If you have the Dirigera hub, the on/off button firmware gets updated to 24.4.5
Really messes up the battery percentage in SmartThings and HA (shows as 250%)
Really, what? They have separate firmware depending on the hub?
Okay... is it any better?
I'm not noticing any difference with it, but I've been keeping it attached to the Dirigera hub as a test system.
The Shortcut button and 5-button remote were also updated to 24.4.5.
The only devices connected to the Dirigera hub that is still using the old driver numbering system are the Styrbar remote, and the smart outlets.
The button I changed the battery in is dead again. I paired four buttons total once the driver was updated. Two of them are just fine showing ~3.05v with a multimeter. The other two have sucked the batteries down to ~2.2v. No idea why the difference. They're all running the same firmware and what-not. Two of them have nothing set up for them. I paired them and sat them on my desk right next to each other. One is fine and the other is doing the fast drain.
I did get an Xbee kit that should be here next week. I wonder if the firmware pushed from the new hub would make things worse, better, or the same. I was hoping to snap a Tradfri off eBay but used ones on there are being sold for more than the new hub brand new.
I'm not see any of the buttons in the hub's zigbee table. I wonder if they managed to each grab a different router and that's the difference in the battery drain.
I can't adequately explain why, but I grabbed an E1766 off eBay (as I don't think they're sold separately to the blinds). The driver has been updated to v1.11 and released through HPM now, so go ahead and update, it's "properly supported". It came with the 2.3.079 firmware, so I couldn't test anything earlier.
If anyone fancies sending me one of these E1743 buttons that they've given up on I'll see if that can be added to the driver too. I'm going to see how long the battery lasts in this E1766 and then likely turf it into the drawer with the rest of my Tradfri collection.
Could be. It would be nice to know what's going on. The Xiaomi buttons confuse me too - they're far more reliable (on my dedicated mesh for them) than these IKEAs but none of them use the repeaters according to the Hubitat routing table. However, if I take a repeater away - hell to pay. They hate it. Weird things.
Cool beans. I'll grab the updated driver tonight. I'm going to set the two foul buttons back up. I have an Xbee3 setup now so I can map and see what network differences there are.
EDIT: Well, I thought I was going to set them back up, but I'm out of batteries. I'll order some more 2032s. If I get some time tomorrow, I'll wire up some AAs just to get back to testing.
Another note, my second "good" button killed the battery after just two days of sitting in my wife's office after being connected for over a week without noticeable battery drain. One thing I noted is that the only "good" button left is going through a GE Zigbee light switch. Any button in the wife's office will route through one of the three nearby Ikea repeaters.
My theory...the Ikea repeater is constantly polling the button or the button is constantly trying to send something to the repeater. This "thing" is maybe something specific to the Ikea hubs that Hubitat doesn't even pick up.
Pure speculation of course...I'll try to some more testing...including forcing my naughty buttons to just through non-Ikea repeaters to see if the drain remains.
I've just tried setting this up with some E1766s I've had sitting in a drawer for years (after updating them via a Dirigera hub to 24.4.5. Added them to hubitat, then after that installed the driver via HPM and selected it for the remotes.
It looks like they added fine, but there are some things that are confusing me. Only a few are reporting battery, none seem to be treating a button press as "activity" and the one that shows activity I don't believe has had any button presses.
I haven't played around much, including I haven't tried connecting the buttons to trigger anything, but I thought it'd be worth sharing.
Thanks for this as well, this is a lot closer to working than they ever have been before.
Someone on the home assistant forum noted that they made a change to the ZHA configuration so that the ikea buttons cannot connect directly to the coordinator.
This supposedly resolved the battery drain issue.
Not something we'd have access to on Hubitat though.
I haven't had a chance to try this myself on my HA install.
Well...I've now got batteries tanking in ~72 hours no matter where I place the buttons. The only one still alive is because I wired it up to two AAs.
Apologies, if this is a wrong discussion group. I have E1810 5-button button and trying to find Hubitat C7 driver for it. Any help ? or I am simply out of luck.
Thx, W
I’d heard they were incompatible with the way in which Hubitat passes on messages to custom drivers, so I’ve never bothered picking one up.
Now, from our recent work with the previously-incompatible blind control button it would seem this may not be the case with IKEA’s newer firmware. However, nobody has yet overcome the bizarre battery drain issues, so I give hope with one hand and take it away again with the other.
Thx !
Its a shame ... E1810s worked correctly with Smartthings. Anyway, will try Sonoff.
W
Did you ever receive this button as you requested? I think I have one lying around though I am in the Middle East. Don't mind sending it though.
Hey there, no, I’ve not got one I’m afraid. Given the blind controller gives me the same battery issues as the rest of the Tradfri kit I’m not hugely enthused about spending more time on them at the moment.
I’ll keep an eye on other projects though, and will definitely take another look if a battery solution appears. Thanks for the offer of sending one - it’s likely to cost you more than the thing’s worth to get it to the UK!
I don't mind at all, it's the least I can do for the community and especially people who are actively working to make things better for the rest of us. I got the buttons free with the blinds but ironically am using Sonoff buttons to control them (single tap to open - double tap to close).
I also have the dimmer but I am afraid it suffers the same fate as the button with the battery drain though I have not yet tried updating the firmware on it.
I don't know if it's anything, but I got a new blind which has updated to 24040010. Any change in the buttons?
With the Tradfri repeater, would it be possible to keep the "Get link quality", "Get route table" functions back with your presence driver?
That's typically how I test if the repeaters are actually responding on the network and other troubleshooting.
I updated my two repeaters to this driver, both show present even though I know one is misbehaving. How long without a check in before it changes to not present?
Been away for a bit, just catching up.
The link quality should be doable. Never done the route table so I'd need to research how to get that data.
Should be 30 minutes or so. From the code it's set to expect messages every 10 minutes. It accepts that one message may be lost and then the check only runs every few minutes, so ballpark half an hour for these.
Cool. I've been using your driver for a couple weeks now and set up a notifier to message me if one of my repeaters goes MIA. So far so good!
Did you update the firmware using Ikea Gateway? I've had better success on the latest Ikea Firmware (2.3.080)
