[RELEASE] HomeSeer HSM200 Multi-Sensor
It was relatively simple to create a Rule Machine entry which triggers on HSM-200 color change - it looks just like your screenshot. Note, you may need to look at the Device page for the HSM-200 when it's the color you want, to see what it actually calls the color. For example, I thought it was "Red", but actually "Magenta" in my testing.
While this is not exactly what you want it does show conditions for color represented in hex. The 2 colors listed are green and red.
Is there a way to update the sensors firmware thru HE?
I've downloaded sensor firmware update 2.8, but don't know how to get it into the sensor.
I see in the device settings:
There is a zwave command line. How would this be used to send the .hex file?
TIA.
There is a built in app called device firmware updater.
I've used it to update Zooz devices.
Thanks Velvetfoot. I found it! I followed instructions & got the update process started, but it errored out. It seems HomeSeer want you to buy their software update package and THEIR USB dongle to update their products. Doesn't look like I'll be purchasing anymore Home Seer products.
Bummer.
It’s been a while since i’ve done this, but i remember the auth event it’s looking for is a button press on the side. I’m not sure if you tried that already, but i think that will get you further.
Thanks, but no joy. No side button I could see, just and arrow to proceed after firmware file is selected.
Mine had to be right next to hub to update .
It’s the same side button you have to push for inclusion. If the button is not there it’s not a HSM 200.
https://docs.homeseer.com/products/sensors/hsm200/hsm200-user-guide
DUH! Slapping fore head. Yes. Didn't occur to think of that.
Pressed THAT button, then clicked start update. The led started blinking yellow, and the updated started. 1%, 2%, 3%, etc.
Gets to 25% and errors out. Several attempts. Same timlng. 25%. Does that sound like a bad hex file?
THANKS!
if its a bad or wrong hex file it should fail after the whole thing is copied over. i think kahn’s recommendation of ensuring the hsm200 and the hub are VERY close to each other, like no more than 3 ft/1m and try again. If you have S2 enabled on the device re-pair the device to hubitat w/o S2. Finally there are 2 versions of hsm200, make sure you are using the correct version for your hardware. 2.8 for the version w/ a tab, 1.10 for the version w/o a tab.
2.8
IMG_0635
1.10
IMG_0636
Thks Sidjohn. I have the tabbed ver.
I moved the HSM200 2ft away from the C7 hub. No other devices near by.
Pressed the hsm200 side button and clicked start update. Led started blinking yellow, and the updated started, like before. 1%, 2%, 3%, etc. Got to 25%, and when I expected to see 26%, it errored out, again.
The hsm200 has ver 2.7 in it now. I wanted to update this 1st before doing another hsm200 that has ver 2.07. Also, no security when I added it to the network.
Yes, I could never get the HSM200 to update and had all kinds of issues with it not resetting after motion. Great idea, and it would be great if there were more plugin options. But as someone with 8 HSM200’s, I can say they are not yet ready for prime time,
Have you tries my driver
Is anyone using the HSM200 successfully? I don’t want to develop an opinion based solely on problem reports, but it seems that’s all the Hubitat related info I can find :slight_smile:
Are there any other plug-in motion sensors? Seems very convenient as it acts as a repeater. The RGB light on this product is icing on top.
I’ve decided to take a chance and order one. Will give it a go and post my results.
Okay, just for the record. I got an HSM200 and it works great! I used the EzMultiPli driver from @kahn-hubitat I’m able to set up motion triggers and set the light color in a Basic Rule (it’s capable of exactly seven colors).
When you first plug it in it’s in pairing mode (blinking cyan). Once paired, it plays a game called “Can I see you?” where you move around and it will blink white if it sees you move. It does this for five minutes. I guess this allows you to determine its range and whether the positioning is good.
A good first impression!
I'm not sure which driver I'm using but it works great.
Just a little bit of info for anyone wishing to employ the Homeseer HSM200 in their environment.. I own 11 of these devices.. bad decision.. very inconsistant from device to device.. highly inaccurate temps sometimes by over 100°F and the non-stock driver cannot accomodate a parameter adjustment anywhere near that high.. the illuminance value is highly inaccurate in all devices.. I use the built-in LED to show hubitat HSM status ie armed, alert etc.. Send out the command to turn all the 11 LED's the same color but usually only 1/2 actually ever get the command.. Several previous HSM200 have become partially inoperable after a power failure.. Motion detection sometimes become stuck..
The unit (not produced by Homeseer, rebranded by Homeseer) in theory seems like an excellent piece of equipment but only if it would actually live up to its claim to fame.. I wasted alot of good money on these..$50+ each..
