@dandanache just want to say mega-thanks for the added remote control. Works great!
Hey Dan, am I missing it or does the driver not have a mute attribute? My TV remote (dashboard) has a single mute button that, like most remote controls, toggles the mute/unmute setting. So I had previously run with simple logic -- if the TV is muted, then unmute it; if the TV is not muted, mute it. But I can't implement any such muting logic AFAICT because there is no mute attribute in the driver.
I'm guessing it's a simple fix -- I'd do it myself and submit a PR, but I don't know what I'm doing so.... ![]()
Totally not a big deal, but a nice to have if/when you get around to it. TIA.
Isn't this it, on the Commands page, under Current States?:
If you want to use it in a rule, it's under Custom Attributes:
Hmm odd I don’t have that attribute. What version of this driver are you using?
Or maybe there’s a WebOS firmware thing.
Can you please set logs to "Debug", then mute/unmute the TV, and paste the logs? Maybe there's something easy to fix.
Firstly, thanks for this!!
Would there be scope for adjusting screen brightness in the future? If not, I'm sure one of the picture modes is dim enough! (I could never get our TV to automatically dim when the lights are off in the bedroom, but we have a mmWave sensor that also has a Lux sensor on it, so my idea would be to dim the TV when the light levels are low)
Setting aside Hubitat for a moment, does your LGTV allow for screen dimming? Never knew that, if so.
Issued "Mute" command and then "Unmute" command from Commands page of the HE device. To be clear, they both work as expected, but no Mute attribute shows up.
Immediately before the mute/unmute stuff, but right after I turned the TV on, I noticed this in the logs. I don't see any bad behaviors, but thought I'd share in case it helps.
Released version 1.7.0 with the following updates:
Added
- Add "Set Picture" command to control brightness, contrast, color, backlight, and pictureMode - @Biggsyboi, @mluck
Fixed
- Fix "mute" attribute for TV that do not support "volumeStatus" - @mluck
Picture attributes can be set all-at-once (like a scene), or modify just a subset; empty values, and values outside the 1..100 range, are not sent to the TV:
Hope the new picture settings are supported on other webOS versions, I can only tell you that it "works on my computer" (fw 23.20.58) ![]()
Have fun!
V1.7 worked on my TV to add the mute attribute. Mega-gratitude!
Wow! Thanks! I'm using a discontinued driver so I'll swap over soon and report back! Thanks so much
Any reason HPM is not updating your app? My HPM-installed version shows v1.5.2 being installed and check for updates doesnt show 1.7 being available.
I moved the source code repository away from Github, and this change is not really supported by HPM (it caches all matched package manifest files, so it still points to Github).
To fix this:
Apps >> Hubitat Package Manager
Package Manager Settings >> Remove a Matched Package
Tick only "LGTV with WebOS" >> Next >> Next >> Main Menu
Match Up >> Next >> Put your hands in the air & wave 'em like you just don't care >> Tick "LGTV with WebOS" >> Next >> Main Menu
Update >> Wait a bit >> Tick "LGTV with WebOS" >> Next >> Next
fabulous thank you
Hi @dandanache
FYI I came across a 404 error when the TV is turned on (not sure when it appeared... sorry):
(note that I moved up a couple of lines in utils_sendMessage() to get the message id logged, to make it easier to match up the sent and received messages in the logs
Looks like my TV doesn't like ssap://com.webos.media/getForegroundAppInfo however ssap://com.webos.applicationManager/getForegroundAppInfo returns the current activity just fine.
Released version 1.7.1 with the following small fix:
Fixed
- Ignore 404 error for devices that don't have support for
ssap://com.webos.media/getForegroundAppInfo- @hubitrep
Have fun!
Released version 1.8.0 with the following small update:
Changed
- Change the "Ping interval" preference option into a device command, so it can be used in automations - @hubitrep
Kudos to @hubitrep for preparing a pull-request for this feature! ![]()
Have fun!
I'm using the with my LG OLED TV and the driver is working very well. However, I'm having problems trying to control some of the functions of the driver with the Maker API.
I can turn on/off power, set the channel, set the volume and other similar functions with the Maker API. However, I am unable to set activities or simulate button presses from a remote control through the Maker API.
For example, to change the TV to HDMI1 I am sending:
http://[Hub IP Address]/apps/api/[Maker API App ID]/devices/[LG TV Device ID]/startActivity/com.webos.app.hdmi1?access_token=[security token]
To simulate pressing a down button on a remote control I am sending:
http://[Hub IP Address]/apps/api/[Maker API App ID]/devices/[LG TV Device ID]/pushRemoteButtons/DOWN?access_token=[security token]
Both commands are accepted by the Maker API and I get a JSON response string but neither performs the intended function.
Any insight on what can be done differently to allow these functions to be controlled through the Maker API would be greatly appreciated.
Thanks in advance for the help
Looks like you're doing everything right. If you enable debug logging in the driver, what gets logged?
These URLs work just fine for me:
- http://192.168.1.201/apps/api/158/devices/687/startActivity/HDMI+1?access_token=xxx
- http://192.168.1.201/apps/api/158/devices/687/startActivity/Live+TV?access_token=xxx
- http://192.168.1.201/apps/api/158/devices/687/pushRemoteButtons/MENU+WAIT:4000+BACK?access_token=xxx
Try to start an activity that is present in the "Activities" State Variables:
For the buttons, make sure this preference is on:
Thanks so much @dandanache !
I can see why the HDMI1 selection didn't work. It is more confusing why the push remote buttons http request didn't I'll play with it some more.j
Thanks again
