Which is why I specifically said the it works if you remove the DriverV3 part and make it device.HubInformation
You made this easy fix almost pointless now. This tiny fix makes the app work with either version of the hubinfo driver work perfectly.
HAH !! I looked at this code again and the issue is the upper/lower case. The actual name of the driver is Hub Information Driver v3
notice the V is lower case NOT upper case as in the code so @thebearmay made a typo in his code. However the app does seem to work with either version of the hub info device so device.HubInformation
should still be ok.
Thanks for the pointer as I totally forgot about this.
