[RELEASE] HubConnect Bundles
I've released the ProBundle versions of HubConnect v2.0 from behind the "free wall".
The difference is that ProBundles don't expose the code. If you need to explore the code, it's all there on https://HubConnect.to
https://hubconnect.hubitatcommunity.com/HubConnectProBundles/HubConnectServer_v2.0.zip
https://hubconnect.hubitatcommunity.com/HubConnectProBundles/HubConnectRemote_v2.0.zip
https://hubconnect.hubitatcommunity.com/HubConnectProBundles/HubConnectUniversalDrivers_v2.0.zip
To install a ProBundle:
Select Bundles from the main menu and click Import Zip in the upper right.
Select the Download from a URL tab, select This is a private pro installer bundle, and then paste in either the Server bundle URL or the Remote bundle URL above. Click Import and the result is:
You can then import again using the UniversalDriver URL or use Hubitat Package Manager for the Universal Drivers.
