No. There is no proximity/motion sensor in the Iris V1 keypad. They only light up if you press one of the buttons.
Much appreciated! Thanks for your quick response.
I just had to have one of these Iris V1 keypads when I stumbled on one on eBay. I paired it with Hubitat and immediately felt dread regarding setting it up. Removed it from my hub and going to stick with tablet dashboards. It's such a shame because it appears to be an incredibly well made device.
Oh dont give up. The iris v1 keypad is great. The member who created the driver did a great job . I had version 2 and switched and never looked back.
Tony
Ok this is a update. I just bought another keypad on ebay and discovered another firmware. This one doesn't repeat the alarm tone like mine did. Now im wondering what others are doing. Some of the tones mine have are not in this one. So I've made sound changes. Also added options for BAD PIN tones.
I also discovered on one of mine is reporting 2 battery values because one set of batteries is lower than the other. It reports a 67% then later a 78% so far I cant find anyway to tell which battery its sending info for but with 3 sets its likely been sending 3 bat reports all along they just normally match. The bat pack has 3 sets of power input wires making 3 3v supplies. Not sure what to do about this. Perhaps a warning that your batteries are mismatched.
I have made changes in the arming from the keypad. The keypad would arm and then send the HSM arm command. When the HSM replied back it was already armed.
Now it sends the HSM arm command and waits for the HSM to arm it. This should work better if the hub is sluggish, It should arm right when the HSM does. This might make setup easer because its no longer going to arm if you don't add it to the HSM setup. So if you forget to do that you will notice something wrong right away
The HSM sending code has been rewritten to save space.
Delays are also different before the HSM set the delays when in setup. Now it can detect a HSM arm delay change and adjust to it while arming. I had detected it having a different delay than the HSM and this fixes that,
Extra PINS were added in a version a while back.
Autopair is now fixed. The solution was that the HUB is hard wired for the CareFob
inClusters:"00F0,00C0" the keypad uses
inClusters:"00F0,00C0,00F3,00F5"
The hub doesn't know of any other iris device using 00C0 so it thinks any device using 00C0 is a care fob. For now the solution was just to add the carefob fingerprint.
Also the driver is now in the Hubitat Package Manager if you have problems with it matching, I did you may have to switch to carfob delete the driver and install from the Package Manager
@iris What firmware version did you get on your new keypad? Was it unused or used?
Thank you for updating the driver. I have a question. Do you have a list of the sounds? I did see that 10 is the "door chime" which also seems to be used as the disarm sound. What are the others?
@iris I just started with the Keypad I received as a complete kit with sensors etc. After pairing and installing the driver from HPM,(v6.8.5 10/10/2022) I am getting the following error:
dev:6772022-10-16 06:14:14.077 PMerrorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Long#minus.
Cannot resolve which method to invoke for [null] due to overlapping prototypes between:
[class java.lang.Character]
[class java.lang.Number] on line 1453 (method checkPresence)
dev:6772022-10-16 05:14:14.068 PMerrorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Long#minus.
dev:6772022-10-16 04:48:54.135 PMinfoIris v1 Keypad : SendMode: [Normal] Pulses:0
dev:6772022-10-16 04:48:54.126 PMtraceIris v1 Keypad : sending:[he raw 6751 0 01 0x00F0 {11 00 FA 00 01} {0xC216}]
dev:6772022-10-16 04:48:54.123 PMtraceIris v1 Keypad : sending:[he raw 6751 0 01 0x00F0 {11 00 FA 00 01} {0xC216}]
dev:6772022-10-16 04:48:48.066 PMtraceIris v1 Keypad : sending:[he raw 6751 0 01 0x00F0 {11 00 FA 01 01} {0xC216}]
dev:6772022-10-16 04:48:48.060 PMinfoIris v1 Keypad : StartMode : [Ranging]
i'm attempting to use this keypad to lock/unlock a smart lock independent of HSM. i've created rules to accomplish this based on armedaway and disarmed status of keypad that locks/unlocks the lock respectively. however, when the keypad is in armedaway status and the lock is locked, the driver polls HSM and if HSM is disarmed it sends an action to disarm the keypad thus unlocking the lock.
is there a way to disable the HSM polling feature?
I was in the SystronicRF Beta as well. Having them just fall off the face of the Earth was discouraging. When I could not get any answers to questions, I jumped to HE.
Sad to see them go. Their system and concept could have been something.
I was wondering if anyone has had luck pairing this with a C8 hub? I am still on a C7 and it works fine, but not working on a C8 is a def reason not to upgrade for me.
I would assume it won't as they no longer support the V1 Zigbee on C8 hubs.
I wish I had know this before I bought my C8, because I would not have. My C7s and C5s worked fine, but I had to have two in my house to cover all my devices. One worked mostly but it was just better response and reliability with two. I had hoped with the C8 I could just use one, and I think it would have worked. I have a number of the V1 iris devices, however, that I can not pair to the C8 so I still have to have 2 hubs.
Dude, this is amazing. I've been using your driver on my V1 keypad over the last year. Out of the 6 keypads I own, the V1 plus this driver is an awesome combo. 100% reliable, hasn't failed once and still on the same set of batteries !!
@iris Thanks a million
The key for me would be whether Iris V1 devices on a C5 or C7 hub would work if I upgraded the hub that has all the other devices. If it would not work, then I guess I will not migrate to a C8 hub.
I put my upgrade plans on hold because they took out the Iris compatibility. I like my Iris V1 keypads the best too. I'm holding out till the c-9 with hopes that compat will return.
I would not hold out hope for that to happen. I still would like to know if Hub Mesh would allow the V1 devices to remain useful if they are on a C5 or C7 hub when used with a C8 or higher hub.
If you have a C5 or C7 then yes the V1 devices work well on those hubs. I have both a C7 and C5 and V1 devices on both. My plan was to remove the C7 and put everything's on a C8 but I had to scrap that. So I still have my C7 running the V1 stuff. Hub mesh allows full access the V1 devices on a C8 if you need to, you just can't pair them to the C8.
I have two Centralite zigbee keypads that are new in the box if anyone is interested. Pm me with an offer.
RE: do I have a list of the sounds?
I have named them in the pulldown menu but yours may or may not play all those sounds depending on the firmware. I tested all the possible sounds and these are what I found.
I have 3 keyboards and not all the sounds play the same on all keypads. You need to try them.
Is there updated code available or is it something that can be done by just editing the code here? I also don't use home, so it isn't urgent for me. However, it is good to squash those bugs.
Not sure what you wanting, IRIS supported ON and Part. ON arms away and Part can be set to any hubitat modes as well as * and # can be set to any mode.
Are you wanting to rename the ON button to other than away? As far as I know there are no bugs
