Now with a question to the experts. I have 2 ST 360 Cams.
Similar to what we do inside ST app, that we can see the live feed from the cams.. capture screenshot, etc.. would it be possible to create a Replica driver with the same functionalities in HE ?
I imagine using a dashboard tile with the feed (in mpeg maybe) from these two cams.
Thanks in advance.
Authorize the device(s) in the OAuth application then build a HE Replica switch device. Replica will pull in the device capabilities. Copy that information:
and then paste into PM message using preformatted text </> (otherwise the forum will break the data) like so:
Summary
{"components":[{"id":"switch","version":1,"status":"live","name":"Switch","ephemeral":false,"attributes":{"switch":{"schema":{"type":"object","properties":{"value":{"title":"SwitchState","type":"string","enum":["on","off"]}},"additionalProperties":false,"required":["value"]},"enumCommands":[{"command":"on","value":"on"},{"command":"off","value":"off"}]}},"commands":{"off":{"name":"off","arguments":[]},"on":{"name":"on","arguments":[]}}},{"id":"switchLevel","version":1,"status":"live","name":"Switch Level","ephemeral":false,"attributes":{"level":{"schema":{"title":"IntegerPercent","type":"object","properties":{"value":{"type":"integer","minimum":0,"maximum":100},"unit":{"type":"string","enum":["%"],"default":"%"}},"additionalProperties":false,"required":["value"]},"setter":"setLevel","enumCommands":[]}},"commands":{"setLevel":{"name":"setLevel","arguments":[{"name":"level","optional":false,"schema":{"type":"integer","minimum":0,"maximum":100}},{"name":"rate","optional":true,"schema":{"title":"PositiveInteger","type":"integer","minimum":0}}]}}},{"id":"firmwareUpdate","version":1,"status":"live","name":"Firmware Update","ephemeral":false,"attributes":{"lastUpdateStatusReason":{"schema":{"type":"object","properties":{"value":{"type":"string"}},"additionalProperties":false,"required":[]},"enumCommands":[]},"availableVersion":{"schema":{"type":"object","properties":{"value":{"type":"string"}},"additionalProperties":false,"required":[]},"enumCommands":[]},"lastUpdateStatus":{"schema":{"type":"object","properties":{"value":{"type":"string","enum":["updateSucceeded","updateFailed"]}},"additionalProperties":false,"required":[]},"enumCommands":[]},"state":{"schema":{"type":"object","properties":{"value":{"type":"string","enum":["normalOperation","updateInProgress","insufficientStorage"]}},"additionalProperties":false,"required":[]},"enumCommands":[]},"currentVersion":{"schema":{"type":"object","properties":{"value":{"type":"string"}},"additionalProperties":false,"required":[]},"enumCommands":[]},"lastUpdateTime":{"schema":{"type":"object","properties":{"value":{"title":"Iso8601Date","type":"string","pattern":"^(?:[1-9]\\d{3}-?(?:(?:0[1-9]|1[0-2])-?(?:0[1-9]|1\\d|2[0-8])|(?:0[13-9]|1[0-2])-?(?:29|30)|(?:0[13578]|1[02])-?31)|(?:[1-9]\\d(?:0[48]|[2468][048]|[13579][26])|(?:[2468][048]|[13579][26])00)-?02-?29)T(?:[01]\\d|2[0-3]):?[0-5]\\d:?[0-5]\\d(?:\\.\\d{3})?(?:Z|[+-][01]\\d(?::?[0-5]\\d)?)$"}},"additionalProperties":false,"required":[]},"enumCommands":[]}},"commands":{"updateFirmware":{"name":"updateFirmware","arguments":[]},"checkForFirmwareUpdate":{"name":"checkForFirmwareUpdate","arguments":[]}}},{"id":"refresh","version":1,"status":"live","name":"Refresh","ephemeral":false,"attributes":{},"commands":{"refresh":{"name":"refresh","arguments":[]}}}]}
The controls and events probably will mirror, but the video itself is troublesome.
Hi there @djgutheinz!
I just wanted to express my gratitude for adding Sonos to HubiThings Replica. When I was using SmartThings, I had many Webcore pistons using Sonos that were incredibly helpful, and now that I've switched to Hubitat, the Sonos integration isn't as robust and is missing some features like recognizing stereo pairs, etc.
However, I did notice a small issue with the "Status" in the HubiThings Replica for each device. It doesn't seem to be working properly, as it displays "stop" instead of "playing". I actually use this feature in my Webcore pistons for various purposes, so I was wondering if there's a way to fix it? Thanks in advance!
HubiThings Replica Sonos Device Status
Hubitat Sonos Device Status
First, I assume you are using the SmartThings Edge driver, yes? I only ask because when I look at the images you provided, I see evidence of a problem in more ways than just the "status." For example, your speaker is reported as "ungrouped," but the groupVolume is different (18) than the individual speaker volume/level (17), which isn't really possible.
If you are using the Edge driver, then I have to refer back to one of the "known issues" I mentioned in my original post wherein the SmartThings Edge integration intermittently stops reporting or responding properly (or incompletely) via the API or even in the device presentation in SmartThings' own app. This behavior has also handicapped my SharpTools dashboards, which are connected directly to the SmartThings API and don't use the replica driver in any way.
When I posted the replica driver, it was my understanding a fix was already in the works, however, according to some reports, the problem has gotten worse with the latest release (3-14-23) of the Sonos (Beta) driver. SmartThings engineers are very much aware, but haven't provided any updates as yet. A couple of people have reported that an ST hub reboot helps, but I've found that to be a temporary fix at best.
I've been debating for the past couple of days about how to handle this in my original post as the replica integration works for me about 90% of the time, but you sort of solved that for me. Unfortunately, I've had to postpone any further work on my webCoRE integrations using this driver as well.
Sorry I don't have a better answer for you...yet.
I am not the creator of this product. I am a user of it and ALSO greatly appreciate the capability as well as the great amount of work done to generate the work.
Thanks @djgutheinz sorry for the confusion. I tagged you by mistake, should have been @bthrock.
@bthrock thanks for the valuable information and insight. Fingers cross this get fixed in a timely manner by Samsung.
Hello, I was wondering if anyone could help me answer if this app can solve a need for me.
The Logitech Harmony remotes have home control buttons that allow you to control devices from specific hubs including Smartthings (not Hubitat, unfortunately). I previously had my lights in Hubitat and connected them into Smartthings using Hubconnect. That allowed me to map the device into the Harmony remote. Is it possible achieve that with this app?
Short answer is yes. Mostly because Logitech (Harmony) has recently updated their OAuth integration with SmartThings to the new ST cloud scheme.
The longer part of this - the Harmony to SmartThings OAuth integration is difficult to make work, but seems to keep working once you have it configured.
This is my suggestion to make HubiThings and Harmony buttons work for you:
- Delete all integrations with SmartThings and Harmony on both the SmartThings app and the Harmony app. If you have multiple hubs, clear those integrations too. Be sure to clear the old ST automation application that was Groovy based (in the ST app).
- In the SmartThings app - configure a new location and call it 'Harmony'.
- Install HubitThings from HPM and follow the normal install path. When you go to authorize a location, be sure to pick the 'Harmony' location you made in step 2.
- Once authorized for the 'Harmony' location, you can build ST Virtual devices from the 'Configure Virtual Devices..." selection in Replica.
- Use the 'Dimmer Switch' virtual device type to build virtual devices (screen shot below).
- Now comes the fun part, you need to go to the Harmony app and authorize Harmony to use the new 'Harmony' location and the virtual dimmer switches you just made. This is hit or miss on working the first time or the 20th time or the 3rd day or...
This solution will work without a SmartThings hub.
However, if you have a SmartThings hub, you can do similar tricks with the Mira solution using ST Edge Virtual drivers and/or the Logitech Harmony hub driver (no ST hub required) with its UUID solutions. Step 6 above is the hardest and would need to be done for any of these solutions to work.
I found making a 'Harmony' location works better since the new Logitech OAuth integration will pull in ALL of the location devices, so if you have lots of ST things in a location it gets messy and makes step 6 even more difficult if not impossible.
Open for questions --
Step 5:
Thanks for this detailed step by step and additional nuanced information. Since I wanted it to be local I tried Mira which works but the problem is I cannot create a Harmony home and put the devices in there due to the fact that it requires a hub and must be located in the same home as the Hub.
Therefore all of my Smartthings devices are in Harmony now. If that causes me any issues I will consider switching over to Hubithings and see if it performs better.
Ouch, you had to say that.
But since you did lets chase this rabbit, the only 'local' option would be the Logitech Harmony Hub Driver.
Even with Mira your communication path is:
Remote -> Harmony Hub -> Harmony Cloud -> SmartThings Cloud -> SmartThings Hub -> Hubitat Hub -> Device
With the Logitech driver your communication path is:
Remote -> Harmony Hub -> Hubitat Hub -> Device
The trick with the Logitech driver is you need to assign each button a UUID. The only way todo that is connecting the Harmony Cloud to the SmartThings Cloud and assigning devices (step 6). After that is completed - the Harmony Cloud does nothing.
SO the best'est' option IMHO is to build 'virtual cloud dimmers' and then connect them to Harmony, then use the Logitech driver and assign the UUIDs from the 'virtual cloud dimmers' to the button definitions. In transparency this is what I do. (I did use HubiThings to build the virtual cloud dimmers, but you can do this via the SmartThings API or the ST Android app)
I have a BIG mental problem with the long term security of SmartThings and community Edge drivers. That is just a future security incident waiting to happen. A couple of folks in this thread know my soapbox, but since I have been involved now in 4 major security incidents at work in 3 weeks which will take months to completely block, figured I should say it again.
Wow thank you again for such a detailed response. I haven't seen anyone else break this down like you have so I appreciate it.
Here is the thing about the Logitech Harmony Hub Driver: When used for a dimmer switch the buttons only control ON/OFF. The dimmer rocker in the home control section does not work when using the UUID method that you described. If I am wrong about this please correct me but I just tried this and could not get the dimmer function to work.
Edit: I just thought about this idea: What if I created the Virtual Dimmers in Smartthings and used the Hubitat Harmony Driver UUID method to control the on/off functionality in Hubitat but I also send the Smartthings Virtual Dimmer to Hubitat via Hubithings and use rules to control the dimming functionality of the endpoint device? Sorry if I am not articulating my idea very well but let me know if you understand and think that's possible.
Logitech Hub Driver does but the implementation is a little clumsy as a result of the way the Harmony remote works. If you look a the parent device, you can see the values as bulb1Level, bulb2Level, socket1Level & socket2Level.
I couldn't begin to tell you how to use RM to solution this, but here is a webCoRE piston that makes it a little easier to duplicate (more than one remote) and assign devices to each button.
To note, I have always found the rocker switch to be hit or miss in reliability even with the ST Groovy solution was allowed. More of a toy button, then something to except to work.
This should work but you might get weird echo effects at low light levels.
New driver: Samsung Washer. Available at site below. Does not (yet) include flex compartment control. HELP can be accessed by selecting WASHER HELP from upper right of the device's edit page.
Updated driver: Samsung Oven and Cavity. VERY IMPORTANT to read the help file accessed by selecting OVEN HELP from the upper right of the devices edit page.
Near future:
- Samsung Dryer
- Dedicated thread to cover Samsung Appliances (to reduce garbage here)
- HPM inclusion as library HubiThings Replica Samsung Appliances
'HubitatActive/HubiThingsReplica Drivers at master · DaveGut/HubitatActive · GitHub'
I was wondering if it is possible to use HubiThings to send push notifications to phones with Smartthings installed. I'm using HubiThings to control the Smartthings location mode and I was wondering if it could also push notifications to Smartthings as well. It would be helpful for me as I have people at home that exclusively use the Smartthings app.
There is an undocumented ST API that at least did work but there is no promise from ST that it will always/continue to work. I think it broadcasts to an entire location and not individual device.
Are you using the Replica Hub or Replica Location driver to control the mode?
Coming back on this - Replica Location Knob was updated version 1.3.1 to send push messages to devices with HPM updated.
The 'deviceNotification' command will take either 'text' or a JSON in the format:
{ "title":"the title", "message":"the message" }
or you can use 'sendLocationNotification' with the parameters directly.
I have no idea what the various alert types do:
("ALERT","SUGGESTED_ACTION","EVENT_LOGGING","AUTOMATION_INFO","WARNING","WARNING_CLEAR","FLASH_TOAST","OPTION")
On iOS they all seem todo the same thing.
Here is a webCoRE piston to show usage in three different methods:
Wow this is amazing. Thank you so much! Don't have time to test right now but will over the next few days.
Works great! I did notice that SUGGESTED ACTION messages give an OK option that will open Smartthings if selected. Other than that they all seems the same. Don't think FLASH TOAST, or EVENT LOGGING worked for me.
