[RELEASE] IKEA window roller blinds
Has anyone replaced Trippevals cellular blinds w/the new Tredansen motorized blinds?
Would be nice if I can just pop out the Trippevals and replace them w/Tredansen.
You outta look at blinds.com and get an AM43... Your WAF will go through the roof
She only wants simple cellular blinds like the Ikea Trippevals (which she loves the look of)...no external motors allowed, nothing that makes it look any different than the simple design of the Ikea cellular blinds. That's why the Tredansen could be my only hope (aside from Obi-wan...). :slight_smile:
https://lafacemcgovern-my.sharepoint.com/:v:/g/personal/it_laface-mcgovern_com/Ef3MgAoJVi1Nk8KhewJWLmABbANYBj6eUtT1brVSsGLwpQ?e=dKBRQn
@a4refillpad , I’ve just finished modifying Ryan780 from 2 year old code and then I found you. Comparing the driver code I like your idea of setting maximum height. If you dont mind, I’ll incorporate this idea in mine. I want to keep mine for the following reason;
I have 14 of these blinds. With all that « talking » on the zigbee network, it was getting too many collisions and too many commands were getting lost or taking too much time to respond. Beside, in my case I have absolutely no need to know the percentage of the opening. So I stoped the blind from pushing its position. Great improvement in responsiveness.
My main concern was the battery level. When replacing the battery, I had to open up HU go select each blind, select Open, the Ping to get proper battery level. I have found a way to automatically detect reinsertion of a battery and activated the commands to refresh the battery.
I believe your code is perfect the way it is and these changes might not be suitable for everyone. I think I’ll publish mine a bit later (after I added the max length and after I figure out how to publish from github).
Now the big question: have you modified this like me (on try and errors) or you actually found the real documentation on the ikea commands? I wish I could understand everything received from the blind, and also being able to see all possible commands.
And have you been able to make uses of their ikea buttons?
Hi there, yes, I worked it all out years ago via trial and error only whilst still on the smartthings platform. AFAIK there isn't any real documentaion apart from generic ones for the zigbee platform.
I did try for some time to make the buttons work but apparently they are not compatible with hubitat. I did get them to work on smartthings and for a while used hubconnect to relay them across. However, even on smartthings they were just so unreliable I uninstalled them.
Has anyone had their IKEA blinds suddenly start stopping half way ? I can't seem to force it to go lower than 50%. May need to reset.
Maybe. But try going to the device page and doing a Hard Open and see if that fixes it.
Hi there,
I've been using the old driver for quite some time. Worked like a charm, but with a lot of events in the logs. So I came back to this thread and was happy to find a newer version of the driver.
However, if I use the old driver, 0% would be open and 100% would be closed.
With the new driver it's the other way around. 0% is closed and 100% is open.
Is it supposed to work like that, or do I need to change something?
Thank you in andvance for your reply!
EDIT: Never mind, I have changed all my rules (and my mind) to the percentage being how opened the blinds are, instead of how closed...
It needed to be this way to be compliant with Alexa. Close = 0% and Open 100%
That what it's for and I would recommend running occasionally as the blinds tend to lose calibration over time.
Hi new HE user here and this community is amazing! so far I've seen lot of help. Ive been struggling to pair my Ikea blinds with my habitat, I follow everything on the instructions
I pair first the repeater, then I did the blinds and pair them with hubitat, so when I'm in my devices I can see the blinds and ive added the blinds to google home, the thing its that they don't work once I press the button do I need to change anything else? thanks
Welcome to the community!
I suggest reading back through this topic to see what has worked well for others. For one thing, I would have put the Ikea repeater and your Google Home aside for a while until you had the blinds working with Hubitat. The repeater is simply a Zigbee repeater and it doesn't need to be part of your install unless you don't already have strong Zigbee in the area of the blinds. Google Home is just layering on a complication.
When you say "button" are you talking about the up/down button that came with the blinds? That won't be part of your install either. If you choose to integrate the blinds with Hubitat, you won't be able to use that button for anything.
Can you control the blinds from the Hubitat device page?
thanks for the answer! sorry for late response. Yes! i did manage to control the blinds with hubitat device page and on the dashboard too but my whole point its to create some voice commands or automization. When i first paired google home with HE i did put the blinds as switch so my command was "google turn off the lights" so Google can open the shades but i want blinds to be on my voice command so i try unpairing HE and google, delete my dashboard and unsuccesfully manage to change from switch to shades.
Did you ask Google to "Sync my devices"?
You should be able to remove the switch from Google Home on HE. (Sync my devices - to remove it from Google)
Then add the blind to Google Home in HE. (Sync my devices - to add it to Google)
The blind appears as dimmable lamp. You can then set the "dimmer" to any level and the blind will open/close to the desired level.
How do I ask to sync my devices? I thought that was done on HE I did press sync on hubitat, unlink Google from HE and even delete my dashboard but still Google recognizes that tule as switch and not shade
You say: "Hey Google, sync my devices"
Google usually responds with somthing like "okay, synching devices from 4 providers..."
Oh I’ll try that after work thanks! So after that I should be able to see the tile as shade and no switch?
No, it will be a dimmable bulb :slight_smile:
Thanks for the driver @a4refillpad!
So to rehash a question that’s been asked a million times over:
No direct blind button driver? I just hate to toss plastic in a bin.
I also don’t have their later didgeridoo mostly matters hub so I’m curious if that could get the buttons working. Just nice to be able to have this as an added option.
I could always add double clicks to my existing Lutron Picos via ABC I suppose… but so close, yet so far awwwaayyyyy……….
