work fine but v7 bulb won’t work. Don’t think it allows me to upgrade it to v8 either. Any ideas?
Do they at least turn on/off?
No this one won’t do anything, v8 ones are fine.
If you enable debugging in the device preferences, open your logs, and hit save, what do your logs show?
802020-12-20 19:48:01.138infoMagicHome (192.168.0.16): [86, -9, 27, 93, 0, -16, -86] was converted. Transmitting: 56F71B5D00F0AA
dev:802020-12-20 19:47:58.712infoMagicHome (192.168.0.16): [-52, 35, 51] was converted. Transmitting: CC2333
dev:802020-12-20 19:47:58.710infoMagicHome (192.168.0.16): Switch set to on
dev:802020-12-20 19:47:55.985infoMagicHome (192.168.0.16): [86, -9, 27, 93, 0, -16, -86] was converted. Transmitting: 56F71B5D00F0AA
dev:802020-12-20 19:47:54.402infoMagicHome (192.168.0.16): [86, -9, 27, 93, 0, -16, -86] was converted. Transmitting: 56F71B5D00F0AA
dev:802020-12-20 19:47:53.648infoMagicHome (192.168.0.16): [86, -1, 17, 103, 0, -16, -86] was converted. Transmitting: 56FF116700F0AA
dev:802020-12-20 19:47:50.767infoMagicHome (192.168.0.16): [86, -6, -1, 17, 0, -16, -86] was converted. Transmitting: 56FAFF1100F0AA
dev:802020-12-20 19:47:48.905infoMagicHome (192.168.0.16): [86, -71, -68, 16, 0, -16, -86] was converted. Transmitting: 56B9BC1000F0AA
dev:802020-12-20 19:47:48.883infoMagicHome (192.168.0.16): Level set to 74
dev:802020-12-20 19:47:44.252infoMagicHome (192.168.0.16): [-52, 36, 51] was converted. Transmitting: CC2433
dev:802020-12-20 19:47:44.250infoMagicHome (192.168.0.16): Switch set to off
dev:802020-12-20 19:46:14.548infoMagicHome (192.168.0.16): [-127, -118, -117, -106] was converted. Transmitting: 818A8B96
dev:802020-12-20 19:46:13.472infoMagicHome (192.168.0.16): [-52, 35, 51] was converted. Transmitting: CC2333
dev:802020-12-20 19:46:13.471infoMagicHome (192.168.0.16): Switch set to on
dev:802020-12-20 19:46:12.724infoMagicHome (192.168.0.16): [-52, 36, 51] was converted. Transmitting: CC2433
dev:802020-12-20 19:46:12.722infoMagicHome (192.168.0.16): Switch set to off
dev:802020-12-20 19:46:07.704infoMagicHome (192.168.0.16): [-52, 35, 51] was converted. Transmitting: CC2333
dev:802020-12-20 19:46:07.703infoMagicHome (192.168.0.16): Switch set to on
dev:802020-12-20 19:45:54.255infoMagicHome (192.168.0.16): Initializing device.
--- Loading Past Logs... ---
Will you show me the logs if you only press initialize, and give it a minute or two? Curious if it’s even connecting.
802020-12-20 21:34:15.281infoMagicHome (192.168.0.16): [-127, -118, -117, -106] was converted. Transmitting: 818A8B96
dev:802020-12-20 21:33:54.970infoMagicHome (192.168.0.16): Initializing device.
dev:802020-12-20 21:33:46.842infoMagicHome (192.168.0.16): [-127, -118, -117, -106] was converted. Transmitting: 818A8B96
dev:802020-12-20 21:31:16.815infoMagicHome (192.168.0.16): [-127, -118, -117, -106] was converted. Transmitting: 818A8B96
Is your logDebug setting turned on?
Yes turned on in the device
This is an RGB + CCT bulb, correct?
I’ve tried both new and old drivers, new ones work well with the v8 bulb.
Update I’ve got it working somehow! Switched to using the following driver and it allowed me to turn it on and off without colour. Then switched back to the rgbw driver and all working. Strange!
Just the led strip now! It works but you have to press the on or off button twice to enable or disable it manually. I’ll work through the drivers again
Further update this bulb keeps going unresponsive to HE. Think it must be due to the version of it as the other bulb on version 8 works fine all the time. Magic home have said there is no upgrade available for this one so looks like I need to remove it.
Can you send me an amazon link to that bulb?
It doesn’t seem to be available anymore but here is a screen grab of the original order. Don’t worry about it I’m probably going to replace with smart light switches instead as friends and family turn the switches on and off which stop the bulbs working anyway :joy:
Oh! I actually have that bulb. I’ll be doing some work on the RGBW driver today, which is what that one should use.
Ok cheers, I bought another one a few months after this and that seems to be a v8 one which works fine. Seems to be an issue with the v7 and magic have said it cannot be upgraded :weary:
