I suggest you revert back to 123. Others have found the 500 error also.
Ok, will give that a try.
Edit: Reversion to platform 2.3.8.123 eliminates Error 500 when Save Preferences or Save Device in Hub Info.
Works OK to Save Preferences or Save Device:
Hub Info v3.0.36 or v3.0.37
Hubitat 2.3.8.123
C-8
Gives Error 500 if Save Preferences or Save Device:
Hubitat 2.3.8.124
C-8
Try hitting Initialize.
Been there, done that, no change. See the logs posted above. Only corrected when I rolled back to 2.3.8.123. 2.3.8.124 seems to have problems saving preferences and devices, not just your device.
There is a whole other thread where staff replicated the issue and recommended rolling back while they investigate.
v3.0.38
Added a passive cloud connection check (attribute: pCloud) by interrogating the Hub Alerts array as an alternative to the active cloud connection check (attribute: cloud) that does a query against MakerAPI or a Cloud Dashboard link.
This could result in one less endpoint call if you are already using the Z Status, Hub Alerts, Active Cloud Check parameter.
Was originally designed to catch when zigbeeStatus and zigbeeStatus2 disagreed and trigger an alert that there may have been a radio crash. The error and alert have been disabled as after the code ran for a while it became apparent that what was causing the discrepancy was having the radio in one state at boot (zigbeeStatus) and then changing it after boot.
@thebearmay,
I believe I requested for the memory to be displayed in MB last time.
Are you able to support displaying the free memory in GB as well for C8 Pro please?
Thanks again
The way your hub is using ram, give it another 24 hours and MB will be the appropriate unit. ![]()
In all seriousness, dynamic unit switching between GB and MB would be a nice option to enhance legibility. Eg <1GB = MB and >=1GB = GB.
That should be easy enough to do, not sure why I hadn't thought of that.
Okay, v3.0.39 is out there.
I could do that easy enough, but if you're logging the memory usage for graphs, etc. it could cause irregularities unless you compensated appropriately.
Just for you @dJos
v3.0.40 has a dynamic memory unit option.
- Below 150000 -> KB
- 150000 - 1048575 -> MB
- Above 1048575 -> GB
Thanks, that was a very fast update!
Dynamic option does not seem to be working for me (GB works fine) ?
See below:
1182.68 MB (Dynamic option)
1.15 GB (GB option)
Well the calculation is correct but not the unit elevator - I'll take a look and see what I typo'ed.
Thanks.
Edit: Do a repair or re-import v3.0.40 (I typed w instead of W in the middle of a variable0
Working now, thanks!
Dead set legend, thank you. ![]()
Sorry if this is answered already or I'm too stupid to figure this our on my own, but what does everyone use to grab this data from a remote hub? I have a couple of remote hubs and currently use HubConnect to share and control devices in my main hub dashboards. I'd like to bring this data over, so a quick look on my phone or at work, I can see data from all my hubs in one place. Currently using HubMesh for the local hubs...
You could use the free cloud InfluxDB and Grfana setups, then my pre-made dashboard. You can view all the hub info on one dashboard using that setup. If you dont mind sending some data to a cloud service.
