Did you install the remote hub driver on HE? Is your ST hub on the same LAN as HE? You should be able to copy the connection key, switch apps to the ST classic app, paste the connection key and click done all the way out of the ST app. Then switch back to the HE app and see if you have a connection. It still says HubConnect Server Instance, which means setup isn't complete. It should change to whatever you named your ST hub when setup is complete.
@csteele , does that sound right to you? I'm so used to the beta that my memory is a little foggy on 1.6.4. Steve needs to release the new version before camping season starts.
OK I simply did not successfully complete the last step of setting up ST to HE. It is working now. Man that process could be improved or docs could be made clearer. Thank you guys for your help!
Now would be great as we all in San Jose are supposed to stay home because of Corono virus. (I've already watched all the movies on Amazon Prime that I wanted to see)
My OCD is killing me.
I have several 3210-L Iris plugs, using @srwhite 's driver for both the Zigbee switch and the Z-Wave repeater. I noticed that HubConnect has a section for both. The Zigbee switch makes sense (I want to control the native HE switch from Smartthings); but why would I expose the Z-Wave repeater to ST?
I'm having trouble with fan control. The device is installed in hubitat and shared to smartthings with hubconnect. But the fan won't work thru smartthings. Am I missing something?
Well. It works in classic app not new app. Didn't know that. Has anyone got this to work with Google home? Home doesn't recognize hubitat fans as fans but it will recognize smartthings fans as fans. Problem is control doesn't work thru home
Yes, HubConnect for ST is Classic App only at this time.
There's just one Tile for Fan Control and it cycles through, Auto, Low, Med-Low, Medium, Med-High, High, On, and Off. The logs above show I rotated through them all.
