[RELEASE] Linptech/Moes 24Ghz Presence Sensor ES1 ( TS0225 _TZ3218_awarhusb ) drivers
@alex1 Instead of rebooting the device, have you tried periodically sending a command to change the sensitivity or the detection distance?
These commands force the Linptech sensor to re-calibrate, which may effectively have the same effect as turning it off and then back on.
